Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: All Motor 16v Build...now with real butter!
  1. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-10-2011 10:17 PM #1
    Will try to update as much as possible but at the beginning it's going to be kind of slow.
    So here we go.
    -16v 2.0 (I think) head; mild port by Russ Jr.
    -Supertech Valvetrain
    -ABA OBD1 block
    -ODB1 Knife-edged crank by Jarod @ SCCH
    -Balanced IM Shaft by Jarod @ SCCH
    -TT Hydraulic 298 cams (soon to have SCCH cam trigger)
    -Wossner 84mm 12.4:1 CR pistons (static CR should be 12:1 after build)
    -SCAT Rods (engine shop can't find them at the moment after moving )
    -Racecraft AE111 manifold
    -AE111 throttle bodies
    -Pipercross Filter & backing plate
    MS3/MSX from Paul
    4x IGN-1A coils near plug
    Little ITB teaser:
  2. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-10-2011 10:18 PM #2
    Update: Cams from TT arrived 03/08
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    03-10-2011 11:25 PM #3
    whut scch cam trigger??
  4. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-10-2011 11:28 PM #4
  5. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-11-2011 07:49 PM #5
    Quick pic of the Supertech valves before they go to the shop next week.
  6. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-12-2011 06:33 PM #6
    Update 3/12:
    Found out block is cleaned, bored to 84mm, and honed ready for assembly.
    Intermediate Shaft bearings came in today from GAP.
    Ordered some misc. parts from the dealer (discount because I work there )
    Oil squirters (expensive!)
    few bolts and washers
    couple woodruff keys
    All stuff from dealer should be here Tuesday.
    Also ordered intermediate shaft gear from Bahn Brenner.
    Ordered Techtonics Tuning valve guides and seals.
  7. Member Stussy NJ's Avatar
    Jun 28th, 2008
    Burlington NJ
    1987 gti 16v
    03-13-2011 08:57 AM #7
    what are you shooting for as far as numbers go, also what size valves did you go with? Been reading a lot of info on all motor 16vs and most optimal valve size is 34mm intake and 29.5mm exhaust. Either way looking forward to your progress, subscribed .
    Drive a VW they said, it'll be fun they said...
  8. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-14-2011 07:20 PM #8
    Update 3/14: Ferrea Spring Seats
    So, the head I got didn't come with spring seats. Ok, no big deal I'll order some fancy expensive Ferrea spring seats.
    They came in today.
    Outer springs fit perfect; inners not so much. I'll have to get my builder to shave a hair off the spring seat inner ring I guess.
    My fault for thinking Ferrea & Supertech parts could live in harmony.
  9. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    03-16-2011 01:30 PM #9
    Update 3/16
    Parts I ordered from the dealer came in.
    Oil squirter & bolts
    Cam bolt & washer
    IM shaft bolt & washer
    Crank bolt
    front water flange seal
    Front/rear main seal flange bolts
    Cam & IM shaft woodruff keys
    Have some stuff coming in tomorrow & Friday as well.
  10. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    89 GTI 90 Audi Coupe Quattro 06 Xterra
    03-25-2011 12:44 AM #10
    I look forward to see how this turns out!
    Flickr
    Quote Originally Posted by Mr. Knappy View Post
    We really need breeding standards like they have with dogs.
    Quote Originally Posted by pete@blackforest View Post
    I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
  11. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-07-2011 10:06 PM #11
    Update 4/07/2011
    Not much going on lately. Just been collecting parts the past 2 weeks.
    -Jarod @ SCCH has my cam trigger made & should be getting shipped out tomorrow.
    -Ordered the universal VR sensor from 034 Motorsport to go with the new trigger.
    -Shop still hasn't found my rods from when they moved. I think they're going to have to order a new set; on their dime of course.
    Hopefully by next week I should have some more solid updates.
  12. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-09-2011 06:13 AM #12
  13. Member 1983rabbitgti's Avatar
    Apr 3rd, 2004
    georgia
    88 16v 2.0 rocco
    04-12-2011 10:53 AM #13
    moar pictars
    sounding and looking good so far.
    Fur die Liebe des Fahrens. Nicht einen Schwanz zu werden
  14. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-13-2011 09:04 PM #14
    Update 04/13/2011: Shop has all parts now
    Dropped off everything I have left to finish the long block at this point.
    -Still have to order head gasket from Cometic
    -Timing chain & timing belt tensioner on order from GAP
    -Just got an update from 034 Motorsport that my VR sensor has been shipped
    Still on the list:
    -Header
    -ECU + wiring
    -Ignition coils + connectors
    -Slim fans
    -Water pump
    -Oil pump
    Also decided to build my own seperate relay/fuse box for everything engine related and use the factory box for everything else. More on that later on.
    Cylinder head notes after talking to the builder awhile today on air flow:
    -Going to have him work super hard on the valve throat area and get it up to about 90% the size of the intake & exhaust valves. This should increase my VE significantly along with the valve job he's planning on.
    -Larger valves would give me more flow but I don't have the time or money to drop into going bigger; atleast not yet.
    -He's also going to port match and blend the intake ports to match my RF manifold.
    That's it for now. More to come later.
  15. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-16-2011 08:37 PM #15
    Worked on the throttle bodies some today since I don't have anything else I can do right now.
    -Rustolem Engine Paint; Chrysler Red
    -Gaskets made between the ITB's and the manifold.
    I think they came out pretty good. Had to do two coats to get all the little spots covered.
  16. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-20-2011 03:01 PM #16
    Small update:
    -Decided to go with Lugtronic/VEMS for standalone. Have to get the approval from the wife to order soon.
    -Going to be sending off the exhaust cam + cap + trigger sensor so Jarod @ SCCH can do his magic. The engine shop isn't going to have time to get this done for me + they don't have the proper taps.
    -Builder should be getting to my head by Friday. Going to do the 3 angle valve job and surface the head, then give me a rough idea on the throats and see what he thinks he can do. Hoping to get some good flow out of this head.
    That's all for now. Lugtronic might be able to get ordered this weekend. Going to call Lugnuts before sending money to work out what I want.
  17. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-20-2011 03:37 PM #17
    At least you're going with Kevin and not something from left field
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  18. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-20-2011 03:41 PM #18
    Quote Originally Posted by need_a_VR6 View Post
    I had a long talk with Kris @ DRS about it. That system would have worked, but only with wasted spark + batch fuel. It was also maxed out on everything. No upgrade path and I don't know the software at all.
    To convert it for sequential fuel & spark it was going to cost just as much as the system to begin with.
  19. Junior Member
    Sep 27th, 2010
    Portland ME
    04-26-2011 08:35 PM #19
    What power goals are you shooting for with this setup? Looks to be very well thought out. Can't wait to see the final results.
  20. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-26-2011 09:22 PM #20
    Shooting for 200whp. Anything beyond I just hope it's at a safe level.
    So, ordered my TPS sensor for the throttle bodies. Turns out it was the wrong one. Shame on me for not researching the # more.
    89452-22090 fits some Toyota, Lexus. However it turns the wrong direction.
    89452-12090 is the one needed for the AE111 throttle bodies.
    So now I have a $127 TPS I can't use and Toyota won't take back.
  21. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-28-2011 07:39 PM #21
    Ok. Got the new TPS today. Denso 89452-22080.
    It fits the body housing perfect. However, it won't bolt up without being turned slightly. So that means the spring on the rotor in the sensor will always have tension on it. I suppose that doesn't matter really while driving. And the ECU can be adjusted for 0-100% throttle easily.
    More importantly it fits in the right position; meaning the connector points down, instead of up, which is nice.
    I don't have any bolts to mount but I can solve that this weekend and take a good picture or something.
  22. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-28-2011 07:59 PM #22
    On second thought, just so people know what I'm talking about.
    Sensor with zero rotor tension:
    Turned just enough to mount:
  23. 04-29-2011 10:34 AM #23
    What you have pictured is perfectly normal and what you want. If you were to mount it with no spring tension you could end up with a dead spot in the sensor that the ecu wouldn't be able to read. As you said the ECU will calibrate the tps sensor and will not be an issue.
  24. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    04-29-2011 06:01 PM #24
    Yea that's what I'm thinking too. The difference between both positions in very minimal.
  25. Member Mathew...'s Avatar
    Feb 22nd, 2009
    edmonton canada
    95 wrx, 82 rabbit, 83 rabbit-sold, 91 golf-parted, 88 jetta-killed, 91 jetta-sold, 01 jetta-sold
    05-01-2011 05:39 PM #25
    updates???? love your build
  26. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    05-01-2011 05:59 PM #26
    Not much to update.
    -Ordered the Pass Racing velocity stacks on Ebay.
    -Ordered AEM Long Pencil coil set.
    Bigger note:
    -I jumped on my engine builder's ass about not getting my stuff started. If he took anything I said seriously he should be getting started on the headwork Monday or Tuesday. Also, going to go over to the shop after work one day this week and make them find my rods. Been waiting a long time to start on this project and I don't need these holdups.
  27. Member Mathew...'s Avatar
    Feb 22nd, 2009
    edmonton canada
    05-02-2011 03:06 PM #27
    ****ty. I just bought some itbs so ill be watching this build verrrrry closely
  28. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    05-05-2011 05:10 PM #28
    Got the Pass Racing stacks in; also received the AEM Pencil coils, however ebay seller sent me the short version instead
  29. Member
    May 3rd, 2011
    Downtown, Bako
    E36 ///M3 + Mk2
    10-13-2011 08:13 PM #29
    subscribed!
    Shinin’ like a mother****er BBS' blingin' Steve Erkle bought a ton... -Dolla
  30. 11-01-2011 09:10 PM #30
    Updates???
  31. Member A3dOUde's Avatar
    Dec 22nd, 2002
    Canada
    11-14-2011 08:37 AM #31
    quite interesting build-up ! keep goin
  32. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    11-19-2011 04:19 AM #32
    Anything new?
  33. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    11-20-2011 05:32 AM #33
    Unfortunately not. Still out of work.
    Hoping to be back on my feet in December. Should be able to get back on this project in the new year.
    Cylinder head is, however, pretty much done. I haven't been to the shop in awhile so next time I visit I need to bring my builder some cash.
    Also, with recent events, I'm probably going to just have to run MS + AEM CDI for the AEM coils I have. My original setup was going to be Lugtronic + CDI. In any case, will have to see what happens in the next few months.
  34. Member 02vwgolf's Avatar
    Oct 6th, 2009
    SE-PA
    02 vw golf gls
    11-20-2011 09:45 PM #34
    Quote Originally Posted by VWn00b View Post
    Hope you get back to work soon, cant wait to see this build get back on track! Final result should be quite fun
  35. Member Dubrunner's Avatar
    Nov 8th, 2000
    Portland, OR
    01-22-2012 10:41 PM #35
    Nice to see another ae111 16v build! Great job! I have pretty much the same setup (minus cams) and got it running last May on Megasquirt. Only problem I've run into is the clearance to the hood. I couldn't fit a sausage filter on mine as it would foul the hood - so am still figuring that out - running 75mm T3 horns. I was thinking of buying the same stacks, but wasn't sure how that would effect the lower end. Of course, my setup is on a Mk2, so you might not have an issue with the Mk3 & hood clearance. Keep up the good work!
    WTB:
    Clean MK2 Golf small bumpers
    Black Carpet kit
    4pt. bolt in roll bar
    ^ Please PM me^
