Results 1 to 8 of 8
Thread: Big 3 upgrade question
  1. 03-25-2011 05:55 PM #1
    Looking to upgrade my sound system and I've been doing the Big 3 upgrade (upgrade engine ground, battery ground, and alternator power wire). I've been following this DIY made for a VR6, and I got the 2 ground wires done.. but I'm wondering where the bolt for the alternator is at.
    I found this from looking at the top of the engine, is this what I want?
    Thanks a bunch.
  2. Member blazerpounds's Avatar
    Mar 19th, 2008
    Greeley, CO
    02 GTI 1.8t
    03-25-2011 06:30 PM #2
    Your picture looks like a picasso, but there should be only one wire connected to it with a big bolt, that's the one you wanna replace 。
  3. 03-25-2011 06:37 PM #3
    Thanks, I try
    Haha alright well if there's only one wire connected to it, then that's definitely it.
    It doesn't have a ground wire or anything? (total n00b when it comes to engines if you couldn't tell)
    Thanks man.
  4. Member blazerpounds's Avatar
    Mar 19th, 2008
    Greeley, CO
    02 GTI 1.8t
    03-28-2011 05:07 PM #4
    It's grounding itself out through itself, through the main bracketry to the motor itself
  5. Member ibanezguy19's Avatar
    Aug 21st, 2009
    93 Golf 2.0/96 Golf 2.0/07 GTI 2.0(t)
    04-01-2011 03:55 PM #5
    I'm sure you allready know this but just to double check:
    Be sure that you disconnect the ground wire from your battery before removing this wire. If you don't, this could short to anything that is grounded(i.e. almost any metal in the engine bay)
  6. Junior Member
    Mar 20th, 2008
    San Antonio, TX
    2003 Jetta 2.0
    04-30-2012 11:08 AM #6
    how much cable did you end up using? any suggestions for battery terminals? pics?
    Mar 10th, 2002
    Middle River, MD
    2003 VW Jetta GLI 24v, 2008 Yamaha R1
    04-30-2012 05:25 PM #7
    Quote Originally Posted by BIGPIMPNfshtx View Post
    This thread is from last year. The thread starter hasn't been on since 3/20/2012. Might wanna shoot him an email.
    Here's the thread that he used as a guide. It says 7 feet.
    http://forums.vwvortex.com/showthrea...hlight=big+diy
  8. Junior Member
    Mar 20th, 2008
    San Antonio, TX
    2003 Jetta 2.0
    05-09-2012 01:44 PM #8
    thats about right. thx for the info.
