VWVortex.com - Need Help: Gas Tank Door Won't Open
    Results 1 to 12 of 12
    Thread: Need Help: Gas Tank Door Won't Open
    1. 03-09-2011 11:03 PM #1
      Hello,
      Is there a manual release for the gas tank door of a Mk VI GTI? If so, could you please point me in the right direction?
      I tried restarting and turning off the engine, and unlocking all doors, but I don't hear a click for the gas tank door (which would normally allow me to push it in and swing it open).
      TIA.
    2. Member Feyd's Avatar
      Apr 1st, 2002
      Chicago
      2011 Golf TDI, 2012 Touareg TDI
      03-09-2011 11:26 PM #2
      Hmm..
      Ignition off
      Doors Unlocked (make sure you it it 2x so that it unlocks all doors)
      Push in and then pull open.
      If it isn't working like this, then you have an issue.
    3. Member Moltenburn's Avatar
      Jun 29th, 2010
      Denver
      2013 Platinum Grey Passat TDI SE 6-spd, 2013 Denim Blue Beetle, 1991 Inka Blue Cabriolet
      03-10-2011 12:02 AM #3
      If this does not work, you will need to get into your trunk and start removing the paneling behind the gas door. A million bucks says there is a remote release right there or you can even fix the issue you are having. Get some nice interior tools and get to work.
    4. Member Mo_Focus's Avatar
      Oct 9th, 2005
      2010 Golf Highline TDI DSG, 2011 Jetta Highline TDI
      03-10-2011 06:43 AM #4
      Quote Originally Posted by GTINC View Post
      If there was a remote release, why would it be hidden behind the truck lining that has to be removed with tools?
      I think he is talking about the emergency release. Not sure if you need tool to get at it thought! Maybe thats why VW gave you that screw driver
      i've heard some ppl mention the gas tank release was out of sequence. Test the door when the car is locked and then test it when the car is unlocked.
      10 VW Golf Highline DSG TDI- wife's , 11 VW Jetta Highline 6spd TDI mine!
    5. Member evosky's Avatar
      Feb 13th, 2010
      noVA / DE
      a van
      03-10-2011 10:01 AM #5
      i thought mine was broken once too. then i unlocked my car.
      but since you already tried that i am really at a loss. might be a mechanism failure.
    6. Member Custom158's Avatar
      Sep 3rd, 2006
      Manchester, CT
      2010 VW GTI 2012 Ducati Monster 696
      03-11-2011 02:03 PM #6
      bump for VW treating the trunk and gas cap as doors
      gotta just unlock all the doors for them to open... oddly enough you have to unlock all the doors for a VAG-Com to function properly. went bat sh!t crazy trying to figure out what was wrong until someone corrected me
      2010 CSG VW GTI 6MT - APR K04 v3.1
      Facebook | Micro CAN VAG-COM
    7. Member BOOGATA's Avatar
      May 2nd, 2010
      2010 GTI 2.0T
      03-11-2011 02:16 PM #7
      Quote Originally Posted by Custom158 View Post
      didnt know that, but may come in handy in the future
    8. Member Feyd's Avatar
      Apr 1st, 2002
      Chicago
      03-11-2011 06:54 PM #8
      Yeah I was after I had a couple "good" coding sessions and then I went to do it again and all of a sudden the module I needed access too wouldn't work.
      I found this burried somwhere in an FAQ, but it is the truth.. if your VCDS isn't communicating you might need to cycle the locks.
    9. 03-17-2011 02:11 AM #9
      Thanks for all your suggestions, guys. Believe me, I tried almost every combo of locking/unlocking all doors and hatch, to see if the fuel door would open.
      It turns out, it's a bad actuator. Got it replaced under warranty, and I'm now good to go.
    10. Member RogueTDI's Avatar
      Dec 12th, 2002
      USA
      2010 Golf TDI 4DR MT6 SB 1989 AW11 MR2 4AGE 150whp 2250lbs
      03-17-2011 03:59 AM #10
      Know how they got in there? They go through the hatch space trim/liner?? Good to know in an emergency.
    11. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      03-17-2011 10:23 AM #11
      That's only when you access 09 - Cent. Elect.
      OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
      Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
