Results 1 to 26 of 26
Thread: When shifting into 1st or reverse...
  1. Member John2.8GLI's Avatar
    Jan 15th, 2008
    Ridley Park, PA
    2003 GLI 2.8 6speed Manual, 2009 CC 2.0T 6speed Manual-Stage 1+2 APR Intake-3" DP
    03-16-2011 01:36 PM #1
    When I'm shifting the car into first or reverse (6MT) as I'm letting off the clutch and applying the accelerator I hear a weird rubbing metal noise, is this the release bearing in the clutch system???
    I dont want to take it to the dealer because I know they won't here it...
    Also I hear a knock from the back tire right after I hear the metal rubbing noise...
    Any ideas fellow dubbers????
    Jun 10th, 2008
    Tappan, NY
    2010 VW CC Sport 6MT. VAG MODS, 5K HID KIT, FORGE SHORT SHIFTER
    03-16-2011 01:43 PM #2
    that doesnt sound normal to me...its best to take it into the dealer and have them check it out.
    Make sure you come to a complete stop when shifting gear into reverse.
    2010 VW CC Sport 6MT White Gold / Cornsilk Beige
    2000 VW Passat GLX V6 Auto Silver / Black (her ride)
    Previous:
    2008 VW Passat Turbo Auto (Bone Stock) Candy White / Black (Gone)
    2004 Audi A4 3.0 Ultrasport 6MT Arctic White/Black (Gone)
    Oct 6th, 2010
    Philly 'burbs
    Mocha Anthracite Metallic 2010 CC Sport 2.0T 6M, Nocturne Black Metallic 2010 Routan SE w/RSE/Nav
    03-16-2011 01:43 PM #3
    Auto Hold?
  4. Member sfccryder's Avatar
    Nov 24th, 2009
    Castro Valley, CA
    2010 VW CC Sport 2.0T 6M
    03-16-2011 02:19 PM #4
    Quote Originally Posted by 10CC View Post
    Auto Hold?
    try disengaging the auto hold and see if that helps.
    also if you are at a stop and have engaged the emergency brake
    button, if you are properly strapped in your seat belt, you can
    drive off or reverse and the e-brake will disengage. when it does that
    you will hear the e-brake release, it is a very noticeable metallic sound.
    Island Gray Metallic 2010 CC Sport 2.0T 6M, APR Stage1, R-Line Sport Pedals, HTTRS-256-MA:M
    235/35/19 Hankook Ventus V12 K110's, Borla CBE, Koni ss coilover kit, Adams slotted/drilled rotors, with Stop Tech pads.
  5. Member TJEli's Avatar
    May 15th, 2009
    Iron Mountain, MI
    11 CC Sport 6MT
    03-16-2011 02:30 PM #5
    I remember when we got our 1st VW (MKV Jetta) I asked about a strange "not smooth" feeling when letting the clutch out to first get rolling. I don't remember exactly what the answer was but it had to do with the design of the pressure plates and was normal. Our CC is the exact same way.
    -Eli
  6. Member
    Mar 22nd, 2008
    Toledo, OH
    2011 CC Sport
    03-16-2011 05:04 PM #6
    Quote Originally Posted by sfccryder View Post
    Thats what I was thinking.
  7. 03-16-2011 06:36 PM #7
    I'm thinking you are hearing the Auto Hold release as well. If it's off and you still hear it, then I would take it in as that does not sound normal.
    Good luck.
  8. Junior Member
    Dec 28th, 2009
    2010 VW CC, 1964 Mercedes Benz 230SL
    03-16-2011 07:56 PM #8
    To the OP this exact thing happened to me. I took it to my dealer they said after several times of bringing it back in they said my flywheel and clutch was shot! I had to argue for my life letting them know that it was some defect my car had only 13k on it. After I pulled some connections they said they had a specialist who was coming into town and he would look at it. They determined that the flywheel may have been a defect but they wouldnt not cover the clutch. Im only 20 and obviously didnt look like a someone who was very credible so they made me pay for a new clutch at 13k and I dont launch my car cuz all it does is peel out! If your situation is the same as mine say it is 100% factory defect and both parts need to be covered! I hope you had better luck than I did.
  9. Member John2.8GLI's Avatar
    Jan 15th, 2008
    Ridley Park, PA
    03-17-2011 10:40 AM #9
    Well I know it's not the auto hold or e brake, cos the e brake makes that transformer sound, like my car is about to turn into an auto bot... and I know its not the auto hold because its rare when I wear my seat belt, and auto hold wont engage with seat-belt not on. The reason I think its a clutch component issue is because from a complete stop I'm slowly coming off the clutch pedal and engaging the accelerator, from a complete stop, and until the clutch is fully disengaged the sound stop, same with reverse, every other gear sound good though. and Its only happening from a complete stop, but I have to do inspection and emissions at the end of the month so I guess Ill have the dealer check it out, hopefully I can get a free clutch system out of them
  10. Member TJEli's Avatar
    May 15th, 2009
    Iron Mountain, MI
    11 CC Sport 6MT
    03-17-2011 11:26 AM #10
    When did this start?
    -Eli
  11. Member
    Jan 30th, 2009
    MA
    Too many
    03-17-2011 11:12 PM #11
    Hmm, which is worse, not wearing a seat belt or having auto hold on, AT ALL !!!
    2011 CC Sport 6SPD MT Candy White with 4 holes in front.
  12. Member gtitrini's Avatar
    Jun 8th, 2006
    Boynton Beach, Fl
    2012 Lexus IS 250 F Sport
    03-17-2011 11:23 PM #12
    Quote Originally Posted by mswlogo View Post
  13. Member John2.8GLI's Avatar
    Jan 15th, 2008
    Ridley Park, PA
    03-18-2011 04:20 PM #13
    It started around 29000 miles...
    Well sometimes I dont wear my seat belt
  14. Member CobraKing's Avatar
    Feb 15th, 2010
    Canada
    04-14-2011 10:41 AM #14
    OP, please check out the link below, it's more than likely your Throwout Bearing - get it fixed under warranty ASAP:
    http://forums.vwvortex.com/showthrea...rp-squeak-hooo
  15. Member John2.8GLI's Avatar
    Jan 15th, 2008
    Ridley Park, PA
    09-22-2011 11:40 AM #15
    It definitely is the TOB, not because I took it to the dealer, but because my mechanic friend, as soon as he heard it, that's what he said it was, and then he drove it and then said he is 100% sure that's what it is, so, I get to take a trip to VW soon and get it fixed...Under Warranty Im hoping!!!!
    Thanks for all your suggestions and help everyone!
  16. Member rabbit07's Avatar
    Feb 22nd, 2007
    Frederick, MD
    09-22-2011 01:01 PM #16
    yeah mine started to do it as well and I'm only at 18k miles.
    gone: 07 Rabbit, 07 A4, 08 R32, 10 CC, 81 Rabbit
  17. Member John2.8GLI's Avatar
    Jan 15th, 2008
    Ridley Park, PA
    09-28-2011 07:38 PM #17
    Damn TOBs!!!! I here that the part is fine, but annoying, and if your VW dealer/,mechanic that is going to do it under the warranty and see the slightest bit of abuse
    (a little harder than everyday driving) they will charge you for dropping the trans and all that fun labor that doesn't even involve replacing the part....
    So0o0o0o0o0o0o0o what I plan o do is, stock clutch kit comes for $700-$00, rather than put another stock clutch in there, I'm just going to go with southbends Stage II daily for an extra $150, and the guarantee that it will last with the chip set I'm going for.
  18. Member UMJonny's Avatar
    Dec 6th, 2009
    Kissimmee, FL
    09-28-2011 09:28 PM #18
    Mine does the same thing. It only seem to happen when the car is cold though.
    How the hell can you recreate this and convince the dealer to fix it?
    2002 Egg Yolk Ford Focus ZX3: first car, sold.
    2010 Deep Black w/two tone CC Sport Manual: Current car, no mods yet...
    2001 Ford F150 SCrew Lariat, gas-hoggin beater...
    GO CANES!!!!
  19. Member rabbit07's Avatar
    Feb 22nd, 2007
    Frederick, MD
    10-17-2011 01:03 PM #19
    took my car in for its 20k service and told them about this problem. they called me and said they could not duplicate the sound. I told them I want to drive with the tech so when I got there I took it for a spin in the parking lot and was able to duplicate it. then we got the shop foreman in the car and then he heard it. now its back in the air and they are taking apart the trans and calling VWOA to see if it will be covered under warranty. wish me luck.
  20. Semi-n00b scott508's Avatar
    May 11th, 2011
    MA
    2010 VW CC Sport
    04-30-2012 12:24 PM #20
    Just brought my car in and there is a new TSB for this issue. It was just put out on 4/26. If I remember correctly they have to replace a spring assembly and something else. According to the dealership there are only 2 replacement parts in the US and I'm getting one of them.
    I don't know what the TSB number is but will post it when I pick up my car tomorrow and get the invoice.
  21. Junior Member
    Apr 23rd, 2012
    '09 VW CC Sport
    04-30-2012 12:48 PM #21
    Can this happen with an automatic as well? Sometimes when i backup in my car i hear a sound, it almost sounds as if the windsheild wiper was rubbing, like a rubber sound. I only hear it for a split second.
  22. Semi-n00b scott508's Avatar
    May 11th, 2011
    MA
    2010 VW CC Sport
    04-30-2012 01:27 PM #22
    Quote Originally Posted by jonyCC View Post
    Probably not, it's an issue with the clutch on the manual.
  23. Junior Member
    Apr 23rd, 2012
    '09 VW CC Sport
    04-30-2012 01:29 PM #23
    Great thanks for that. Now I wonder what that sound is. Maybe it is the wiper rubbing somewhere.
  24. Semi-n00b scott508's Avatar
    May 11th, 2011
    MA
    2010 VW CC Sport
    05-01-2012 06:21 PM #24
    So the TSB is 2028783. The cause of the noise is the clutch hub spring. According to my invoice they removed and replaced the clutch assembly. So far the noise is gone and hopefully it stays that way.
  25. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 06:30 PM #25
    I wonder what years that applies to?
    2013 VW
  26. Semi-n00b scott508's Avatar
    May 11th, 2011
    MA
    2010 VW CC Sport
    05-01-2012 06:36 PM #26
    I think they said 10-12 but I could be wrong.
