Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 257
Thread: Cars with hidden 'time bombs'
  1. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    2010 Hyundai Accent 1992 Mazda Miata
    03-23-2011 06:47 PM #36
    Quote Originally Posted by yeayeayea View Post
    sad part is they used the same ****ty heatercore in the mk3.
    And the B3/B4 Passats...
    Any early VW doorhandles. They used them for 20 years and never tough about upgrading them.
    Quote Originally Posted by SAV912 View Post
    Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
  2. Member Delux's Avatar
    Dec 9th, 2001
    '09 Lexus ES 350, '11 Lexus IS 250
    03-23-2011 06:48 PM #37
    Quote Originally Posted by realpower View Post
    Any Chrysler product older than 5 years; Transmission
    this
  3. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    00' VR6 12' V6 TDI 72' 914-6
    03-23-2011 06:48 PM #38
    06 production VW 3.6L VR6 motors used in the Passat, Tourag, and early Porsche Cayannes.
    they have the dreaded oil=pump bolt failure.
    I know, because my 1st one went 22 days into ownership....VW replace the car with a doppleganger.
    I had VWoA sell me an extended warranty in case it happens in the replacement car.
    Larry
  4. Member GLI_DRIVER's Avatar
    Mar 26th, 2002
    OR.WA.
    04 R 06 A3
    03-23-2011 06:50 PM #39
    Saab V6 oil coolers in the valley.
    GM plastic intake manifolds and cooling elbows.
    VW/audi upper control arms.
    Jaguar timing chain guides.
    Mk5 rear brakes @ 15k.
    Mk3 aba ignition coils.
    B5 heater cores clogging.
    .:R
    Build your car for yourself, not what an internet forum tells you.
  5. 03-23-2011 06:54 PM #40
    vw diff rivets.
    yeah experienced that the hard way
  6. Member zmt's Avatar
    Dec 7th, 2001
    DFW, TX
    '07 335i, '06 T&C, 07 Z4MR
    03-23-2011 06:57 PM #41
    Don't tell my '06 T&C w/ 150k miles!
  7. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    West Palm Beach, Florida
    1971 Super Beetle, 2010 Golf TDI, 2012 Jetta TDI
    03-23-2011 07:07 PM #42
    B4 Passat:
    Heater core
    1.8T:
    Timing belt
    Water pump
    Coil packs
    Diverter valve
    MK4:
    Window clips
    Brake light switch
    B6:
    Steering column lock
    CR TDI:
    Fuel pump
    2.0T FSI:
    Cam follower
    Chrysler/Jeep/Dodge products:
    Automatic transmission
    Steering rack
    Ford Ranger/Mazda Trucks:
    Steering pump
    Toyota:
    Accelerator pedal
    Ford Pinto:
    Too much to list
    also the BMW electrical systems, and their hpfp
    And more ....
  8. Member sticky euro's Avatar
    Nov 23rd, 2009
    RI
    '08 Jetta, '07 Wrangler
    03-23-2011 07:10 PM #43
    I guess more recently, the MKV Jetta/Rabbit blows the clutch somewhere between 40-55K
    I hope not though, mine only has 26k
  9. 03-23-2011 07:13 PM #44
    I believe you're looking for this:
  10. Member eddie291's Avatar
    Jun 16th, 2007
    Coral Springs, FL
    Nissan 370Z 6MT
    03-23-2011 07:24 PM #45
    The Pontiac Grand Prix GTP S/C(my very first car) has a big problem with the transmission. IIRC, the car comes stock with 280 ft/lb of torque. And the torque rating of the transmission...also 280 ft/lb of torque. There's a solid chance it'll fail at stock form, never mind how it'll fare if it were modded.
  11. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    03-23-2011 07:28 PM #46
    Came for "020 - Pull the Pin and Drive" demotivator picture.
    Left disappointed.
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  12. 03-23-2011 07:29 PM #47
    Volvo S60R - Angle gear
    986 Boxsters - Front engine mount, air/oil separator
    E46 BMWs - Rear subframe
    Every direct-injection engine on the market - Valve deposits (worse on non-turbo models)
  13. 03-23-2011 07:32 PM #48
    Quote Originally Posted by Unkabart View Post
    Can you say "IMS" in 986/987 series Porsches?
    ...and the 996 and 997.1's too...
  14. 03-23-2011 07:33 PM #49
    Toyota 3.0 Truck-4Runner headgaskets
    Toyota 22R and 22RE 85> timing chain rail driver's side
    VW 01M automatic
    VW 020 reverse gear
    VW Mk3 heater core
    Ford 4.6 and 5.4 sparkplug blow outs
  15. Member Geechie_Suede's Avatar
    Jan 17th, 2009
    Grand Rapids, MI
    1990 Lexus LS400
    03-23-2011 07:35 PM #50
    Quote Originally Posted by eddie291 View Post
    Yeah, this.
    Previously Owned: 96 LR Disco SD/65 Corvair Monza/93 Corolla Wagon DX/89 LeSabre Limited/96 Camry LE99 Regal GS/95 Accord EX/98 CSVT
    Current:90 LS400
  16. Member windycityvdub's Avatar
    Jan 21st, 2008
    Nashville, TN
    2012 MINI Cooper S, 1986 BMW 528e BABE Rally Beater
    03-23-2011 07:44 PM #51
    2000-2003 Acura TL: transmission
  17. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    03-23-2011 08:03 PM #52
    Mazda rotary gaskets
  18. Member Toaster29's Avatar
    Jan 19th, 2000
    Birmingham, Al
    2010 GTR
    03-23-2011 08:10 PM #53
    This:
    2010 GMG GT-R, 10.72 @ 132 so far / 09 E92 335i M-tech, JB4 and E85 mix
    Past: 300 hp A4, 500 hp Evo, 430 hp 335, and a 520hp Z06
  19. Member 2.0_Mazda's Avatar
    Nov 3rd, 2010
    Mtl, Quebec
    Protegé
    03-23-2011 08:32 PM #54
    no signature
  20. Member boner's Avatar
    May 18th, 2002
    Ottawa
    93 corrado vr6, 95 cabby vr6, 95 golf race car, 05 trailblazer
    03-23-2011 08:35 PM #55
    Quote Originally Posted by palakaman View Post
    I totally agree with the G60 supercha......wait.....INB4G60SUPERCHARGERS??
    i know! 22 posts on a cw forum till g60??? you guys are slipping!
  21. Member Boogety Boogety's Avatar
    Jun 22nd, 2003
    Dallas!
    '06 NBC
    03-23-2011 08:36 PM #56
    E46 BMWs older than 2003, auto transmissions (and someone mentioned subframes, too)
  22. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    03-23-2011 08:38 PM #57
  23. Member CosmicTDI's Avatar
    Oct 9th, 2005
    Ohio
    1999 Cosmic Green Jetta TDI
    03-23-2011 08:50 PM #58
    Quote Originally Posted by KahviVW View Post
    Wow, TCLers are not a photogenic bunch
    My god...this thread is pure homosexual excellence.
  24. Member 89fuchswagen's Avatar
    Dec 2nd, 2006
    LVNV
    1956 Buick Special "Riviera", 1997 Jeep TJ
    03-23-2011 09:07 PM #59
    This:
    With this:
    The W123 Mercedes, most notably the 240D, is an excellent model of automotive perfection!
  25. Member adrew's Avatar
    Aug 14th, 2003
    Texas
    Yaris x2
    03-23-2011 09:11 PM #60
    Quote Originally Posted by BattleRabbit View Post
    My friend's wife hit 450k with a first gen Odyssey on what I believe to be the original transmission.
    Those are all four-cylinders.
    Improving the signal-to-noise ratio
  26. Banned boostingti4lyf's Avatar
    Mar 22nd, 2010
    li ny
    02 vw gti 1.8t, 95 cummins 12v
    03-23-2011 09:13 PM #61
    dodge 5.9 cummins torque converters and the rest of the auto trans
  27. Member JOHNS92JETTA's Avatar
    Mar 2nd, 2003
    Markham
    '92 Jetta 2.1L 16V, '08 Mazda3 GT
    03-23-2011 09:13 PM #62
    Quote Originally Posted by CodeMan View Post
    Mk2 VW heater cores.
  28. Member Murderface's Avatar
    Nov 12th, 2006
    PA
    2001 Porsche Boxster S
    03-23-2011 09:17 PM #63
    I'm shopping Caymans at the moment, and am in full-pucker mode knowing that the delicate digit of destiny may reach down and tap me on the shoulder, leaving a big hole in my wallet.
    insert your favorite expitive here___________________.
    Timebomb defused!
    I don't think replacement bearings exist for Caymans though...
  29. Member todras's Avatar
    Mar 28th, 2001
    Muskegon, MI
    Sold the fun cars. :(
    03-23-2011 09:20 PM #64
    Quote Originally Posted by Nicefeet View Post
    Isn't it more prevalent on the 4.6 though?
    GM 3100 & 3400 with intake gaskets letting coolant seep at about 100k overheating the engine.
  30. Member B3passatBMX's Avatar
    Feb 26th, 2004
    Columbus, OH
    93 525iT, 91 318iS
    03-23-2011 09:23 PM #65
    Quote Originally Posted by Ben.Reilly View Post
    Jeep Cherokee (XJ): Rotted floors.
    Lol so true. I bought mine cause it had only two small rust spots on the body. Thought to myself one day...I ought to check the floor and patch any small holes in the floor. Figured since the body was in such good shape the floor wouldn't be bad at all
    Rear passenger (was MUCH worse once I hit it with a wire brush)
    Front passenger side
    Ended up being alot more than a "patch" job.
    Well, then, I'm here to "ruin" the vortex for you. I'm sorry you hate fun.
    02 SVT Focus: Jackson Racing supercharged (SOLD )
    91 318is
    93 525iT
  31. Member CosmicTDI's Avatar
    Oct 9th, 2005
    Ohio
    03-23-2011 09:38 PM #66
    Quote Originally Posted by adrew View Post
    And are re-badged Isuzus.
  32. Member jimbogxp's Avatar
    Dec 23rd, 2006
    Yuba City CA (near Sacto)
    2008 Pontiac Solstice
    03-23-2011 09:45 PM #67
    German electrical systems. ALL of them. Or has that changed recently.
    Since the British have about quit building cars, I think the Prince of Darkness has jumped from the Allies to the Axis powers.
  33. Member
    Feb 9th, 2011
    Fort Polk, LA
    '87 Monte Carlo SS, '05 Mustang GT
    03-23-2011 09:49 PM #68
    Instrument cluster failures on S197 Mustangs, (mostly '05 and '06 I believe).
  34. Member rains's Avatar
    May 30th, 2008
    Sherwood Park
    2000 GTI [1.8t], 1993 Jetta [ABA-T]
    03-23-2011 09:56 PM #69
    Quote Originally Posted by Burnitwithfire View Post
    Yep. B4 heatercores, window regulators, door handles ... The Vr6 coilpack, crackpipes ...
  35. 03-23-2011 10:01 PM #70
    Quote Originally Posted by CosmicTDI View Post
    NOT you're thinking of a Passport.
    I would say VW's out of the bumper to bumper warranty are ticking bombs.
