VWVortex.com - door chime problem
    Results 1 to 18 of 18
    Thread: door chime problem
    1. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 02:38 PM #1
      i always have my interior light to go on when i leave a door open, or open my door when the car is off, etc. i left it like that last night, and all my doors were closed properly, i guess the light stayed on. i went to it a few mins ago and my door bell chime was going off even after i closed all doors, my light stayed on even all the doors were closed. then the light finally shut off after i opened and closed the door, but the door chime still kept going, is probably going right now as i type..but its not at its full volume, its almost like its muffled, and the sound 'cracks' a little. but it wont stop even after i start the car. this happens when i just put the key in, it goes even when i dont have it in the 'start' position....any thoughts on what happened?? im probably gonna need a new battery anyway lol but why is the door chime still going??
      May 8th, 2010
      Riverside, CA
      97 GTI VR6
      03-14-2011 02:48 PM #2
      Something similar happened to my car when it was my dads. He said the little cover that goes over the switch in the door jam broke thats supposed to make the light turn off. And he said the door chime wouldnt shut up. So he took the chime out but now when you open the drivers side door the light wont turn on, but it will if you open the passenger side door. Id like to know why it does that also.
      Quote Originally Posted by vento86 View Post
      Welcome to the vortex, where we smash all of your hopes and dreams.
      Jun 4th, 2005
      Milwaukee, WI
      2008 Rabbit (Previous: 1998 GLS, 279,000 miles)
      03-14-2011 02:48 PM #3
      Sounds like the door switch is sticking/on it's way out.
      Edit...after re-reading that the chime stays on even once the light's out, not sure man.
    4. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 02:53 PM #4
      yeah the light started turning off now i think, but the chime is still going, very faint, but you can hear it. and there's kinda static coming out of the speaker or whatever with the sound...
    5. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 03:32 PM #5
      where's the door switch located? gahh, time to whip out the bentley and see if i can find anything...
    6. Banned toothpick's Avatar
      Dec 31st, 2009
      CT
      94Lb6T2.0, 95B4vr6wagon, 97mk32.0, 98mk3VR6
      03-14-2011 03:35 PM #6
      door switch is in the door jamb. ( on the lower part for the B pillar )
      it's under a little rubber boot near the white sticker with your car's build date on it..
      you don't need a Bentley to find this.
    7. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 03:40 PM #7
      oh ok i know where that's at lol...the real problem here is the annoying door chime that keeps going. its a very faint sound but keeps going even if the car is on
    8. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 04:57 PM #8
      so i found out its the door jamb switch...even when my door is closed, its like the switch gets caught and the door chime still goes off...but i opened the door while my car was on, and pressed it down with my finger, and the door chime still goes off...how do i disable the door chime???
      May 8th, 2010
      Riverside, CA
      97 GTI VR6
      03-14-2011 05:06 PM #9
      yank that sh1t out
    10. Member
      Feb 7th, 2006
      1995 VW Golf 2.0L, 1998 VW Golf 2.0L, 2011 VW Golf TDI
      03-14-2011 05:08 PM #10
      You can try unplugging the door jam switch, and that will eliminate that as a problem. I removed my door chime a couple years ago when I was trying to find a loose connection to the stereo. To this day its still sitting in the drivers side door...
    11. Member VasDrafts's Avatar
      Apr 23rd, 2004
      610 PA
      2 Jettas
      03-14-2011 05:08 PM #11
      go to the junkyard
      pay the man behind the window $2
      Pocket several of those switches
      Replace your switch
      You even get spares outta the deal
      You don't have to thank me
    12. Semi-n00b
      Aug 16th, 2010
      Kent, WA
      98 Jetta K2
      03-14-2011 05:11 PM #12
      Had the same problem. Replace all the door jamb switches and you'll be fine!
    13. Banned toothpick's Avatar
      Dec 31st, 2009
      CT
      03-14-2011 05:12 PM #13
      the door switch is telling the door chime that the door is open.
      solution, replace the door switch. problem solved.
      it's either the switch, or the wiring from the switch to the fusebox which is pretty easy to access.
      Alfredo, how did you get to 2000+ posts and not come across this info before?
    14. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 05:15 PM #14
      Quote Originally Posted by toothpick View Post
      dude im asking myself that same question haha
    15. Member Mk2-Dub-GLI's Avatar
      May 25th, 2006
      Brampton
      '91 GTI '12 Focus Titanium
      03-14-2011 05:27 PM #15
      Quote Originally Posted by 97Ginster View Post
      yank that sh1t out
      most useless relay ever
      -Dave
      Life Is Short So Grip It And Rip It.
      Quote Originally Posted by D_B_Jetta View Post
      Oops, sorry, The 15% off Promo Code: CANIHAVE15%OFFCUZIDRIVEAVWANDIMHELLABROKE
    16. Member jwill187's Avatar
      Apr 5th, 2006
      RIP LC6U MK3, RIP LG7X MK3, 2013 Silver 2.5 grocery getter
      03-14-2011 05:34 PM #16
      "What does Marcellus Wallace look like?"
      http://creativeregiment.blogspot.com
      Quote Originally Posted by rubbinNdubbin21 View Post
      I know you just picked up the car, and are new to the game... but please re-read the title of this thread again, and compare the other cars in here, to the nonsense you just posted
    17. Member
      May 8th, 2010
      Riverside, CA
      97 GTI VR6
      03-14-2011 05:41 PM #17
    18. Member Alfredo_mk3's Avatar
      Nov 6th, 2008
      Tukwila, WA
      99.5 VW Golf
      03-14-2011 06:17 PM #18
      blahaha yeah i've seen that
