VWVortex.com - Generic code P2015 in my new :/ 2009 GLI
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 67
    Thread: Generic code P2015 in my new :/ 2009 GLI
    1. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      2013 CC, 2008 yzf-R1, 01 yzf-600r
      03-08-2011 08:27 PM #1
      *** update: the intake manifold flap on the TSI motors is a known failure point; it is covered in the power train warranty and VW should replace it with out any hassles. As always, if you're heavily modified, the dealer could claim your mods are the reason for the fault (but we all know 85% of the time this is not true).
      Common Questions:
      -Is it okay to drive with? Yes, I did 12k miles on mine before replacing
      -should I clean my valves while I'm in there? Yes, it is always a good idea
      -can I fix it myself? Yes, on a scale of 1-10 (10 being VR timing chain job) I'd say this job is a solid 8. not for the newbie backyard mechanic.
      Just Bought the car 4 days ago, wouldn't be a VW if I didn't throw a code.
      My question is, is it covered under the powertrain warranty or did the below technical service bulletin act as a precursor to a recall ...most likely not
      Anyone know how to fix this wrong?
      TIA
      I understand driving on a busted intake runner flap isn't harmful as it just smooths idel correct?
      Technical Service Bulletin Transaction No.: 2019394/1
      01-08-32 - DTC P2015 (2968) Stored in ECM Fault Memory (U.S. Only)
      Release date: Nov 21, 2008
      Condition:
      DTC will set with or without MIL ON
      DTC Description:
      P2015 (2968) Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Sporadic
      Technical Background:
      • Intake manifold tumble flaps sporadically stick.
      • Engine performance is not affected.
      Production Solution:
      Production countermeasure implemented.
    2. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-09-2011 06:27 AM #2
      So far based off what I've read, this code on an FSI motor indicates that you'll have to have the actuator motor replaced. On the TSI, this motor was done away with (as they probably saw it was faulty) and not there is a piston and vacuum set up attached to the intake mani, with a sensor of some sort. the only problem is I cannot find a dinfinitive explanation of how this is fixed, weather its covered under warranty and so on. Some ppl say their entire intake manifold has to be replaced, others say the sensor. I wish and hope it was just the sensor as I could do that myself. even the mani I could do myself. but I hear is like a $500-800 part. we'll see, I as looking at powertrain warranty details and it says intake manifold is covered. unfortunately thats the only warranty left on my car
    3. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-09-2011 12:06 PM #3
      Any additional input would be Great guys. I know others have/will be going through this, none of the search results net anything useful for the TSi, I know know this issue was addressed for the FSI but still no real solution
    4. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-09-2011 03:37 PM #4
      back into eyesight for afternoon crowd
    5. Semi-n00b
      Mar 3rd, 2008
      Wisconsin
      2012 GTI, 2004 Audi A4
      03-09-2011 06:04 PM #5
      From what I have seen and assuming you have a TSI engine, the complete intake manifold will have to be replaced.
      It could be a sensor but from the ones I have seen under warranty we have had to replace the entire intake manifold. I would have liked to try just the sensor but it was only available as a complete unit, if you want the sensor, you get the intake manifold with it.
    6. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-09-2011 07:05 PM #6
      Quote Originally Posted by HXMan View Post
      Thanks for your input. After a day and a half researching it seems this is the popular consensus. I'm trying to get a used manifold off a CC TSI motor to see if they'll pair up, (And if there is any way to clean the intake mani/sensor to fix the issue. If I can get if for free, it'll be nothing lost, fixed car gained but this is also assuming the dealership i bought it from doesn't replace it for free (again, purchased at a ford dealer)
    7. Semi-n00b
      Mar 3rd, 2008
      Wisconsin
      03-12-2011 02:03 PM #7
      It should be covered under your 3/36k warranty.
      ASE Master Technician
      VW Expert Tech
      2012 GTI
      2004 Audi A4
    8. Member laramie1pt8t's Avatar
      Dec 4th, 2006
      Laconia NH
      96 GTI sold,99 GLX sold, 04 BT GLI RIP, 08 GTI sold
      03-12-2011 03:39 PM #8
      it will be covered under your power train warranty full intake mani swap. 100% positive
    9. Member wolfsburg__gli's Avatar
      Feb 24th, 2009
      Orlando / Boca
      84' Mercedes 300SD - 87' BMW 535iS
      03-12-2011 04:34 PM #9
      what sensor are you refering to??
      IG @tbmikeeee
      I VAG-COM IN SOUTH FLORIDA & ORLANDO PM ME
    10. Member
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      03-12-2011 06:30 PM #10
      The sensor that measures the position of intake manifold flaps is probably faulty. Sorta common in the TSI engines.
    11. Member wolfsburg__gli's Avatar
      Feb 24th, 2009
      Orlando / Boca
      03-12-2011 07:13 PM #11
      Quote Originally Posted by Boosted2003! View Post
      could it be why i get rough idles sometimes, and serious shuddering under throttle??? and what ive read from this, is that i couldnt buy the sensor without buying the whole
      manifold. or can you even take the sensor out??
      IG @tbmikeeee
    12. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-12-2011 07:45 PM #12
      Correct Runners and sensor, as well as the actuator all come integrated in the Manifold. I just seafoamed my engine as a possible solution
      From what I've found an heard, its not so much the sensor failing, more the runners sticking due to build up. causing the sensor to read incorrectly
    13. Member laramie1pt8t's Avatar
      Dec 4th, 2006
      Laconia NH
      03-13-2011 11:44 AM #13
      The shaft breaks off from the motor so the flaps will shut and throw misfire codes and intake flap sensor codes. You can manually open them to drive it to the dealer. I have seen this happen 3 times now.
    14. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      '66 Impala '07 Silverado Crew Cab '09.5 G8 GT
      03-13-2011 01:21 PM #14
      On the new 2.0L TSI engines, there is a vacuum “T” off of the Brake Vacuum Pump.
      On the vacuum “T”, there are two smaller vacuum lines. One going to the Leak Detection Pump (LDP)
      and one going to the Intake Manifold Runner Control Solenoid (IMRC).
      There are small orifices drilled into the plastic connection for these two lines. If these orifices should
      become plugged with debris, the following DTCs may result: P2015 for the IMRC vacuum line and
      P0455, P0442, or P0456 for the LDP vacuum line.
      Also TSB runner stick on all 2009 CCTA and CBFA engines TSB 01 08 32 Basically replacing the intake manifold for that fault code
      NEK '07 Chevy Crew Cab. Formerly CorradoG60
      '66 Impala 3 on the tree (sold)
      '09.5 G8 GT
      '74 F250 High Boy
    15. Member NEW2B's Avatar
      Nov 30th, 2006
      USA/SALONIKA
      09 GTI - 06 PASSAT
      03-13-2011 05:36 PM #15
      Quote Originally Posted by CorradoG602 View Post
      i have the same issues would i be able to check the line your talking about myself?
      if i can how would i find it?
      thanks.
      2009 GTI -APR K04 - USA, NJ SOLD
      APR GREECE SALONIKA!!!!!!!!!!
      2006 PASSAT-AUTO K04 -APR HPFP -KW V2- APR TBE- NS PULLEY VWR INTAKE--P3 BOOST GAUGE- BSH BLOCK OFF
      PLATE - LEVEL 10 TCU FLASH.-----Greece
    16. Member wolfsburg__gli's Avatar
      Feb 24th, 2009
      Orlando / Boca
      03-13-2011 07:13 PM #16
      could you seafoam the vacum lines to clear em out??
      IG @tbmikeeee
    17. n00b
      May 15th, 2009
      BOSTON, MA
      2009 Jetta Wolfsburg 2.0T
      03-22-2011 03:56 PM #17
      My 2009 wolfsburg MIL light just went off, firing code p2015. My car has 36 500 miles on it, wondering if anyone has had this fixed under the power train warranty.
    18. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      03-25-2011 12:19 AM #18
      Quote Originally Posted by robvan8 View Post
      It is covered under powetrain. I have yet to get it replaced (does not change driving at all) only cause they want to keep the car while part is on order, (3-4days) and they won't order the part till i drop my car of to have the work done. So Im waiting until I have another car to drive in interim whole manifold will need to be replaced. ECS sells the part for $200 if your'e out of warranty
    19. 06-12-2011 10:12 AM #19
      I just threw this code on my '09 GLI with 11K miles on it. Unfortunately the car has an R-title so no warranty coverage for me. I cleared the code after reading this thread, so we'll see if it's a persistent thing. I'm not familiar with ECS... got a link to the part?
      Thanks!
    20. Member LampyB's Avatar
      Apr 2nd, 2007
      Boston
      MKVI GLI + Rabbit
      06-12-2011 10:47 AM #20
      to the OP, how many miles are on your '09 GLI? you can just call VWoA and ask them what your current coverage is based upon miles on the car. if its under warranty just take it in to the dealer and thats it....
      2006 GLI / 2008 Rabbit - United Motorsports (used to be Flex Fuel)
      Quote Originally Posted by pete@blackforest View Post
      I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen?
      Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
    21. Member heimbachae's Avatar
      Apr 8th, 2009
      2013.5 GLI
      06-12-2011 10:53 AM #21
      my CEL went off at 41k and had the intake manifold replaced. just go in and make a stink, they'll replace it. just sucks being without car for a few days. if you search the TSI forum I think there is a thread on this issue.
      girls dig when i play with the V
    22. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      06-12-2011 02:10 PM #22
      actually, I took the car back in and they said that it was a sensor and not the manifold, but then I asked a VW tech and he said the entire manifold needs to be replaced. I've been dragging my feet on the whole thing. Tomorrow I'll be dropping the car off most likely
    23. Member
      Apr 21st, 2008
      Dayton, OH
      2009 GLI 6sp; 2009 Jetta 2.5 5sp
      02-02-2012 08:52 PM #23
      Quote Originally Posted by laramie1pt8t View Post
      Quote Originally Posted by onevrsix View Post
      Sorry to resurrect an old thread. But I just got the CEL (2009 GLI with TSI engine), and a VAG-COM scan shows the "008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal" fault.
      I cleared it yesterday, and it's back today. So I guess I'm going to be having my intake manifold replaced.
      The car's got almost 45,000 miles, so it's out of the bumper-to-bumper warranty.
      You guys are certain it would be covered under the powertrain warranty. But there are others, in other threads, who say that VW dealers have turned down this exact repair under the powertrain warranty.
      But I'm looking in the Warranty manual, and it does say that "manifolds" are covered as part of the powertrain. Since there are only two manifolds, that would seem to include the intake manifold, right?
      And they wouldn't be tempted to say, "Oh, the sensor's bad, but the manifold itself is just fine. Sorry"... would they?
      I'm just asking because I want to be sure before I take it to a VW dealer. I don't want them to take the car in, charge me a diagnostic fee, and then deny the warranty -- when I could have taken the car to my trusted independent dealer and have it done for less than VW -- but still a chunk of change.
    24. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      02-03-2012 09:40 AM #24
      Quote Originally Posted by Marek K View Post
      Hey man I originally posted this thread. So here is the deal. The reason the "sensor" fails or sends an implausible signal is because the vacuum actuated arm on the right side of the manifold has failed (or a portion of it has failed). Technically the manifold itself hasn't yet failed but it's only a matter of time before it does. The flaps are getting stuck and not moving causing the sensor to read incorrect signals.
      It's like schrodinger cat theory; you know/think it's covered but won't know until you take the car to the dealer to have it checked out. But yuo don't have to do it at the dealer, the indie shop should honor VW powertrain. I'd hurry though because if you bought the car used the powertrain drops to 50k miles and not the 60k that comes with the original purchase.
      Good luck; my advice it to take it in
    25. Member
      Apr 21st, 2008
      Dayton, OH
      02-03-2012 09:56 AM #25
      I called the new (for me) VW dealer to whom I'm taking the car this afternoon (I'm defecting from my old VW dealer.)
      I asked the service rep whether my TSI intake manifold would be covered under the powertrain warranty (60,000 mi, since I'm the original owner). He immediately said, "intake manifold flap, eh?" He added that it is covered.
      We'll see when I take it in.
      Technically, since it's all one piece now (sensor and flap, parts of the manifold), I would argue that the sensor or flap failing would mean the manifold has failed.
      Again, we'll see.
      First I've heard that an independent shop would honor a VW warranty. How would that work?
      Oh by the way, what exactly does the manifold flap do? And why does it lead to long-term damage (intake, spark plugs)?
