Page 13 of 17 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 LastLast
Results 421 to 455 of 563
Thread: Meet Ellen the Jetta
  1. Member db3ck's Avatar
    Sep 2nd, 2011
    Flint, mii
    86 vw jetta 90 b3 wagon
    07-14-2012 02:25 PM #421
    its a pain trying to find anything for these cars ya some parts are pretty easy some websites make have alot of parks motor wise and all that stuff but its hard to find the little things
    Eva: 90 b3 wagon
    Whore: 86 jetta
    i my dubs
  2. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    07-14-2012 05:53 PM #422
    Those look like the vents from a US made car?
    A2Resource
    Nov 26th, 2001
    DC Metro
    '88 Jetta | '08 Cooper S | '10 Clubman S | '88 Ranger
    07-14-2012 06:14 PM #423
    Quote Originally Posted by db3ck View Post
    It *is* the little things man. It kills me. How's your Jetta coming along?
    Quote Originally Posted by VDub2625 View Post
    Yup. It's a US dash. The orig one was all cracked up, and I had this sitting around.
  4. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    07-14-2012 07:37 PM #424
    Sent from my SPH-D710 using Tapatalk 2
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
    Nov 26th, 2001
    DC Metro
    07-30-2012 11:51 AM #425
    OK, so I pulled the engine and some other bits I needed from the Audi, and a friend of mine came to pick up the rest of it this Saturday.
    I borrowed a fender roller from a buddy of mine, and rolled out the rear arches. That was a lot more work than I thought it would be, but I think I gained a few mm of clearance.
    Of course, while I'm down there, I notice that one of the bolts for the sway bar has been rubbing on the exhaust's over-axle pipe. I expect to have this exhaust for a while, so that just won't do.
    So, I bust out the sawzall. NBD, right? Wrong. Had to drop the axle a bit, and jack up the exhaust to get the effin sawzall in there. It's always something. Buuuut, I got it done. Hopefully shiz won't get any further scratched up.
    Got that crap all buttoned up, and went and did what any responsible adult would do... bought a truck! Mwuahahaha!
  6. Member
    Nov 26th, 2001
    DC Metro
    08-11-2012 11:43 AM #427
    Got some work done on the donor motor recently, and took a TON of photos so that I can remember where everything goes when it comes time to put it back together. I won't subject you to all that
    Anywho...
    Valve cover off:
    wtf?
    Cams out:
    All of the bolts in the head had schmutz in them, caked in. I had to clean each one out with a small screwdriver and then compressed air, and tap whichever tool into them to keep from stripping. Even then, the third head bolt in the sequence stripped out soon as I had some torque on it.
    So, I drilled at it for a while
    And then pounded a 12mm 12pt in there, and hit it with the impact wrench. Take that, f*cker!
    Head off:
    Yeah, that was a water passage way
    Valves
    I took the head, cams, cam caps down to my buddy Matt. He's got a lot more experience with these things than I do, and did a fantastic job on the head he built for my digi/aba Golf.
    There was some scoring on one of the cams, which he cleaned up nicely.
    Head went off for a hot tanking and was decked. 8 somethingths? I forget.
    There was still some random crud built up in some of the corners, so I went at that with a pick.
    Decked surface of the head:
    detonation marks (?) in combustion chamber for cyl 2 (or three?). Too deep to mill out without going over spec.
    Anyways, the valves were filthy, so I went at them with a wire wheel. (an oddly relaxing task)
    Huge improvement
    Matt started lapping in the fresh valves
    Manifred the Austrian came by, and decided that cleaning valves looked like too much fun, so he did a couple of them as well. Biggups Manifred
    Anywho, that's where I'm at. This engine building sh*t is a slow and expensive process, even when you have friends to help you out. Should all be worth it in the end. I just keep telling myself that ~250whp will be fun.
    Nov 26th, 2001
    DC Metro
    08-16-2012 05:25 PM #428
    After all the work to try to seal her up, I was pretty bummed when I drove back from SOWO and both the top and botttom of the windsheild were leaking. It sucks - the damn thing looked brand new!
    I called a shop local to me that's done some good work for us before, and dude was able to come on my day off - bonus. He got the old windshield out without breaking it, so it's available if someone wants it.
    Anyways. Pics.
    Windshield out. The window dude said that the old seal was done pretty sloppily, and didn't adhere properly. There were sections where his knife just went through with no resistance.
    Window channel looked pretty damn bad when the windshield first came out:
    But upon inspection, everything was solid, there was just some surface rust to take care of. This is the worst spot, right around the driver's side drain hole.
    So, I decided to clean it up a bit and Por-15 it. The guy was really easy to work with, and told me just to call back when I was done and he could come by after hours if need be to finish the job.
    He was nice enough to leave me a razor scraper thing so I could get any remaining glue out.
    All masked up, prepped, and Por-15'd
    It looks a bit sloppy in this shot, but none of it shows around the seal.
    New windshield in, and it looks fantastic.
    Yay!
  8. 08-16-2012 05:40 PM #429
    love the 1.8T
    loooks great
    Nov 26th, 2001
    DC Metro
    08-16-2012 05:50 PM #430
    Quote Originally Posted by 35i 2000 View Post
    love the 1.8T
    loooks great
    Thanks man! Wish the engine would just finish itself and hop the f*ck in there already!
  10. Junior Member
    Jul 21st, 2012
    Nashua, NH
    92 VW GTI, 98 VW Jetta
    08-16-2012 06:00 PM #431
    nice ride man
  11. Member TurboLover3's Avatar
    Oct 20th, 2003
    Gainesville, VA
    91 GTI, 03 GTI
    08-16-2012 07:55 PM #432
    I can't believe I've missed so much of your build! Shows me right for practically taking a year off from even thinking about MKII's She's lookin awesome
    Nov 26th, 2001
    DC Metro
    08-16-2012 07:59 PM #433
    Quote Originally Posted by ShawnOMV View Post
    nice ride man
    Thank you
    Quote Originally Posted by TurboLover3 View Post
    Thanks a bunch, Vic! She's getting there. I'm *really* tempted to buy some 195/45's and lower her a bit before H2O. Not sure it's all that logical to get rid of practically brand new tires though. I *might* have 3000 miles on them.
  13. Member TurboLover3's Avatar
    Oct 20th, 2003
    Gainesville, VA
    91 GTI, 03 GTI
    08-16-2012 08:10 PM #434
    Well chances are you could probably find someone to buy the tires you have. I mean 3k on them is still like new. You'll love the 195/45's if you do get them though.
  14. Member
    Nov 26th, 2001
    DC Metro
    08-16-2012 08:53 PM #435
    Hmm... Good point dude. I am gonna have to ponder this...
  15. Member db3ck's Avatar
    Sep 2nd, 2011
    Flint, mii
    08-16-2012 10:46 PM #436
    Quote Originally Posted by odj View Post
    Its at a stand still till i get a job so i can really do what i want to it instead of throwing it together, and i just bought a 90 b3 16v wagon and it needs new lifters so im getting the usrt lw ones and then once i have the money some street cams so i dont have to worry about the stock ones goin out anytime soon, but anywho great work on the car man that motors lookin good
    Eva: 90 b3 wagon
    Whore: 86 jetta
    i my dubs
  16. 08-17-2012 12:58 AM #437
    Nice work as usual!
  17. Member
    Nov 26th, 2001
    DC Metro
    08-17-2012 10:02 AM #438
    Ahh word, I saw your B3 thread. Good luck man... be patient and things will come together
    Quote Originally Posted by Moofluffen View Post
    Nice work as usual!
    Danke
  18. Member
    Nov 26th, 2001
    DC Metro
    09-05-2012 03:51 PM #439
    Truckin' along...
    Matt finished my head a couple weeks ago.
    High notes:
    Hot tanked
    decked .008"
    all new seals
    valves lapped
    cam to bearing cap tolerances checked and A-OK
    I parked the Jetta outside and found a little water under the driver's side mat - gotta check all my drains and my vapor barriers again.
    I bought a new head unit, should have it soon. Found a Pioneer DEH-80PRS for a great price, new. It'll do full active 3 way with auto EQ and TA, and it will color match its display. No more weird blue on my green dash!
    I'll be up at H2O to chill with the MK2 homies at the end of the month. Just going to do some little things between now and then to clean up and the like. Nothing drastic.
  19. Member TurboLover3's Avatar
    Oct 20th, 2003
    Gainesville, VA
    91 GTI, 03 GTI
    09-05-2012 09:14 PM #440
    Man that looks so good...
  20. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    09-05-2012 09:42 PM #441
    cant wait for h2o
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  21. Member karolgolf24's Avatar
    Sep 13th, 2008
    Hell, AZ
    89 GTI 16V ,92 GTi 16V,11 JSW TDI,87 Golf GL 8V, 87 GTi project
    09-05-2012 09:49 PM #442
    Nice job
  22. Member Gaets's Avatar
    Feb 7th, 2005
    Easton, Maryland
    1991 GTI 24v
    09-05-2012 11:52 PM #443
    Cant wait to hang out and drink some with the mk2 guys.
  23. Member
    Nov 26th, 2001
    DC Metro
    09-06-2012 01:53 PM #444
    It's (almost) all Matt... and the machine shop. He did a bang up (and really fast) job. I was expecting to have a few months before I got it back. So... nothing else is ready for the head.
    Block is filthy still. Haven't ordered any seals or even looked for parts I know I have. Oh well... after H2O I'll get my sh*t together.
    Quote Originally Posted by steveo27 View Post
    cant wait for h2o
    I think you can get Natty Boh in OC, but do you want me to pick ya up some regardless?
    Quote Originally Posted by karolgolf24 View Post
    Nice job
    Thanks!!
    Quote Originally Posted by Gaets View Post
    F*ck yeah!
  24. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    1992 12V 1992 16V 2012 TDI
    09-06-2012 02:11 PM #445
    Man.... the last 2 weeks have been so hectic.
    I got your text dude.... Gonna call those guys to make sure they are OK with it, and then should have a time and location locked in for the gtg.
    Natty Boh you say?! I'll have plenty of it at the condo.
    Tell your buddy I'm sorry I didnt get back to him.... like I said... crazy week!
    oh yeah.... head looks great too
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  25. Member
    Nov 26th, 2001
    DC Metro
    09-06-2012 02:44 PM #446
    No worries holmes. I just started school again this week, and am in training for the next couple of days, on top of regular work stuff. I'm feeling it.
  26. Member
    Nov 26th, 2001
    DC Metro
    09-23-2012 12:18 PM #447
    Got some work in yesterday, including what turned out to be a two hour oil change.
    Highlights:
    1: Fixed the leaky driver's side vapor barrier. Strip caulk is not a good solution for adhering the plastic to the door. The plastic pulled away in a number of places. Going to have to check the other doors and see how they're fairing.
    2: Lowered 1CM front, 1.5CM rear. No rubs! Might lower the front a tad moar.
    3: Q: How do you make a MK2 Jetta worth $33k? A: Put $30k in the trunk.
    I need to wash & wax before H2O. Otherwise not much is gonna happen before the end of the week.
  27. Member datenstrom's Avatar
    Mar 21st, 2001
    Louisville, KY
    Porsche 912, E30 325i, B7 S4, MK6 GTi, Volvo 245
    09-23-2012 03:06 PM #448
    Hit that drivers door trim with the heat gun. Also, please tell me you didn't leave that google appliance in your trunk overnight.
  28. Member
    Nov 26th, 2001
    DC Metro
    09-23-2012 03:09 PM #449
    Quote Originally Posted by datenstrom View Post
    I'm going to. I did once, but it didn't blacken up as well as the rest. Gotta scrub it really good first.
    Dude... I almost forgot about it. Went out just after dark and brought it in.
  29. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    09-23-2012 09:04 PM #450
    Ya can down there. WHen I was down there in July, we brought a few cases back
    Can't wait to hang out
    O/R/T
    We Do It Big In PA
  30. Member
    Nov 26th, 2001
    DC Metro
    09-26-2012 04:44 PM #451
    almost H2O time!
    This week can seriously go f*ck itself. I'm very much ready to get out and go chill.
    Anyways... got a couple things done to get ready for H2O.
    Before:
    After:
    I used some QD and a scotch brite pad to clean it up and hit it with the heatgun.
    Lookin better.
    Gotta hit 'er with a wash & wax Friday morning and then I'm off!
  31. Member db3ck's Avatar
    Sep 2nd, 2011
    Flint, mii
    09-28-2012 11:26 AM #453
    Looking good man
    Eva: 90 b3 wagon
    Whore: 86 jetta
    i my dubs
  32. Member datenstrom's Avatar
    Mar 21st, 2001
    Louisville, KY
    10-02-2012 06:49 AM #454
  33. Member
    Nov 26th, 2001
    DC Metro
    10-02-2012 09:22 AM #455
    Nice!
