Page 21 of 27 FirstFirst ... 11 17 18 19 20 21 22 23 24 25 ... LastLast
Results 701 to 735 of 918
Thread: >> BAG RIDERS Deal Of The Month <<
  1. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-21-2012 11:13 AM #701
    Whats the switchspeed to e-elevel upgrade like? Just the ecu, controller, and sensors?
  2. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    08-21-2012 12:31 PM #702
    Quote Originally Posted by 98DUB View Post
    http://bagriders.com/modlab/products...GRADE-KIT.html
    This is hidden in the other parts under the accuair tab
    @gtijoey
  3. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    coal powered torque monster.
    08-21-2012 01:06 PM #703
    The SwitchSpeed to e-Level upgrade includes everything you'll need to make the switch:
    Sensors
    Wiring
    Hardware
    Although, due to the way AccuAir sells the kit, you will need to send them your controller and your ECU for reflashing. Their theory on the matter is that in the time it takes you to install the e-Level upgrade, they can reflash everything and have it back in your hands by the time you're ready to put the car on the ground.
    + Price of the upgrade is also dependent upon whether or not you already have the electronic pressure sensor
  4. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-21-2012 01:45 PM #704
    Quote Originally Posted by Andrew@ORT View Post
    Sensors
    Wiring
    Hardware
    So they can have the ecu and controller back in a day?
  5. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    08-21-2012 01:55 PM #705
    Highly doubt that and I've voiced that concern several times. This is why when we sell an upgrade kit we have a loaner ECU/touchpad that we send out. Granted, we do take a fully refundable deposit, but this way our customers are never completely down and out (no pun intended).
  6. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    08-21-2012 06:10 PM #706
    Perhaps not, but that's why we have loaner units
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  7. Member phil123's Avatar
    Aug 13th, 2009
    08-22-2012 03:19 AM #707
    If you drive down to them i'm sure they can
    2011 Golf TDI DSG | 2001 Cabrio VR-T | 1995 GTI VR6
    A2Resource |
    FS: Porsche Wintercults | MK3.5 Mirrors
    Aug 28th, 2011
    MD 21703
    08-22-2012 08:44 AM #708
    Quote Originally Posted by Will@BagRiders View Post
    How much pressure are we talking about here? Plenty of cars are a little off (5psi higher on one corner to get an even wheel gap).
    Only by about 5-10psi.
    My question about the v2 was since its pressure based how does it level the car out without knowing if the car is sitting the same height all around? It just evens the pressure out on all 4 corners correct? So wouldn't that make the car sit uneven if one bag needed less pressure to sit level?
  9. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-22-2012 01:58 PM #709
    Quote Originally Posted by harlequin80 View Post
    Lets say you are setting preset 1. The V2 saves a pressure value for each of the four corners of the car. If your car happens to be uneven when comparing the passenger side fender to ground height vs. the drivers side fender to ground height, when both front air springs have 55 psi in them, then you could take a tape measure out and dial them in to the exact same height be adding or removing pressure. (Keep in mind you should verify that both struts are installed correctly before resorting to this). Once the desired height has been reached, you would then save the preset.
    When you hit the preset 1 button, the AutoPilot V2 will return your four air springs to the pressures that you saved. Assuming you have the same load in the car when you hit that preset button, the heights at each corner of the car should be the same as they were when you saved the preset.
    Saving and returning to a preset needs to be done on level ground for maximum accuracy.
  10. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-22-2012 04:19 PM #710
    Quote Originally Posted by phil123 View Post
    That's one way to do it
  11. Member
    Aug 28th, 2011
    MD 21703
    08-22-2012 05:04 PM #711
    Makes sense but when someone said auto leveling I was thinking like e-level. That's what didn't make any sense is that it was said to level based on pressure. It's basically like Auto pilot then
  12. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-22-2012 06:36 PM #712
    Yeah it isn't auto levelling
    It has the function of preset ride pressures. I guess that would be the technical term there. Exactly the same as Autopilot version 1 but with a different controller, different control philosophy, different manifolds and more presets. But still the same theory of preset ride pressures
  13. Member
    Aug 28th, 2011
    MD 21703
    08-22-2012 08:40 PM #713
    Quote Originally Posted by MechEngg View Post
    Thats what I thought. Someone on the previous page made it sound like it was autoleveling but based on pressure not ride height which made no sense
  14. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-24-2012 09:27 AM #714
    Correct, the AutoPilot it doesn't 'auto level' per say. It will automatically reach the set pressures but pressures don't necessarily correlate to the vehicle being level. This is where the advantages of height based presets (e-Level) come in to play.
  15. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-25-2012 11:01 PM #715
  16. Member phil123's Avatar
    Aug 13th, 2009
    08-25-2012 11:21 PM #716
    Any sort of status on the touchbox for Android?
    A2Resource |
  17. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-27-2012 11:40 AM #717
    I last heard they would be released in early 2013. (Hopefully January).
  18. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-28-2012 09:27 AM #718
  19. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-30-2012 01:34 PM #719
    Our next deal of the month is about to be launched
  20. Member crispy21's Avatar
    Mar 26th, 2012
    somewhere lost in the dark pit of my endless thoughts
    Prev: 2008 United Grey GTI 6MT (Sold) Current: 2013 Toffee Brown Jetta SE w/ Conv+Sunroof Automatic
    08-30-2012 01:47 PM #720
    What is it? Deals on airhouse 2 bags and airlift fronr slam xl struts??
    Quote Originally Posted by MikeMeachum View Post
    Will there be a Jetta/ GLI VII thread? I got one.
    Wanna get scammed and recieve broken sh*t? Buy from Zach at BDA Industries.
  21. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-30-2012 01:53 PM #721
    Quote Originally Posted by crispy21 View Post
    Air Lift front Slam XL struts will be on sale along with several other products and kits. The AH2 bags will not be on sale.
  22. Member crispy21's Avatar
    Mar 26th, 2012
    08-30-2012 01:57 PM #722
    Cool thanks
  23. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-31-2012 07:42 AM #723
    Cool thanks
    No problem
  24. Member niles's Avatar
    Aug 6th, 2009
    Fairhaven, MA
    MKIVR32
    08-31-2012 07:15 PM #724
  25. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    09-01-2012 06:41 PM #725
  26. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    Mine: Bagged TR '11 GTI His: '08 WRX
    09-02-2012 12:46 PM #726
    Great deals as always guys. Glad I picked up my V2 kit couple months back during the deepest discount you've had on it since launch. Also amazing customer service/tech support from Will, Rali and team.
    BAG RIDERS | APRStage 2
  27. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    09-05-2012 11:14 AM #727
    Quote Originally Posted by dubb34r View Post
  28. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    09-25-2012 09:56 AM #728
    These setups will be in stock at H2O International in OCMD! See you there
  29. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    09-26-2012 03:49 PM #729
  30. Member 03_uni-B's Avatar
    Sep 6th, 2005
    Lexington, Louisville, Bowling Green, KY
    bagged 03 24v, 65 Mustang Fastback
    09-29-2012 12:48 AM #730
    ya, i really hope they will be running something similar in nov/dec. thats when i plan on buying.
    1965 Mustang Fastback build
    BUY MY BBS'S
    I really comes down to personal preference. Some like it fast, some like it slow.
  31. Member eurolicious's Avatar
    May 13th, 2009
    Grocery Getter
    09-30-2012 03:58 PM #731
    Quote Originally Posted by 03_uni-B View Post
    Same here
    Quote Originally Posted by dubvinci View Post
    liking/appreciating static is one thing, but to think its better that airride is a whole nuther story....better ride and handling while driving, more drivability, and looks better when parked....you might as well say its better to always have a hard on...id rather deflate it when im not using it and then pump it up when its time to go....lol...
  32. Banner Advertiser Rali@BagRiders's Avatar
    Nov 19th, 2010
    04 R32
    10-04-2012 03:47 PM #732
    Out with the old and in with the new!
  33. Member 03_uni-B's Avatar
    Sep 6th, 2005
    10-07-2012 07:00 PM #733
    exactly what i was looking for. should be ready to order late oct. hyped.
    BUY MY BBS'S
  34. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    10-08-2012 10:11 AM #734
  35. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    10-11-2012 12:41 PM #735
