VWVortex.com - how to disable DRL using vag-com?
    Results 1 to 17 of 17
    Thread: how to disable DRL using vag-com?
    1. 03-21-2011 03:24 PM #1
      i need some help how to use vag com to disable my DRL on 2010 cc.
      I have nver used it before, however i have another cc ownder with vag-com software in upstate ny. I am sure that person would know more about vag-com than myself, but i would also like to know like specific codes and steps to succesfully disabling the DRL.
    2. Member VdubTX's Avatar
      Jul 5th, 2003
      Rockwall, TX
      03-21-2011 04:39 PM #2
      Quote Originally Posted by JYGTI View Post
      No codes are needed, it is a simple unchecking of a box in the 09-Central Electriconics Module Long Coding Helper. I have screen shots at home I can post up if you like. Can post up later this evening.
      edit:thanks for correcting me veedubin
      2012 Audi A4 Quattro Premium Plus, push start/stop, Nav, lots of vagcom tweaks.
      2011 VW CC fog lights retrofit LINK
      CC Windows w/key fob & Rain Closing - LINK
    3. Member Veedubin02's Avatar
      Mar 25th, 2002
      Ashburn, VA
      2002 VW GTI 1.8T, 2003 Audi A4 3.0Q, 2009 VW CC Sport, 2011 JSW TDi
      03-21-2011 04:42 PM #3
      Its centeral electronics (09). I believe its even in byte 0.
      Same as the MKVs
      http://www.swankmonkey.com/vw/jetta/2006/ecu_recode/
      He is right though its just check boxes in vagcom, the software will adjust the coding for you.
    4. Member ebi718's Avatar
      Jan 15th, 2011
      Brooklyn
      2010 A6 Avant, 2009 A8 L
      03-21-2011 04:44 PM #4
      Why would you want to disable DRL?
      2010 A6 3.0T Avant
      2009 A8 L
    5. Member Veedubin02's Avatar
      Mar 25th, 2002
      Ashburn, VA
      03-21-2011 04:49 PM #5
      Quote Originally Posted by de_bklyn View Post
      Its personal preference. They dont look goo to me especially with halogen bulbs plus they can reduce bulb life.
    6. Member VdubTX's Avatar
      Jul 5th, 2003
      Rockwall, TX
      03-21-2011 04:55 PM #6
      Quote Originally Posted by Veedubin02 View Post
      Agree. The only time I like to have the DRL's on is when I am driving major highways etc. Have to re-enable with VCDS on my CC, but in our Touareg, can select them via the MFD.
    7. Member ebi718's Avatar
      Jan 15th, 2011
      Brooklyn
      03-21-2011 05:05 PM #7
      I'd leave mine on. I think safety trumps convenience/preference.
      2010 A6 3.0T Avant
      2009 A8 L
    8. Member Veedubin02's Avatar
      Mar 25th, 2002
      Ashburn, VA
      03-21-2011 05:29 PM #8
      The safety of them has been debunked plenty of times, hence why the DOT doesnt make them a requirement in the US. Halogen DRLs don't help, xenon and LEDs on the other hand are more noticeable.
    9. 03-21-2011 08:18 PM #9
      what else do i need to tweak? i heard something about xenon without shutter or something??
      I just installed HID and wanted to set the right settings for it...
    10. 03-21-2011 08:21 PM #10
      I installed HID kit so therefore i wanted to save the bulb life time....by disabling DRL which is always on....i just think that this would help.
    11. 03-21-2011 10:25 PM #11
      How can you tell what they look like, when you're inside the car driving?
      Mine as well not turn your lights on at night, reduces bulb life.
    12. Member VdubTX's Avatar
      Jul 5th, 2003
      Rockwall, TX
      03-21-2011 10:42 PM #12
      Here is screen of the 09-Central Electronics Long Coding Helper Byte 0 simple uncheck of the DRL for North America box in Bit 4
    13. Member
      May 12th, 2010
      2010 CC Luxury
      03-22-2011 03:07 AM #13
      Anybody knows how to enable cornering lights as DRL?
    14. Member Veedubin02's Avatar
      Mar 25th, 2002
      Ashburn, VA
      03-22-2011 07:38 AM #14
      Quote Originally Posted by 56nomad56 View Post
      Troll post is trolling
      Quote Originally Posted by Faramarz1 View Post
      CHeck the VagCom box for "Fogs as DRLs" There is something different with the CC that will apply this to the cornering lights and not the fogs.
    15. 06-16-2011 01:07 PM #15
      Will this work for 2012 CC?
    16. Member Veedubin02's Avatar
      Mar 25th, 2002
      Ashburn, VA
      06-16-2011 01:33 PM #16
      Quote Originally Posted by gordonyz View Post
      It should I dont believe the coding has changed.
    17. Member teknodogg's Avatar
      Nov 18th, 2013
      Dallas, TX
      2010 VW CC Sports
      04-21-2014 11:20 AM #17
