Lumina alternators
#1
Perhaps it's the pessimist in me, but I often see certain nice, desirable cars and the first thing I think of is the hidden time bomb I know lurks within.
For instance: I saw a 944S2 en route to work. First thing I thought of: "I wonder if the owner has replaced the timing chain tensioner guide ramp." If that fails, catastrophic head failure is a WHEN, not an IF.
Similarly: Volvo XC90 T6...a neighbor just bought one used and is very proud of it. I didn't have the heart to say it, but my first thought: "Hope the gearbox has already been replaced..." The GM-sourced AT in those cars is a known failure point that many XC90 T6's encounter.
A friend bought a high-mileage W124 E320 wagon that "is in really good shape, but I think it needs a tune up" because the check engine light was on and it was missing intermittently. I poked around underhood a bit, and sure enough--the engine wiring harness was disintegrating.
What other cars have these hidden time bombs that you know of?
#4
90-93 Infiniti Q45: Timing Chain Guide
Any LT1: Optispark
90-91(some) Miata: Shortnose Crankshaft failure
Any V6 Honda/Acura with auto trans: Eventual trans failure, particularly RL1 Odysseys
#7
#8
Mk2 VW heater cores.
I can still hear mine ticking.
#9
Oh so true, so lets add ANY Chrysler 4spd automatic transmission, with an emphasis on the ones named "Ultradrive"
What is somewhat amusing is that while my parents had their 94 Town and Country it went through 5 transmissions, however when it was working correctly it did drive really well for 4spd auto with very little shift reluctancy like many 4spd autos do.
#11
vw diff rivets.
thats an easy one though.
sad part is they used the same ****ty heatercore in the mk3. I have done 6 vw heater cores in my short lifetime. Im not a mechanic either, just every mk3 I have owned or my brothers have owned has needed a heatercore, except for my first 97 jetta gt. every single other mk3 has needed a heatercore.
Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
my "build" thread: 16v+carbs FOR SALE!!!
My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
#12
Auto trans for 99.5 to 03 TDI Mk4. They will fail at around 90k miles regardless of maintenance.
#14
Also, Volvo 850/X70 heater cores. They were made with holes on purpose, I swear.
#15
#16
GM pushrod 60-degree V6 (2.8, 3.1, etc) intake manifold gaskets.
Ford 3.8 V6 (Windstar, Taurus) head gaskets.
#18
Jeep Cherokee (XJ): Rotted floors.
F1
RED BULL Racing Formula One
Final Gear
"Here's a couple things America got right; cars and freedom"
#19
Google image search for time bombs on cars is interesting to say the least.
#20
Nissan VQ40- May eat it's timing chain tensioner before 90K miles
Dodge Ram with 5.9L Cummins- The tank mounted lift pump will take a crap at some point between 80-120K. The trucks front end will be completey shot before 80K needing a rebiuild, same for all U-Joints thanks to no factory zerk fittings.
#22
I totally agree with the G60 supercha......wait.....INB4G60SUPERCHARGERS??![]()
#23
cams
Previously Owned: 96 LR Disco SD/65 Corvair Monza/93 Corolla Wagon DX/89 LeSabre Limited/96 Camry LE99 Regal GS/95 Accord EX/98 CSVT
Current:90 LS400
#24
BMW engines with electric water pumps.
When it happens it is sudden and you most likely left stranded .... with a 1K$ bill.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
#25
i just noticed sunday that my 1981 ford f100 has grease fittings on the drive shaft. seeing as i got the truck for 1 dollar, from what i believe to be the original owner, i can almost guarantee they have never been greased. Probably why the dodges brake ujoints, most onwers likely have no idea they are serviceable.
#27
#28
turbo seals & direct ignition cassette
#30
Vanagon fuel lines
Actually, the WBX as a whole...![]()
Cabby-Info.com -- Your online guide to the VW Cabriolets
Old Blue's Blog -- The adventures of a 1990 Westfalia
"Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
#31
I knew the first post would have something to do with a 944 before I even clicked.![]()
Mazda, Porsche, Volkswagen.
Want to find out where the current Free driving events are being held? Have one to add to the list? Click here!
#32
2.0t FSI cam follower.
I feel sorry for whomever buys a used MKV GTI/GLI/Passat/etc out of warranty and is not aware of this issue. Such a shame, because otherwise is an excellent car.
#33
#34
1998 VW Golf Mk.III 5dr/1960 Porsche 356B T5
/1980 Honda CM400E
"I drive an '81 Jetta with a Scirocco engine, Rabbit front fenders and multi-colored doors. There's a spiderweb fracture in the driver's side windshield, and a dented bumper sticker that says 'praised are the lowered'"
#35
Can you say "IMS" in 986/987 series Porsches?
I'm shopping Caymans at the moment, and am in full-pucker mode knowing that the delicate digit of destiny may reach down and tap me on the shoulder, leaving a big hole in my wallet.
insert your favorite expitive here___________________.
