Results 1 to 11 of 11
Thread: 2001 S4 climbing and droping RPM when idle.
  1. Member RICO85's Avatar
    Feb 3rd, 2011
    CA
    B5 S4(sold) - SILVER 2012 VW CC R-Line DSG
    03-21-2011 01:24 AM #1
    2001 (B5) AUDI S4
    When i turn on my car the RPM's fluctuate between 700 and 1500. And there seems to be a popping sound coming from the engine bay as well. The car is fine when I'm driving it, but when i come to a complete stop the RPM's just start to drop, and climb sporadically. There is no check engine light, and no codes. I have replaced the spark plugs and the air filter, but the car still does the same thing every time i turn it on. I have read other threads with people having the same issues with the RPM's, but no one has the popping in the engine like i do. Any help will be gratefully appreciated.
    Thanks!
    Feb 13th, 2009
    Santa Cruz, Ca
    B5 S4, MK1 Rabbit
    03-21-2011 01:28 AM #2
    have you pressure tested for leaks?
    '01.5 Silver B5 S4 - Follow my build thread here: http://www.audizine.com/forum/showth...4-Build-Thread
  3. Member RICO85's Avatar
    Feb 3rd, 2011
    CA
    03-21-2011 01:38 AM #3
    not yet, but thinking of doing it tomorrow.
    Feb 13th, 2009
    Santa Cruz, Ca
    B5 S4, MK1 Rabbit
    03-21-2011 10:09 AM #4
    Quote Originally Posted by RICO85 View Post
    i would do that first, then go from there. almost sounds like you could have a big leak at the TBB
  5. Member mk2 16v turbo's Avatar
    Apr 2nd, 2006
    SLC
    01.5 S4,03 W8
    03-21-2011 02:24 PM #5
    Definitely a big vacuum leak.
    http://www.lowrangeoffroad.com/
    4 rings to rule them all.
  6. Member RICO85's Avatar
    Feb 3rd, 2011
    CA
    03-21-2011 04:40 PM #6
    Thanks! will definitely have to check that out. I plan on replacing the TBB with the APR Bi-
    pipe i just got in the mail. And hopefully a pressure test will tell me what I have to fix.
  7. 07-26-2012 01:56 PM #7
    did you ever solve this my are is doing the same thing
  8. Member RICO85's Avatar
    Feb 3rd, 2011
    CA
    07-28-2012 09:01 PM #8
    Quote Originally Posted by iBeast View Post
    Yes, I have not been in the B5 forums since I got a CC. There was a vacuum leak in the pcv valve. The valve had a crack in it, and caused the o-ring that held it in to the manifold to fall off. I replaces the pcv valve, and the problem has not come back. I also replaced the TBB, and both diverted valves with APR bi-pipe and 710N's. Hope that helps. This also happened to my friends S4 a couple months ago, he just put silicone on the pcv valve and called it a day. As far as I know the problem hasn't come back on his car either.
    NEUSPEED Tuned 2012 CC .:R-Line Reflex Silver.
    Quote Originally Posted by KOWCC View Post
    Rico has the sickest silver CC out there....
  9. 07-28-2012 09:31 PM #9
    thx you. Ima check for a vacation leak tomarrow
    Sent from my LG-P999 using Tapatalk 2
    Feb 13th, 2009
    Santa Cruz, Ca
    B5 S4, MK1 Rabbit
    07-29-2012 03:17 AM #10
    Vacation leak? Nice...
  11. 07-31-2012 12:09 AM #11
    lol my stupid phone likes to autocorrect everything
