VWVortex.com - Best Oil: 2006 Passat 2.0T
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: Best Oil: 2006 Passat 2.0T
    1. 03-14-2011 03:13 PM #1
      What type of oil does VW recommend to be used on this engine?
      What oil does everybody else use and how successful have you been with it? What do you recommend for use? I just bought a used 2006 Passat 2.0T @ 70,000 miles. Not sure exactly what synthetic blend was being used. I was going to switch to the Mobil 1 Full Synthetic 10W30. Is this the best oil that I can put into this engine?
      Feb 19th, 2011
      Midvale Ut
      83 rabbit convertible 05 4runner
      03-14-2011 03:34 PM #2
      my vw eats full synthetic castrol 5w40. thats what the dealership recommended to me. mines got 83k
    3. Member xen6's Avatar
      Apr 13th, 2006
      2012 Golf R
      03-14-2011 03:50 PM #3
      Mine eats Castrol Syntec 5w40 like it's going out of style as well. 120k KMs on the clock.
    4. Member
      Mar 29th, 2008
      Villas, NJ
      '10 B6 2.0T
      03-14-2011 04:01 PM #4
      Mobil 1 0W-40, never lost a drop of oil with 72,000 miles APR Stage 2
      2010 B6 White Gold Metallic DSG
      Clear Corners, Badgeless Chrome Grille, 5% tint.
      Micro-CAN VAG-COM in Villas, NJ
    5. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      03-14-2011 05:28 PM #5
      Mobile 1 0w40 with a bottle of lubro moly mos2 friction reducer
      07 B6 Passat 2.0 turbo - http://unitronic.ca Unitronic Stage 2 HPFP - High flow cat downpipe 3" - ABD Racingwerks intake Stage 2 - HPFPUpgrade.com Stage 1 HPFP - 142 Bar fuel Pressure relief valve - 5 zigen Oil catch tank - Autotech 3" catback - Adams Rotors - H&R Springs teamed with Bilstein Sports.
      http://i51.tinypic.com/153w51g.png
    6. 03-14-2011 05:41 PM #6
      I think the damn dodge dealership i bought the car from put some kind of blend in. They had it for less than 48 hours when i bought it off them. I need to change it ASAP. I did check my oil level after 2000 miles on the blend and it had not dropped at all. is it the castrol that might be the cause? has anybody had the same problem with a 0w40 of another brand like mobil 1? or is it just the oil type that cuses this?
      Also, the lubro moly, is that necessary with a non chipped car?
      Sort of off the subject. Would anybody suggest using any addetives oil/gas/whatever to clean whatever gunk may be existent from the previous owner? what sorts of things would be worth the money? what would you reccommend? (I already use the BP or Chevron with addetives for the gas as often as possible)
    7. 03-17-2011 09:59 AM #7
      is it alright to mix a 5w-30 with 0w 40 ? the workshop recommended me Ravenol
      http://www.ravenol.de/products?part=402
      but after 2000km of running on it, i see there is quite a drop (30% from the max point).
      my car just clock 33000 km now in total..
      i think that is very weird...
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      03-17-2011 11:37 AM #8
      I run 5w40 syntec and I eat about 1/2-3/4 oil every 5,000 miles. It will eat it more if I drive it really hard.
      Mar 29th, 2008
      Villas, NJ
      '10 B6 2.0T
      03-17-2011 03:14 PM #9
      It is natural for oil to burn off in a turbocharged motor because of how hot the turbo gets. If you drive your car hard, especially with constant RPMs in the 5000+ range, you will burn oil. I haven't lost any oil yet. And I went 10,000 miles for the first change.
    10. Member ichiban5's Avatar
      Oct 8th, 2003
      Centreville
      2006 Passat 2.0t
      03-21-2011 05:31 PM #10
      first change was done by the dealer. Second, I believe i used Mobile 1. I just stumbled upon Rotella 5w40 synthetic so i'll be trying that tonight when i get home.
    11. Member
      Feb 18th, 2002
      Bel Air, MD
      2010 Passat
      03-22-2011 03:19 PM #11
      Official VW oil list - all are great oils
      http://dl.dropbox.com/u/17228246/oiltsb.pdf
      2010 Passat Comfort
      Full Vag-Com Service for
      Dec 14th, 2003
      Thrashville, NC
      04 GTI VR6, SOLD 82 Cabby, SOLD 08 Passat Wagon TSI, RIP 91 BSI Racing Built GTI
      03-23-2011 11:40 PM #12
      That list does not include Amsoil. They are an American oil company and engineer to euro spec. In use it in some form or another in all my cars and bikes. It's a little more pricey but extends change intervals and has worked for me. Keeps engine temps a bit cooler as well.
      Everything you can imagine is real.
    13. Member Blue Flame's Avatar
      May 27th, 2001
      Canuckada
      1997 BMW M3, 2010 Ford Flex
      03-24-2011 02:33 AM #13
      Total 10w30. Don't burn a drop. Stage II.
    14. Junior Member
      Jun 13th, 2012
      Pittsburgh, PA
      2006 Passat 2.0T FSI Uni Stage II
      01-31-2013 04:23 PM #14
      what about 0w-30 ?? Is that gonna mess #@$# up I live in pittsburgh, pa. Gets pretty cold in the winters and can get hott in the summers but usually more mild.
      I been goin with 5w-40 but not sure if i'd be a total dumbF by changing to 0w-30.
      i drive it pretty hard but i'm mostly 4 grand rpm average. I barely ever red-line and occationally go into the 5,000 rpm if i get pissed at the dilly-dalliers on the highway
      no one else ever has anywhere they need to be on time i guess..
      i already use castrol edge 5w-40 but am thinkin about liqui-molly synthoil longtime plus 0w-30
    15. Member
      Jan 6th, 2012
      2006 VW Passat 3.6 VR6
      01-31-2013 04:51 PM #15
      For the 2.0T, you need to stick with VW approved oils, which ever is the latest specification. I think 504.00 is most common.
    16. 01-31-2013 07:02 PM #16
      Once out of warranty, lots of people have reported using Shell Rotella T6 5w40 full synthetic ($21.59/gallon at Walmart) with reduced oil consumption as compared to the VW 504 oils. Have used the T6 myself for years in assorted VW's and Volvos.
    17. Member B6REDHELL's Avatar
      Nov 19th, 2008
      Nashville TN
      2008 PASSAT
      01-31-2013 08:19 PM #17
      Quote Originally Posted by n3on3m0 View Post
      German Castrol 0W-30 is group 4 Oil and is superior to all oils mentioned above. If you look at bottle it says made in germany, not new jersey like other castrol oils. I have used since 15K miles now over 50K miles and zero cam follower wear, no gunk on intake valves, and minimal consumption..
      I see you are interested in liqui-molly 0w-30. I don't know much but look like is euro spec oil...
    18. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      01-31-2013 08:53 PM #18
      Quote Originally Posted by B6REDHELL View Post
      Follower wear will happen no matter what the oil is like, if your stock then the follower generally lasts pretty well 50k-70k+ miles. Carbon build up on the valves will happen also no matter what oil.... its a direct injection issue. The oil vapor will bake to the valves
      Sent from my Galaxy SIII
      Unitronic Stage III w/ PT5558BB Turbo Unitronic.ca, IE HPFP, 3in B&B TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC/Forge SS, 42Draft Design CNC Shifter bushings, BFI stage 2 motor/tranny mounts, 034 Dogbone, KW V2 coilovers, Nuespeed 25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
    19. Member
      Feb 13th, 2009
      Ontario
      2007 2.0T, 6MT, shadow blue Passat wagon
      01-31-2013 09:18 PM #19
      I get my changes at Mr. Lube, so it seems to go back and forth between Castrol and Motul.
    20. Member B6REDHELL's Avatar
      Nov 19th, 2008
      Nashville TN
      2008 PASSAT
      01-31-2013 09:23 PM #20
      Quote Originally Posted by Bill6211789 View Post
      You are right. It will happen. But with conventional oil, It will happen a lot sooner. I know you are very active here on vortex and you know this. Dino and some syntetic if you wanna called oils bake sooner creating asphalt like sludge and stick to valves, and there is no proper lubrication. No explanation needed, You know this better than I do Bill...
    21. Junior Member
      Apr 30th, 2012
      2006 Passat 2.0t FSI, PCV Fix, Rev D diverter, BSH dogbone. 3'' DP, OEM replacement clutch w/ SMFW
      01-31-2013 10:37 PM #21
      Quote Originally Posted by claudio12401 View Post
      I too use Mobile1 0w40. Burns maybe 1/3 of a quart every 7000 miles. Not bad at all.
      2006 Passat 2.0t FSI, PCV Fix, Rev D diverter valve, BFI dogbone
    22. Member
      Sep 29th, 2012
      Philly
      2007 Passat 2.0t
      01-31-2013 11:08 PM #22
      I burn 1 qt of Mobile 1 0-40 every 1000 miles.
    23. Semi-n00b
      Oct 11th, 2014
      San Diego Ca
      2008 VW Passat Lux Wagon
      12-17-2014 01:28 AM #23
      I too burn about 1+ qt every 1000 miles. So not used to this. Only 96K on car.
    24. Member
      May 20th, 2013
      06 Passat, 04 F150, 04 Expedition
      12-17-2014 10:27 AM #24
      I use pennzoil euro spec, I only go through about a quart between 5k oil changes.
      Quote Originally Posted by spitfirevr6 View Post
      I don't know what to think anymore after nemo played with my emotions.
    25. Member toplessvw's Avatar
      Jul 31st, 2003
      Calgary, Ab.
      03 Jetta GLI , 07 Passat
      12-17-2014 10:28 AM #25
      I use liquimoly 5w-40 synthetic german blend that is vw spec and I do not burn a drop of oil between changes. I have used mobil 1 but always saw oil loss between changes.
