Page 5 of 5 FirstFirst 1 2 3 4 5
Results 141 to 162 of 162
Thread: Installed *OEM* LED license plate lights today
  1. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    02-23-2012 09:08 PM #141
    Quote Originally Posted by 71sbeetle View Post
    I have yet to see one in person, I wonder how they look
    like love.
  2. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-24-2012 01:32 AM #142
    Quote Originally Posted by Squirrel Nuts View Post
    that's what she....
    nevermind.
    awwwwwww man
    yep
  3. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-24-2012 12:59 PM #143
    No OEM, no care
    That resistor setup is the right way to go though
  4. Banned BetaOp9's Avatar
    May 4th, 2006
    2008 VW R32 [TR #2392]
    02-24-2012 06:32 PM #144
    Quote Originally Posted by phatz314 View Post
    No OEM, no care
    Others might not feel the same way! Just offering up something for people who aren't as savvy with a soldering iron and electronics.
    The write up is great, and I'm not trying to take away from that. Excellent work with the detail. So many people don't take the time to dig into the details.
    Shawn
  5. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    05-09-2012 12:34 AM #145
    Quote Originally Posted by quailallstar View Post
    OK glad you already contacted Dana about this. Need to read all the postings over on motor-talk.de again to refresh my memory. What I recall is that MY2012 Golf models have Byte 17/bit 7 as modifiable and it might just be a matter of VCDS software being updated to reflect this in the coding dialog screen.
    FYI: Look what came from Germany this morning Built 15th week of 2011
    Hi, i know there are different variations of these STOCK LED's. Some part numbers end with B as your does and some end with C. I have a 2012 CC, with the Hi-line CECM. DO you know what part number will work for me and NOT cause the bulb out errors i keep getting. Your help is truly appreciated...i have been battling this for weeks, and so car nothing has worked, even turning off the cold diagnostic for the license plate light via VagCom. Thanks much!!
    '12 CC Lux Ltd....
  6. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    05-09-2012 01:10 AM #146
    Quote Originally Posted by KOWCC View Post
    part numbers ending in A, B, C, etc are just revisions of the part. I would be 99% confident that they are fully backwards comaptible
    that said, you will have a bulb out error unless you add resistors... at least on a golf/GTI
  7. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    05-09-2012 01:19 AM #147
    Good to know...so without resistors, nothing should work..... Even the OEMs.
    '12 CC Lux Ltd....
  8. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    05-09-2012 06:03 AM #148
    As stated by Phatz314 - the different letters are just part number revisions. As for these working in your CC I'm not 100% sure. I would say you might need resistors like the pre 2012 Golf models do in order for these to work. I would contact Dana at Ross-Tech with a scan of your CECM to see if she can maybe help?
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  9. Banned BetaOp9's Avatar
    May 4th, 2006
    05-09-2012 11:07 AM #149
    The CC does a canbus check, as well. So resistors would be required.
    Mar 2nd, 2011
    CT
    08 Passat 4Motion Sdn
    05-09-2012 02:23 PM #150
    I got the revision C and installed them on my '08 Passat and have no errors...and they work fine. Anyone care to throw out a reason? Different from a GTI I know...
  11. Member jettaglis's Avatar
    Nov 9th, 2006
    Huntersville Nc
    '88 gli, '11 cc, '12 ko4'd gti... '03 gli in the past
    05-09-2012 04:00 PM #151
    i just ordered the "c" ones and will pop them in to see...oh wait my projector xenons have a bulb out error anyway
    BILLY BOAT, H&R , UNITRONIC & VMR WHEELS at Vw of South Charlotte NC
    VSC Tuning
    Chapter 11 dubs
  12. 10-18-2012 07:45 PM #152
  13. 11-12-2012 09:15 PM #153
    I might be missing something here, but why are two load resistors adapters necessary?
    Isn't the computer looking at the draw coming from both bulbs?
    If you need two 50 ohm resistors, one 25 ohm resistor should work just as well.
    Or, am I missing something.
  14. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    11-13-2012 03:12 AM #154
    Quote Originally Posted by Toehead View Post
    You could try
    But they are separate connectors for each bulb... So one resistor per connector. The high sides may be common but I don't think so
    In any case you'd still need all the connectors and repair wires. Guess you could save one resistor
  15. 11-13-2012 08:25 AM #155
    Should work with one...when I got resistors for regular T10 LEDs I tried with resistor on one side only and it worked without bulb out error.
  16. Junior Member
    May 9th, 2010
    Cheyenne, WY
    2012 GTI
    02-22-2013 05:31 PM #156
    ordered ZIZA lights from ECS tuning for my 2012 GTI and they throw a bulb out code when applied to the city lights. I know the bulbs are good because they didnt do so on my 2009 Tiguan. Called ECS and they said I could run a 10 ohm resistor in series with the bulb and it should work. First, does that sound legit? and second, how do I do that? He also mentioned Radio Shack. Would they have it??? The resistor? I see what you guys did with the license plate bulbs, but I am not prepared to spend that kind of money on all those parts, or time, for now. I am almost willing to just deal with the bulb out light and warnings
    ***LOOKING FOR VAG COM IN WYOMING/NORCO AREA*** 2012 Shadow Blue GTI/Stage 2/H&R Lowering springs.
  17. Junior Member
    May 9th, 2010
    Cheyenne, WY
    2012 GTI
    02-22-2013 05:34 PM #157
    does anyone make a an LED bulb that goes around all of this nonsense? I see a bunch of links, but I have used ECS, I have used ledwholesale, I have used DEautokey, and every bulb is throwing a code. I just want plug and play because I dont have vagcom and I am not as technical as most of you guys...
  18. 02-22-2013 06:23 PM #158
    Quote Originally Posted by sciroccoii88 View Post
    I ordered the oem lights and plug&play adapters from Kufatec USA...i searched for "name plate" on their UK website, found the parts, then emailed Kufatec in the US and they got them for me. 2 years so far and no issues or bulb errors. Took 2 minutes to install.
  19. Junior Member
    May 9th, 2010
    Cheyenne, WY
    2012 GTI
    02-22-2013 07:19 PM #159
    Quote Originally Posted by el_zorro View Post
    the "oem" lights are LED? I think I will just order the whole kit from DEautokey. My only issue now is the city lights in the front. No matter what LED I put in the front it sets off a code. Thanks for the response!
  20. Member hussdog426's Avatar
    Nov 20th, 2011
    North Jersey
    Bagged 2012 Golf TDI
    02-22-2013 07:27 PM #160
    the oem lights are leds
    2012 Bagged United Gray Golf TDI OEM+
    follow me on instagram: @hussdog426
  21. 03-16-2013 10:53 AM #161
    Okay. What the issue with "bulb is out" ever resolved via the VCDS way?
    Is it worth to spend the money (43 GBP per EACH LED at local stealership!) in order to try this mod?
    My complete autoscan was posted here: http://forums.vwvortex.com/showthrea...1#post79834488
    The module I have:
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
    Component: BCM PQ35 M 103 0615
    Revision: 00103 AD
    Coding: 40180A3A80251AC040080080100081E443010088524D816064 8000200040
    Shop #: WSC 00028 028 00001
    VCID: 356AE3019CDE3EB0C23
    Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 09061 21 0512
    Coding: 009795
    No fault code found.
    Also, the car build date seems to be around 25th week of 2010.
  22. 03-19-2013 02:01 PM #162
    In case anyone else is interested in upgrading their car's license plate lights to the OEM units, I have a pair of OEM 1K8943021C license plate lights, just listed them on ebay.co.uk. Although it says shipping to UK only, I'll ship worldwide, just ask me for the shipping costs. Might be cheaper than all you think. Happy bidding!
    Oh, and these OEM LEDs seem not to give the 'bulb is out' message on MkV's once the cold diagnosis is turned off.
