Page 4 of 64 FirstFirst 1 2 3 4 5 6 7 8 14 54 ... LastLast
Results 106 to 140 of 2232
Thread: AJmustDIE's ABA Turbo Build Thread
  1. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-13-2011 10:52 AM #106
    Have you guys seen the power that guys are making on the newer billet wheel precision units?
    I've seen dynos of 700+ on the 6262 (62mm), and solid solid numbers on the smaller versions of the same turbo. They're reasonably priced too. You'd probably end up spending about the same on a similarly sized garretts unit, though that site is scary cheap!
  2. Member 2pt. slo's Avatar
    Jan 4th, 2004
    Creedmoor, NC
    98' GTI 2.0T, 12' TDI SportWagen
    04-13-2011 11:36 AM #107
    I second the Precision units. If the one I have ever goes I will be making the switch.
    Quote Originally Posted by AJmustDIE View Post
    That along with a kinetic manifold and the standard Tial 38mm wastegate.
    Comments/opinions anybody?
    Good choice with the Kinetic manifold. With it you will not need to bash in your firewall as the manifold makes it sit more toward the top at a good angle. If you are going to run an open dump tube go to Lowes or home depot. They sell Stainless Steel shower rods that are prebent to a perfect angle and for like 20 bucks. You will not find a cheaper place for a dump tube. IMO GT30 a bit large. Ask around to different vendors Garret and Precision and tell them your goals and where you want your power and they can set you up with a good unit.
  3. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    Eight valve like WHOA.
    04-13-2011 01:29 PM #108
    Thanks for the opinions guys.
    Before this project all started I did want a Precision unit as I know they totally kick ass.
    The only reason I was gonna go to a gt30 was it was the smallest turbo on that site without an internal wastegate.
    Ideally I'd want the equivalent of a gt28, but which precision unit is that?
    It's Timmy with mmmmMojo, i have returned
    8VALVETURBO - Sorting the kinks out.
  4. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-13-2011 01:36 PM #109
    I know the 6262 is ~35r size.
    My problem is that i dont' know the size of the 28r wheel. Turboz aint my MOST knowledgable point.
  5. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-13-2011 09:05 PM #110
    Alrighty then guys,
    Small update here again.
    Got my slim fans in , I think they look TONS better than the oem setup. Mine was all rusted and too bulky.
    And refitted my Air/Water Radiator so it looks like this.
    I think it looks pretty damn good.
  6. Member 1.AteTee MkIV's Avatar
    Feb 12th, 2009
    Dirtyy Jerzyy
    02' 1.8t Getta (sold) 1997 2.blow Basket
    04-13-2011 09:12 PM #111
    Yes. Definitley looks pretty damn good. How did you mount the fans? And how was it wiring them? Easy/difficult?
    I like the way it looks and looks to be more spacious.
    (_fishbowl society_)
    i wish i was a little less slower...i wish i was lower....i wish i had paint that looked good i would show her...i wish i had a rabbit with a hatch in the back with a custom fit boser.
  7. Member bwalker1992's Avatar
    Aug 19th, 2010
    Warminster, PA
    1998 Vr6 GTi(miss her), 1989 Polar Silver Jetta 8v, 1997 Cabrio
    04-13-2011 09:14 PM #112
    For a young kid doing his own work on his own car!
    Quote Originally Posted by toothpick View Post
    your boy is a retard. find new friends.
    post pics of your DE.
  8. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-13-2011 11:05 PM #113
    Quote Originally Posted by 1.AteTee MkIV View Post
    They're mounted with standard radiator ties, the same thing you'd mount an oil or trans cooler with.
    I like the space too , but I needed the space, the OEM setup hits the a/c lines and some other things when you move back the radiator and condenser back an inch or two.
    As for wiring, I haven't got at it yet, I want to use the stock 3 wires clip that clips on to the OEM fan assembly but I'm not sure how I'm going to attack that issue.
    Could somebody possibly help me out with that?
  9. Member 1.AteTee MkIV's Avatar
    Feb 12th, 2009
    Dirtyy Jerzyy
    04-14-2011 01:06 AM #114
    What brand/model# wfans are they? I'll look up the schematics for you.
    I'm mecp so I'm pretty electrical savvy.
  10. Member 1.AteTee MkIV's Avatar
    Feb 12th, 2009
    Dirtyy Jerzyy
    04-14-2011 02:11 AM #115
    Here,
    Check this out.
    It might not be your exact harness but it should give you a good concept on what to do.
    http://forums.vwvortex.com/showthrea...lim+fan+wiring
  11. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-14-2011 04:35 AM #116
    Here,
    Check this out.
    You're awesome. Thanks man. I'm gonna hook em up tomorrow. Will have pics as always.
    Might work on plumbing the water lines around the car as well.
    Things might start to get slow on this build, I'm running out of funds at the moment.
  12. Member nfx's Avatar
    Jul 18th, 2004
    harco md
    MK3 2.0T, 2011 Elantra
    04-14-2011 06:53 AM #117
    Those slim fans are nice. I've got a small leak in my current rad... maybe it's time to find a new radiator and grab some slim fans.
    2.0T... it's back!
  13. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    04-14-2011 10:03 AM #118
    Quote Originally Posted by 2pt. slo View Post
    Good choice with the Kinetic manifold. With it you will not need to bash in your firewall as the manifold makes it sit more toward the top at a good angle..
    this is true but with my precision 60 trim i had to cut into the firewall alittle with the kinetic stage 3
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
  14. Member 1.AteTee MkIV's Avatar
    Feb 12th, 2009
    Dirtyy Jerzyy
    04-14-2011 01:12 PM #119
    Don't discourage. Stay productive man. Your doin work When funds are low, do what I do.
    Bodywork, clean, polish, interior, anything that doesn't really cost anything.
    I wish i had the time and resources to put together a build.
    I'm jealous
  15. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-14-2011 03:57 PM #120
    Quote Originally Posted by 95jetta17 View Post
    Pics?
    I'm jealous
    Yeah, I've been collecting all of this stuff for quite awhile and I thought I had everything to button it up and I kept on forgetting details and what now, now I gotta send this kit back, which I have to pay to ship myself and the restocking fee, and do my best with the money thats left with from that to buy another manifold and turbo. I'm confident my results will be nice in the end though.
  16. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-20-2011 02:53 AM #121
    Not much again,
    But today I got my 02A tranny and other related swap components delivered. Holy **** that box was heavy.
    Process is going slow, I want to get this thing running before SOWO, if I don't I wont be able to go.
    ECS is also pissing me off by not processing my order yet, I NEED that rear motor mount.
    I got something done today, I modified the brackets that hold the plug wire organizer thing to work with my mk4 valve cover.
    Tomorrow I will be installing my walbro inline fuel bump, trying to route my water lines, maybe some other small stuff, still trying to get in contact with the company I bought this kit off of, so I can get my money back and get to real progress.
  17. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-20-2011 03:12 AM #122
    What trans code did you end up with?
  18. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-20-2011 03:14 AM #123
    I'm not sure to tell you the truth, I haven't even dove into the box yet. Where can I find the code on it?
  19. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-20-2011 03:17 AM #124
    It will be on the front of the case. 3 letters. Reason i ask is that the ratios in the 4cyl boxes usually aren't the best. Depending which one you get, it can go a few different ways. Lots of improvement to be had with some vr parts in there.
    http://www.vwtransaxles.com/code.html
  20. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-20-2011 03:44 AM #125
    Appreciate the info man, I'll check tomorrow and get back to this thread with it so I can get your opinion,
  21. Member nfx's Avatar
    Jul 18th, 2004
    harco md
    04-20-2011 06:55 AM #126
    Where'd you get the manifold? I've got one of the black painted dealies with the plastic PCV dampeners.
    I'd rather have that cover.... or I'd rather weld in a bung for a stainless line for the PCV (which is probably cheaper, still want to know where you got yours lol)
    edit: I'm also interested in what 02A you got... I thought about doing this swap one day in the future but I need some motivation
    2.0T... it's back!
  22. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-20-2011 09:01 AM #127
    NGP supplied all of it, those guys are awesome.
    So I'm not exactly sure on the specifics, I think the cover is from a newer mk4 style 2.0,
  23. Member
    Oct 23rd, 2008
    nj
    mk3 jetta, mk3 gti
    04-20-2011 10:23 AM #128
    its off an mk4 2.0. block code aeg
    http://forums.vwvortex.com/showthrea...2.0L-ABA-OBDII
    2 for sale (not mine) http://forums.vwvortex.com/showthrea...choose-from%29
    i found a full swap at show and go here in jersey for 100. also there are 2 different valve covers one just looks like an aba cover but w/o the pcv hole? ill take some pics.
    been watching this and it looks great
  24. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    04-20-2011 10:52 AM #129
    Pics?
    had to cut it so the coupler could go in and make a dent in it so the turbo had some room
    OG suede
  25. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-20-2011 05:04 PM #130
    So just thought I'd throw up some pics of the 02a swap. It will definitely be cleaned and painted before being put in.
    Still not exactly sure what code 02a it is, there maybe grime covering it up or something.
    If somebody could do me the service of opening the trans pic on paint or PS and showing me where on the trans I could find the code that'd be much appreciated, I can't find anything on google or on here.
  26. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-21-2011 09:43 PM #131
    Ok guys looks like I have a CES code 02a,
    1st, 3.778 | 2nd, 2.118 | 3rd, 1.429 | 4th, 1.029 | 5th, 0.837 | R&P - 3.684
    I got to cleaning it today and I got a lot of the grime off, but I'm probably gonna end up using a pressure washer to get it perfect for paint.
    Hey rootbeer what's the word on having a CES code? Good/Bad ?
  27. Member
    Oct 23rd, 2008
    nj
    mk3 jetta, mk3 gti
    04-22-2011 10:04 AM #132
    _________1st___2nd___3rd___4th___5th___R&P___Notes
    CES====3.778=2.118=1.429=1.029=0.837=3.684== Passat?
    couldnt find anything else to verify those.
  28. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-22-2011 10:31 AM #133
    Yea, that looks right. That's good, that's one of the better ones to have. Short 3rd is good. Shorter 4th is good in terms of 4cyl boxes.
    Only weird thing is that with a 4cyl box, you've got a short 1st and 2nd. If you ever consider tearing that box apart, i'd suggest a long vr 1st and 2nd( 3.3, 1.944), and the even shorter vr 4th gear 1.034.
    Yea, that's all from memory
  29. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-23-2011 04:34 AM #135
    That's awesome, thanks for showing me that. For some reason it didn't include my 5th in the link but I fixed it when I arrived at the page. Looks like with upgraded valve-train I'll be able to go a little over 150 lol as if I had somewhere to even try.
    Also,
    Looking to get this from autotech:
    http://www.autotech.com/product/clut....html?fromcat=
    It's a hefty price, but necessary I guess. Also I guess I'm not returning the kit.
    I'll be using the turbo and the feed lines. As to the rest of the kit, If anybody wants to make an offer I will consider it. The pipes are pre-bent for an mk3 2.0, with a FMIC. It comes with a load of **** I just don't need or want. Feel free to PM me about it.
    Alsoooo, got the trans pressure washed today and will be painting it tomorrow.
    Stay tuned.
  30. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    04-23-2011 11:07 AM #136
    Ah yea. I usually only concern myself with 1-4, haha. I forget we have things like heat, power steering, radios, and 5th gear, haha.
    That ****'s painfully expensive. My clutch alone was 480 now that i think about it. :/
  31. Member
    Oct 26th, 2005
    MA
    I got fiiiiiiiives on it.
    04-23-2011 01:43 PM #137
    oof, price tag on that clutch
    this build is solid though man
    don't let the whole spending a few stacks thing discourage you haha
  32. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-23-2011 05:40 PM #138
    Got some pics of the freshly cleaned/painted 02A,
  33. Member jbigs268's Avatar
    Nov 30th, 2009
    Rhode Island
    98 Ginster(sold) 01 Audi A4 avant QMT
    04-23-2011 05:45 PM #139
    I would eat my dinner off that
    not again 11/11/11 never forget
    Quote Originally Posted by vento86 View Post
    anyone got anymore pics of that yellow gti?
    Yellowlove
  34. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    04-23-2011 09:00 PM #140
    Started the day with painting the trans, as you seen before this post. Decided I wanted to get some more work done on the car today.
    Got the car lifted up,
    I started installing the water lines to/from the ice box.
    Got a hole cut in the floor for the lines, lined it with some putty so it wouldn't harm the lines.
    Slipped the lines in.
    Got everything hooked up, pump feed | pressure line | return line, still needs tightening and mounts made for everything.
    This was the part of the build I was really not wanting to tackle, I mean it's not the hard it's just the concept of running 1" 1/4 rubber lines under an already LOW car that I was really hesitant of.
    Again, I apologize for the sh!tty cell pics.
    Perhaps I will do more tomorrow,
    Take care,
