Results 1 to 12 of 12
Thread: P0037 and P0036 Help
  1. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    03-08-2011 07:05 PM #1
    A while back pulling in to my friends driveway, which is very unfriendly to low cars, my car threw a CEL.
    The code was P0037. Yesterday I decided I would try to fix it. I pulled the O2 sensor out (rear one) and saw that the insulation that covered the wires was ripped, and the 4 wires appeared to be broken. Thinking it'd be an easy fix, I cut the broken part of the wires out, and using butt connectors and heat shrink I wires them back together. Then I re-installed the sensor and had the code cleared. P0037 came back shortly thereafter.
    Figuring that once the wires broke it may have shorted the sensor out or something I went and bought a new sensor. Because none of the 3 dealerships had OEM ones and none of the parts stores could get exact fit ones I bought a Bosch universal O2 sensor.
    Using the included wiring kit I wired the new sensor up to the plug from the old O2 sensor and plugged it in. Disconnected the battery to clear the code, then drove roughly 10-15 miles without the CEL coming back on. Then on my way to get re-flashed back to stage 2 today the CEL came on. When I got it scanned it came up as P0036. Which practically reads the same as the other code.
    Sorry for such a long post, the spelling and grammar may or may not be 100% up to par because this was posted on my iPhone, but I'm out of ideas and getting kind of desperate. Any help would be GREATLY appreciated.
    Lower-IT
    // DROP // DRAG // DESTROY
    OpenRoadTuning
  2. 03-08-2011 07:30 PM #2
    The front O2 sensor is fine?
    Unitronic Stg 2+ K04
    My flickr
    Past cars:
    1991 Corrado G60 autotragic
    1998 Jetta GLX 5MT - miss it to this day
  3. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    03-08-2011 07:34 PM #3
    Quote Originally Posted by g60_corrado_91 View Post
    As far as I know yes. Once I get off work I'll have them see if there is more than one code stored.
    Lower-IT
    OpenRoadTuning
  4. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    03-09-2011 10:01 AM #4
    Last night double checked the wiring on the new sensor to the old plug and it's correct, also checked the wires ahead of the plug, there are no breaks or holes in the wire insulation.
    Could it be possible that the heating element in the sensor is bad? It is s brand new sensor, and even if it is how would I go about testing it?
    Lower-IT
    OpenRoadTuning
  5. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    03-09-2011 06:55 PM #5
    Bump for help.
    Lower-IT
    OpenRoadTuning
  6. Junior Member
    Jun 19th, 2010
    NH
    2008 VW GTI
    03-18-2011 12:23 AM #6
    to test the heater circuit, check for continuity between the two wires for the heater circuit, i cant remember which color wires this is, but if you test continuity/resistance in them, you shouldnt find any opens
  7. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    03-18-2011 12:58 AM #7
    turns out it was a fuse, my car has 2 heater circuit fuses, which is apparently odd?
    Lower-IT
    OpenRoadTuning
  8. 10-24-2011 09:54 PM #8
    Sorry for bringing up a dead tread but where are these fuses I can't find them in the fuse box and I have been searching everywhere. I have the same problem and it is a new sensor.
    Thanks.
  9. Member tobydog777's Avatar
    Sep 19th, 2004
    Pittsburgh, PA
    2004 A4 USP
    07-10-2012 01:54 PM #9
    I am going to bump this up for some more input. I am picking up a car on thursday that I know is throwing p0031 and p0037. From waht I have read up on it, fuses can be an easy fix for it. Can anyone post up a fuse diagram showing which fuses I should look into first. I may also just be replacing the post cat o2 sensor anyway as the PO said it has some electrical tape on it.
    Jersey
  10. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    07-18-2012 11:41 PM #10
    the fuse is in the engine bay fuse box IIRC, although i'm not sure of which one since my buddy fixed it not me.
    Lower-IT
    OpenRoadTuning
  11. 10-03-2012 08:23 AM #11
    Where is/are o2 heater circuit fuses located?
    Anybody?
  12. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    10-03-2012 08:52 PM #12
    Quote Originally Posted by vtraudt View Post
    Anybody?
    In the fuse box in the engine bay.
    Lower-IT
    OpenRoadTuning
