Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 139
Thread: FS: Color Modified Interior Switches; Red, Blue, etc.
  1. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 12:56 PM #1
    Thats right, I've got your Red Lit Switches. These switches illuminate a nice red, slightly brighter than OEM cabrio switches (which i've also got). I also stock blue, and custom make other colors (see below).
    What If?
    - Your desired color is not listed? Please PM, Text or Reply to this thread. I will respond with an answer of availability as well as ETA for any supplies I may need to order.
    - Switches NOT in stock? Please PM, Text or Reply to this thread, I will give you an ETA on the switch conversion and pricing INCLUDING shipping.
    - The switch(s) you need are NOT listed? Please PM, Text or Reply to this thread. If I have them available, I will give you an ETA & Price, depending on quantity and availability.
    I will be stocking common switches in RED and BLUE, but have other colors that can be done.
    Available Colors:
    Red Blue Green UV RGB Color Change
    Stock Levels:
    Blank / OEM Green Switches:
    AC/Recirc: 11
    Defrost: 6
    Lock: 5
    R. Window: 3
    Heated Seat: 2
    Driver Window: 2
    Pass. Window: 10
    Power Mirror: 4
    Bubble AC: 3
    Bubble Defrost: 1
    Sunroof: 6
    Current Stock in RED:
    AC/Recirc: 1
    Defrost: 5
    Lock: 5
    Rear Window: 5
    Power Mirror (black/tan): 1
    2 Position NA Headlight Switch: 2
    Current Stock in BLUE:
    AC/Recirc: 2
    Defrost: 2
    Rear Window: 2
    Lock: 1
    I also have one SPECIAL set of 3 switches for $45 - These use special LED's to cycle colors, or if dimmed remain red. See video:
    Cabrio Switches: $15 ea, $20 for headlight w/o fog, $25 with fog.
    HL w/ Fog: 1
    HL w/o Fog: 1
    Hazard (see photo below): 2
    Rear Window: 2
    Defrost: 1
    Ac/Recirc: 1
    Heated Seat: 1
    HVAC Filter: 0
    Pricing: $15 each, $40 for any 3 dash switches. Higher quantity packages will be determined as they occur. Shipping INCLUDED in ALL stated or quoted prices!
    1. Ac/Recirc Switch
    2. Defrost Switch
    3. Lock Switch
    4. Rear Window Switch (dash)
    5. Driver Window Switch
    6. Passenger Window Switch (if a 4 dr, you need 3 of them)
    7. Power Mirror Switch
    8. Heated Seat Switch
    9. Sunroof Switch
    10. Bubble AC Switch
    11. Bubble Defrost Switch
    Headlight switches:
    • 2 Position w/o Fog - $15
    • 2 Position w/ Fog - $20
    • 3 Position w/o Fog - $20
    • 3 Position w/ Fog - $25
    To finish your interior dress up I have the following available: $10 each, or 25 for a set of the three!
    - Red Ring Cigarette Lighter: 5
    - Mk4 Gauge Needles: 7 sets
    - Aftermarket Antenna Adapter: 4
    Contact Info:
    PM or Thread Reply
    Matt @ 610-291-1270 (texts are unlimited and fastest contact method)
    Email: Slammedeuro@gmail.com
    Example Photos Of My OWN Jetta, in modified Red.
    Off:
    On:
  2. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 03:21 PM #2
    bump for blue swtches in stock
  3. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 07:12 PM #3
    you know you hate that piss green...
  4. 03-10-2011 08:24 PM #4
    email pics of uv please?
  5. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 08:30 PM #5
    Quote Originally Posted by Missnadia View Post
    ill post a picture here in just a minute.
    i can get PINK also
  6. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 08:37 PM #6
    Quote Originally Posted by BonusParts View Post
    i can get PINK also
    UV
    it looks awesome in person.
  7. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-10-2011 11:14 PM #7
    ttt
  8. 03-10-2011 11:15 PM #8
    i can get PINK also
    thx, but purple's my fav color.
  9. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 12:25 AM #9
    Yeah the UV looks good. Ran a set in the VR for a while, then I wanted closer to OEM and went red.
    I also have led's that will cycle colors infinitely as long as they are on
  10. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 11:42 AM #10
    bump ttt
  11. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 03:00 PM #11
    bump. full GTI set in blue lighting avail!!
  12. Member phil123's Avatar
    Aug 13th, 2009
    03-11-2011 03:23 PM #12
    You put the 3.5 hazard in your cabby?
    What color do they light up when activated, orange or the color that you change the switch to? I originally left the orange in mine and then after a little bit i couldnt stand the blue and orange so i put 2 blue LEDs in there.
    It's tedious work, but i'm alot more patient now, probably could do it without any issues
    2011 Golf TDI DSG | 2001 Cabrio VR-T | 1995 GTI VR6
    A2Resource |
    FS: Porsche Wintercults | MK3.5 Mirrors
  13. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 04:17 PM #13
    I actually had that in my jetta. Nreded to fill a blank spot haha
    Quote Originally Posted by phil123 View Post
    -Matt via tapatalk
  14. Member
    Aug 26th, 2007
    '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby "hers"
    03-11-2011 04:31 PM #14
    Interested! The door and dash switches black? Hit me up pm and I'll toss u my number we can talk I'm just outside reading pa may be able to pick up depending on where ur at
    Old user "sweetrocco420"
    It's gunna flip http://forums.vwvortex.com/showthrea...t-Build-thread
  15. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 06:37 PM #15
    Quote Originally Posted by sweetrocco420 View Post
    tXTD
  16. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 07:11 PM #16
    3 orders shipped today. cali, nj, montreal
  17. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-11-2011 10:45 PM #17
    Bumpp
    -Matt via tapatalk
  18. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-12-2011 12:36 AM #18
    bacvk up
  19. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-12-2011 10:05 AM #19
    Bumpybump
    -Matt via tapatalk
  20. Junior Member Dezzell's Avatar
    Mar 25th, 2010
    Nashville, TN.
    Mk3 VR6 Jetta
    03-12-2011 11:56 AM #20
    pm'd
  21. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-12-2011 01:32 PM #21
    Quote Originally Posted by Dezzell View Post
    pm'd
    Called!
  22. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-13-2011 03:07 AM #22
    Daylight savings bump!
    -Matt via tapatalk
  23. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-13-2011 11:12 AM #23
    bump
  24. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-13-2011 02:19 PM #24
    Bump, ive got more switches available....!! if you're local come on by and i'd do them on the spot.
  25. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-15-2011 02:22 PM #25
    Bump
    -Matt via tapatalk
  26. Member
    Sep 15th, 2010
    MN
    1998 Golf K2 2.slow4now
    03-19-2011 09:22 AM #26
    Can I get a sunroof switch modded with all red?
    Thanks
    Minnesota nice mixed with southern hospitality
  27. 03-21-2011 10:27 PM #27
    Still waiting on a response for my red lit ac/recirc switch.
  28. Member MYGTI_MA's Avatar
    May 3rd, 2010
    North of Boston
    1997 GTI 2.0 // 1983 Rabbit Diesel
    03-23-2011 06:55 AM #28
    yeah paid for a bwb sunroof on the 13th still haven't heard from Bonus or seen anything.
  29. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-23-2011 09:10 AM #29
    Yea I have not shipped the last couple things yet. Have been unable. If you can be patient and give me another day or so I can get it out.
    I was kicked outta my house by the parentals and just started a new job, and as I mentioned my car is down.... So ive been trying to sort my affairs out. So sorry for the inconvenience. Shoot me a pm and ill get back to you asap.
    -Matt via tapatalk
  30. Member MYGTI_MA's Avatar
    May 3rd, 2010
    North of Boston
    03-23-2011 12:19 PM #30
    no problem man as long as it shows before the 17th april I'm cool, I just hadn't heard anything and it wouldn't be the first time that i paid for something on Vortex and never gotten it.
    Sorry to hear about life kicking you in the ass hope things start getting better!
  31. Member
    Sep 15th, 2010
    MN
    03-24-2011 11:42 PM #31
    Hey man sorry to hear the news.
    Let me know when/if you can get around to modding a sun roof switch all red.
    Thanks
  32. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-25-2011 04:37 PM #32
    All parts pending shipping oughta be out monday. Booked at work today/tmw.
    I got my station all set up to make switches and I am accepting new orders again
    -Matt via tapatalk
  33. Member
    Feb 25th, 2010
    hicksville new york
    1994 vw golf
    03-25-2011 07:58 PM #33
    im gunna need some purple
    ill let u know which soon
  34. Member MYGTI_MA's Avatar
    May 3rd, 2010
    North of Boston
    03-25-2011 11:17 PM #34
    cool glad to hear you are back and settled as i feel you may have some business coming yourway if people like the blue white blue sunroof dealy.
  35. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    03-26-2011 09:43 AM #35
    Thanks. Im ordering more LED's. espcially for the sunroofs.
    pink should be in soon
