VWVortex.com - 2007 Passat Wagon 2.0T oil leak
    Results 1 to 8 of 8
    Thread: 2007 Passat Wagon 2.0T oil leak
    1. Junior Member
      Aug 7th, 2007
      Magna, UT
      03-09-2011 03:52 PM #1
      Well my 2.0T (just over 50K) FSI is starting to leak some oil... enough to notice on the driveway.
      I am going to get it up in the air tonight and clean up the bottom / try to locate the cause of the leak.
      I ask all of you B6 2.0T owners - have you had an oil leak? What did it end up being?
      Thanks in advance.
    2. Junior Member
      Feb 2nd, 2011
      Humble
      2006 VW Passat 2.0T
      03-09-2011 04:04 PM #2
      Did you recently do an oil change. If so it may or could be the oil filter.
      Sep 29th, 2007
      Santa Clarita
      06 Passat
      03-09-2011 04:52 PM #3
      I had a oil leaking from the vacuum pump and the crankshaft sensor and valve cover. I think they all happened around when my PCV's have failed.
    4. Semi-n00b
      Feb 27th, 2011
      Jupiter, FL
      10 Passat
      03-09-2011 10:41 PM #4
      I had an oil leak I noticed on my drive way about 3 weeks ago. Before that happened I noticed 2 months before that I had a little oil on my valve cover in front of the oil filler neck that the cap is on. Cleaned it off didnt think much of it and it returned ( little bit) and cleaned it again. Well, 3 weeks ago my PCV was replaced. The oil leaked in to the 2nd from pass/side spark plug entry. Air pushed oil towards the back of the engine and the pass/side of the engine. Usually when the PCV fails the normal way the engine light comes and it runs very rough. The reverse effect is what happened to myself? The oil was likely being pushed out though the oil cap and the air will push the oil around the back. . Take the engine cover and look for these signs. Hope this is helpful...
      Nov 25th, 2008
      Bobruisk, Belarus
      07 Passat Wolfsburg / GLI VR6 / 13 Genesis Sedan 3.8
      08-22-2012 07:53 PM #5
      start having these issues with my car for few weeks now, if i replace my PCV system or get a catch can will this fix the problem with the oil being all over my engine?
    6. Member
      Mar 3rd, 2012
      Lyndhurst, NJ
      2006 Passat 2.0T
      08-22-2012 08:45 PM #6
      Quote Originally Posted by RedstarB6 View Post
      Make sure it's oil and not a leaking CV boot. I thought it was oil too, until I looked under the car.
      Nov 25th, 2008
      Bobruisk, Belarus
      08-22-2012 09:14 PM #7
      there is oil all over the top of the engine and the back of it toward passenger side, after i took the engine cover off i started to freak out. So def not CV. Still got warranty for another 40k miles, will be taking it to the dealer but if it only the PCV ill just get a catch can and call it a day
    8. 01-23-2013 04:15 PM #8
      2006 a4 audi 2.0t oil leak ----working on one now..got updated part# 06f 129 101n pcv vent
      looked sledged up pretty bad. idle was eratic.
      this was the fix this time good luck all!
      riverwest auto
      801 e. keefe ave
      milwaukee wi 53212
