VWVortex.com - 2001 audi s4 lots of codes HELP!
    Results 1 to 5 of 5
    Thread: 2001 audi s4 lots of codes HELP!
    1. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      03-08-2011 01:16 PM #1
      So my brother wanted this audi s4 and i went with him to get it and told him it was a good buy. had lots of repairs and maintenance and proof of it and drove smooth. only needed an alternator.
      had alternator replaced and rescanned and tons of codes came up. I did clear and we will see if they come back
      autoscan :
      Tuesday,08,March,2011,08:45:44:04884
      VCDS Version: Beta 11.2.0 (x64)
      Data version: 20110305
      Chassis Type: 8D - Audi A4 B5
      Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
      Address 01: Engine Labels: 078-907-551-AZA.lbl
      Part No: 8D0 907 551 J
      Component: 2.7l V6/5VT G 0003
      Coding: 06751
      Shop #: WSC 06435
      VCID: 316312EAD3E9
      1 Fault Found:
      18057 - Powertrain Data Bus: Missing Message from ABS Controller
      P1649 - 35-00 - -
      Readiness: 0110 1101
      Address 02: Auto Trans Labels: 01V-927-156.lbl
      Part No: 8D0 927 156 BS
      Component: AG5 01V 2.7l5VT USA 3132
      Coding: 00002
      Shop #: WSC 06435
      VCID: 7F0704D2553D
      No fault code found.
      Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
      Part No: 8D0 820 043 P
      Component: A4 KLIMAAUTOMAT D58
      Coding: 00160
      Shop #: WSC 06435
      VCID: 2D5B0E9ACFD1
      14 Faults Found:
      00787 - Temperature Sensor in Fresh Air intake duct (G89)
      30-10 - Open or Short to Plus - Intermittent
      00779 - Outside Air Temp Sensor (G17)
      30-00 - Open or Short to Plus
      01274 - Air Flow Flap Positioning Motor (V71)
      41-10 - Blocked or No Voltage - Intermittent
      00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
      00601 - Potentiometer On Positioning Motor for Central Flap (G112)
      00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
      00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
      00792 - A/C Pressure Switch (F129)
      31-00 - Open or Short to Ground
      01273 - Fresh Air Blower (V2)
      17-10 - Control Difference - Intermittent
      00797 - Sunlight Photo Sensor (G107)
      01297 - Sensor for Vent Temperature; Footwell (G192)
      01296 - Sensor for Vent Temperature; Center (G191)
      01206 - Signal for Duration of Ignition Off Time
      27-10 - Implausible Signal - Intermittent
      01582 - Signal for Coolant Temperature
      Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
      Part No: 8D0 959 655 G
      Component: Airbag Front+Kopf 1002
      Coding: 00304
      Shop #: WSC 06435
      VCID: 3A7135C60E9F
      5 Faults Found:
      65535 - Internal Control Module Memory Error
      00-10 - - - Intermittent
      01217 - Side Airbag Igniter; Driver Side (N199)
      32-10 - Resistance too High - Intermittent
      01218 - Side Airbag Igniter; Passenger Side (N200)
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      01221 - Crash Sensor Side Airbag; Driver Side (G179)
      36-10 - Open Circuit - Intermittent
      Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
      Part No: 8D0 920 980 RX
      Component: B5-KOMBIINSTR. VDO D17
      Coding: 02264
      Shop #: WSC 85555
      VCID: 92213D66F6AF
      4 Faults Found:
      00667 - Ambient Temperature Signal
      00849 - S-contact at Ignition/Starter Switch (D)
      31-10 - Open or Short to Ground - Intermittent
      00562 - Sensor for Oil Level/Temperature (G266)
      29-10 - Short to Ground - Intermittent
      Address 35: Centr. Locks Labels: 8D0-862-257.lbl
      Part No: 8L0 862 257 N
      Component: CV-Pump, Alarm, RC D16
      Coding: 16140
      Shop #: WSC 00000
      VCID: 4085472E6843
      14 Faults Found:
      01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
      35-00 - -
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01374 - Alarm triggered by Terminal 15
      35-00 - -
      01370 - Alarm triggered by Interior Monitoring
      35-00 - -
      01369 - Alarm triggered by Hood Switch
      35-00 - -
      01366 - Opened Due to Crash Signal
      35-00 - -
      01361 - Switch for Anti-Theft Alarm; Close
      29-00 - Short to Ground
      01360 - Switch for Anti-Theft Alarm; Open
      01362 - Close Switch for Tailgate/Trunk (F124)
      01365 - Lock/Unlock Switch; Interior
      28-00 - Short to Plus
      01389 - Tailgate Open Switch (F124)
      00991 - Interior Lights
      00955 - Key 1
      09-00 - Adaptation Limit Surpassed
      Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
      Part No: 4B0 951 173
      Component: Innenraumueberw. D03
      Coding: 00101
      Shop #: WSC 06435
      VCID: E0C527AE4883
      Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
      Part No: 4B0 907 357
      Component: LEUCHTWEITEREGLER D004
      Coding: 00012
      Shop #: WSC 06435
      VCID: E5CB36BA57A1
      Address 56: Radio Labels: 8D0-035-1xx-56.lbl
      Part No: 8D0 035 195 A
      Component: Radio D00
      Coding: 00110
      Shop #: WSC 06435
      VCID: 244DEBBE9C1B
      End ---------------------------------------------------------------------
      07 B6 Passat 2.0 turbo - http://unitronic.ca Unitronic Stage 2 HPFP - High flow cat downpipe 3" - ABD Racingwerks intake Stage 2 - HPFPUpgrade.com Stage 1 HPFP - 142 Bar fuel Pressure relief valve - 5 zigen Oil catch tank - Autotech 3" catback - Adams Rotors - H&R Springs teamed with Bilstein Sports.
      http://i51.tinypic.com/153w51g.png
    2. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      03-08-2011 01:16 PM #2
      It def needs an abs module. but airbag light is on and gives a memory error.
    3. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      '66 Impala '07 Silverado Crew Cab '09.5 G8 GT
      03-08-2011 02:44 PM #3
      Yeah you wanna clear EVERYTHING in every module and start fresh to give you an idea of what's going on. You may need an airbag control module. My old S4 had an internal check error sum fault and I needed an air bag control module and would not erase. I did a capacitive discharge, some times that will help it erase but didn't.
      You may wanna do a capacitive discharge also. Touch the + and - cables of the battery together. It makes all the modules in the car relearn themselves and clears any weird fault codes. After that you will have to set the throttle body adaptation block 60 in basic settings in the ECM. Do that clear all the faults and see what comes back
      NEK '07 Chevy Crew Cab. Formerly CorradoG60
      '66 Impala 3 on the tree (sold)
      '09.5 G8 GT
      '74 F250 High Boy
    4. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      03-08-2011 03:40 PM #4
      Yeah it wont clear the airbag faults. the abs comes right back. gives me an error message when clearing the airbag
    5. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      03-08-2011 07:36 PM #5
      yeah needs an airbag control module too $$$$
      you can send the ABS module out to get rebuilt but not the airbag module
      '09.5 G8 GT
      '74 F250 High Boy
    « Back
