Results 1 to 8 of 8
Thread: Turbo return oil line
  1. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    Why don't you take a seat over there
    03-18-2011 10:36 PM #1
    Considering the high cost of a stock replacement i went searching around for another alternative. What are you guys running other than stock for the line?
    I'm looking at something like this. Any comments?
    http://cgi.ebay.com/20inch-Turbo-Oil...item230e631ef5
    Sent on a Post-It by way of carrier pigeon
  2. Member dirosama's Avatar
    Mar 5th, 2009
    Fairlawn, OH
    1998 Audi A4 1.8T, 2002 RS GTI 1.8T (RIP)
    03-19-2011 01:00 AM #2
    20"?! I think that is a little long and te amount of rigging need to make it work is not worth the hassle. Find a part out and pick one up for $20-30, that is your best bet
  3. Member hootyburra's Avatar
    Feb 19th, 2007
    Bloomsburg PA
    337.sold 2.slow
    03-19-2011 10:32 AM #3
    I have one for sale
    CTS 3076 kit, CTS 750hp FMIC, CM FX400, 2L, AEB, RMR IM, Raxles, Eurodyne, 870's...
    Vag Scans, pm me
  4. Member Zneith's Avatar
    Jan 4th, 2010
    East Greenville, Pennsylvania
    2001 Jetta 1.8 BT
    03-19-2011 10:53 AM #4
    That is far too long.
    GT3071r w/ Eurodyne 630cc Mafless File / Siemens 630cc Injectors / Inline Walbro Fuel Pump / Port and Polished AWP Head w/ exhaust valves / IE Rods / VDO Boost+Vac Gauge / WideBand A/F Gauge / 3" Down pipe / Boostvalve MBC / 38mm EWG / Custom Intake Side / VF FMIC / 3" Eurojet Catback Exhaust / HKS SSQV / ECS Stage 2 Clutch, W/ Light Weight Flywheel**Vag Com - East Greenville, Pennsylvania** Pagparts/Eurodyne
  5. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    03-19-2011 11:33 AM #5
    They have a 14" setup as well, i just copied that link quick. They also have just the flanges available so you can run whatever length. My stock drain is rusting through on the bottom bend and the gasket is leaking.
    http://cgi.ebay.com/14inch-Turbo-Oil...55789755203228
  6. Member hootyburra's Avatar
    Feb 19th, 2007
    Bloomsburg PA
    337.sold 2.slow
    03-19-2011 12:46 PM #6
    Like I said before I have a stock line for sale from when I went big turbo. Both drain and return.
    No need to use cheap rubber lined ebay lines.
    Vag Scans, pm me
  7. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    03-19-2011 12:58 PM #7
    I was looking into running an -AN setup like some other have done. Just wanted to see some options other than stock, not that there is anything wrong with it.
  8. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    03-20-2011 10:58 AM #8
    I pieced together one of these last night, along with 2 flanges from ebay. I got the -10AN size, all together it was about $50.
