Results 1 to 3 of 3
Thread: How to attach breather hose to crankcase?
  1. 03-16-2011 01:33 PM #1
    The old "breather hose" on my Canadian 1995 Mk3 VW Golf GL became cracked and fell off. I bought a replacement tube, which connects to part of the PCV apparatus on top of the engine via a hose clamp, but it is not clear how it is meant to attach at the bottom of the engine. There must be some kind of clip that I need -- how can I find the part number and order it?
    Here is a photo of the engine compartment, with the tube in question outlined in red:
    And here is a close-up of where it should connect to the engine at the bottom:
    How should the tube be secured? (Where can I order the appropriate fastener, and what is the part number?)
    Also, anything else I should do while replacing it? (clear out crud from the port?)
  2. 03-16-2011 02:13 PM #2
    GAP has the part: It's the clip at the bottom of the list.
    Make sure there isn't any broken-off pipe still in there. Probably wouldn't hurt to clean it out a bit, but be careful since it goes right into the crankcase.
  3. 03-16-2011 02:16 PM #3
    Perfect, thanks!
