Results 36 to 70 of 71
Thread: My mk1 TDI daily funmobile. Speedy Build thread lol.
    Mar 2nd, 2009
    Philly
    82 Jetta Coupe, 91 Suzuki VX800
    07-27-2011 12:12 AM #36
    Forgot to mention all the custom motor mount fabrication etc for the actual engine! I'm sure I have some pictures up somewhere, I'll find them and post them up tomorrow.
  2. Member 2mAn's Avatar
    Oct 15th, 2006
    Seattleish
    E30 Daily & Mk1 Jetta Coupe Project
    07-27-2011 02:19 AM #37
    nice work, keep it up
  3. Member veector's Avatar
    Mar 1st, 2006
    Southern Onterrible
    81 Jetta 1.6D
    07-27-2011 07:36 AM #38
    nice work, looks good, im just finishing up my 1.6d swap and hear ya on the brackets and clamps for just about everything, rad looks up-side down?
    Peter Broggs - African Sister
    [ ][ ]====W==D=[ ][ ]
    Mar 2nd, 2009
    Philly
    08-06-2011 12:25 AM #39
    Finally got the exterior almost semi-done! I realized I'm not going to be able to use the sideskirts though (wheels stick out too much so I had to shave the fender arches a bit) , so I don't really know what to do with the cabby bumper now Probably cut the bumper a bit? Any suggestions?
    Took her out for a drive without a windshield Everything works very smooth. Tried giving it a little more boost and the intercooler hoses popped right off! Gotta fix that. Rokkor coilovers not as stiff as I imagined either. Audi 100 and another Jetta in the back
    Hopefully I can finish up the interior and more little bits soon. I'll be sure to update
  5. Member RabbitJockey's Avatar
    Nov 25th, 2004
    York, Pennsylvania
    97 trek, 81 jetta, 81 rabbit, 90 cabby
    08-06-2011 09:34 AM #40
    car in the background look cool, your car looks super mega cool. nice work.
    ..........___..................___..............._ __
    ......._//_|_\__........._//_|_\__........//|_|_\__ .......z____\__
    ......|_@_|_|@|..O0o|_@_|_|@|..O0o|@_|_|@|.......| @_|_|@|
  6. Member jjvblack's Avatar
    Mar 8th, 2011
    Dryden WA
    81' VW MK1 Rabbit, 79' Dodge Omni 024, 87 Bronce 2, 04' Chevy Cavalier, 78' Yamaha SR500
    08-06-2011 10:41 AM #41
    nice work dude, did you water test the rear window? I think with some of the seals your supposed to set the seal in first, like wrap the window frame, then drop the glass in the rubber gasket. There is 2 or 3 types of windows they used with mk1's go figure.
    if its broken, fix it. then break it again.
    Mar 2nd, 2009
    Philly
    08-06-2011 07:56 PM #42
    Quote Originally Posted by jjvblack View Post
    Oh wow I didn't know that. I'm definitely ganna try and do a water test now though. Thanks
    Mar 10th, 2006
    63 beetle 81 rabbit diesel 83 rabbit 86 vanagon/subie 88cabby 95golf 4dr vr 98 tdi
    12-01-2011 10:30 PM #43
    updates?
    Aug 2nd, 2007
    LAX
    McCaddy
    12-01-2011 11:19 PM #44
    coming along nicely man!
  10. Member der hare's Avatar
    Oct 27th, 2001
    Santa Monica
    12-02-2011 12:34 AM #45
    you need to get wheels that fit or smaller tires so you can pull off that look. offset is all wrong.
    interested in seeing the clipper kit on the jetta so make it happen!
    Rando
    DCI - what part of fück off do you not understand?
    RIP Moses
  11. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    '84 Jetta, '84 Mustang 4.6 4V, '96 Mustang GT
    12-03-2011 06:57 PM #46
    Quote Originally Posted by der hare View Post
    Less tire + clipper kit = secks
    EDIT: Holy crap...I didn't realize you actually cut out the the wheel arches...you REALLY need to put the clipper kit on now.
  12. Banned
    May 26th, 2005
    o HI o
    84 coupe, 90 b3 td wagon, 81 coupe, BURNT TOAST
    12-03-2011 11:47 PM #47
    those metal things you tried to use on back window are for the front.. rear and sides do not have teeth... know its a bit late now...
    my dials are et 53... 25mm adapters... will poke way less sir... but enough to pull off the flares...
  13. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    12-03-2011 11:51 PM #48
    How did I miss this thread? Keep us updated.
  14. 05-27-2012 02:57 PM #49
    Is it done yet?
  15. Member
    Mar 2nd, 2009
    Philly
    05-30-2012 07:01 PM #50
    Hi everyone!
    Updates are coming:
    Yes I've kind of finished it. Still has lots of little things to be done though. I'll post up some more less artsy pictures later.
    I've driven around 15,000 miles so far on the motor, and not a single thing has gone wrong. (It's been my daily driver for some quite time now ) Driving up and down I-95 from Charlottesville, VA to Philly.
    I went to THE MAN, Jeff at Rocketchip. I put in some larger injectors (way too big for stock turbo) and he set me up with an RC3 tune. Putting down around 150 hp, 300 ft/lb's of torque. Later had to get my fuel pump rotated to spec with VAG-COM and he did it for free, super great guy.
    Some small issues:
    1. Rubbing. My god what was I thinking with the wheels sticking out like that
    2. Suspension. The Rokkors are terrible. Absolutely terrible, I have nothing nice to say about them other than that they work and they've held up pretty well so far for 15,000 miles. They are way too stiff and bouncy for a daily driver. Looking for some lowering springs and Bilstein Sports/Koni Yellows. Also need a front sway bar.
    3. A little too much overfueling with the injectors I went with for the TDI. I believe I have the PP764's. On the stock turbo they smoke a little too much, and the fuel economy has been MEH because of that. (Ok 42mpg still isn't bad, but I want more ) Thinking of getting smaller injectors or even going back to stock ones.
    4. Sparco's with 4 pt seatbelts not the most comfortable things in the world. Picked up some Mark 2 Jetta GLI Recaros to be put in along with normal seatbelts.
    Mechanically though, SURPRISINGLY, everything has been PEREFCT. I'm really happy the Jetta turned out exactly how I wanted it to haha.
    Changes to come:
    Euro bumpers
    Wheel Flares
    New Rims with lower offset. (Anyone wanna trade their high offset phonedials for my low offset ones?)
    Suspension
    Finish interior.
    DYNAMAT DYNAMAT DYNAMAT. Wanna keep it nice and quiet in the cabin.
    New Grill and Headlights
    New Seats
    Maybe put on a muffler, straight pipe right now, teensy bit too loud.
    Holes on the hood are because the intercooler wouldn't fit in front of the AC condenser and I had no where else to put it. Those who saw it at H2O got the explanation already hehe. Surprisingly the intercooler up top with the holes in the hood manages to cancel heat soak, and works really good I promise I'll put up more pictures of how I finished the car a little later on.
  16. Member tgibson's Avatar
    Sep 27th, 2010
    AZ / RI
    81 Caddy
    05-30-2012 07:24 PM #51
    Rather than some lower offset wheels, why don't you get smaller tires? Those things are huge and you hacked off the fender lips to run them...
  17. Member
    Apr 22nd, 2002
    NJ 08002
    2 clunkers & a nicer clunker
    05-30-2012 09:19 PM #52
    Is that power level possible on a stock turbo? Those nozzles are way larger than I see most people running... how much is a "little" smoke? I smoke a little at full throttle running Sprint 520s and a tune on my 1Z.
    Either way, great job. I especially like the fact that you retained the AC.
    -Todd
  18. 05-30-2012 10:52 PM #53
    it seems like those phone dials are 16x7... if you run a 195/40/16 that will greatly help your problem
    i hope they are also the ET65 ones... the ET52.3 aren't as friendly with adaptors
    looks great so far
    post some more pics
  19. Member
    Mar 2nd, 2009
    Philly
    05-30-2012 11:25 PM #54
    I'd get smaller tires but then I wouldn't get any traction :/ That and I'm scared driving around at higher speed on stretched and really low-pro tires. I feel like they can pop at any second haha. I really like taking turns fast and appreciating the performance of the car so I always thought 45's would be better. I probably could have went with 40's though.
    The PP764's weren't my first choice, but they were having a sale on Kerma, so I just went ahead and bought them. Jeff @ Rocketchip said he would be able to tune the nozzles down to run at the same flow as the 520's, but there's still a lot of smoke haha. I smoke a little basically even on partial throttle, and at WOT it's a biblical cloud of black smoke when I look in the rear-view mirror.
    The phone dials are the early offset 15x7 ET23.3
    The smallest adapters for 5x130 to 4x100 I found at the time were 20 mm, so the offset of the wheels currently is 3.3 all around haha. Wasn't the brightest thing to do.
    Pics are coming, stay tuned.
  20. Member punkvideo81's Avatar
    Jul 12th, 2005
    New Paltz, NY
    81 Rabbit p/u 1.6 td
    05-31-2012 02:00 AM #55
    With the little tweaks you are going to do, this should be real nice.
  21. Member tgibson's Avatar
    Sep 27th, 2010
    AZ / RI
    81 Caddy
    05-31-2012 11:28 AM #56
    Quote Originally Posted by SupraSkylineSTI View Post
    What
    I get traction just fine, and I'm running federal 165/45/15's... And they don't randomly explode.
  22. Member GTrabbIt's Avatar
    Mar 12th, 2007
    San Diego, CA
    '11 Golf TDI
    05-31-2012 01:41 PM #57
    Also picked up some Porsche Cookie Cutters with adapters.
    Was hoping to see cookie cutters, instead saw phone dials
    This car has a lot of cool stuff, can't believe I haven't seen it before and can't wait to see it finished up!
    Our mk6
    oldskoolvw.com
    DIY Garage needs funding... CLICK HERE!!
  23. Member
    Mar 2nd, 2009
    Philly
    06-03-2012 05:29 PM #58
    Here's the intercooler setup that I went with. With the radiator and AC Condenser in, it was impossible to fit the intercooler in front of them. So the only other way to go was top mount. I honestly think it came out pretty cool, and it fits perfectly. As you can see in the previous photos with the small holes in the hood, the air goes through them from the outside and through the intercooler during driving. So far temperatures and down and everythings working as it should. Created a little bar to mount and rested the intercooler on top of it. (Intercooler and piping is from eBay)
    Another angle.
    Fitting the Mark 3 dash onto the swapped firewall, and everything matches up like it should. You can see where we cut the dash on the right to make it fit inside the chassis. I still haven't come up with an idea on what to do about the battlescar where it was cut. I was thinking of recovering the whole dash, but I'm worried it'll start coming off eventually and look like ass. Any suggestions?
    Wiring for audio and other things being finalized.
    Fitting the door cards.
    Fit the Sparco R100's in, and attached harness's to rollbar. Finalized interior. (swapping the sparco's out for Recaro trophy's)
    Trunk area is still naked, don't know how to cover everything in there yet.
    Next step in stripping the whole interior again, and dynamatting the **** out of everything to cut down on noise.
    If I find any more pictures, I'll post them up.
  24. Member travis017's Avatar
    Mar 27th, 2007
    finksburg, MD
    1984 jetta turbo diesel, 04 v8 touareg, 66 notchback, 73 beetle
    06-18-2012 10:43 PM #59
    curious what you did to make the ac compressor fit in the mk1 chassis. Any pictures?
    http://oldskoolvw.com/ Custom MK1 parts
    www.the152.com It's just better here
    www.getbored.biz
  25. Member
    Mar 2nd, 2009
    Philly
    07-10-2012 11:07 AM #60
    I had to carve out a piece of the chassis to fit the compressor, sorry it took so long for a reply.
    Decided to make some few updates to the car before waterfest. Pics will be uploaded soon.
  26. 02-02-2013 04:48 PM #61
    Quote Originally Posted by veedubberkid86 View Post
    this thread delivers:thumbup:
    nice job. subscribed
    And in 30 mins or less too!!!
    I alone stand in a social corner
    - Aesop Rock
  27. Member Lagoyda50's Avatar
    Apr 29th, 2008
    ROCHESTER NY
    10 Golf TDI,81 Cabrrio VR6,97 Passat TDI
    02-02-2013 06:03 PM #62
    More more more more
    Cabrio vr6 swaP[[/COLOR]url]http://forums.vwvortex.com/showthread.php?4305221-84-Cabrio-vr6-swap[/url]
    MK6 TDI http://forums.vwvortex.com/showthrea...o-a-MK6-WHOAAA
    wABBIT TRUCK http://forums.vwvortex.com/showthrea...8#post75140248
  28. Member
    Mar 2nd, 2009
    Philly
    02-18-2013 06:35 PM #63
    I actually completely redid the car since I posted in this thread haha. I may be able to find some pictures of the transformation.
    Some reverse rake with the Eibach Sportline springs sadly, doesn't look too bad though.
    I've got more somewhere, these were from waterfest.
    I did away with the Sparcos, and put in some nice redone mk2 gli recaros. Stock seatbelts too.
  29. Member lots-o-bunnys's Avatar
    Aug 13th, 2010
    Bangor PA
    84 GTI project , 83 gti slow build , 92 Corrado slc daily
    02-18-2013 08:04 PM #64
    How much did you have to cut out of the dash? could you put a dimple dash in from a cabrio, from what i understand its a bit narrower. Love your wheels!
  30. Member
    Mar 2nd, 2009
    Philly
    02-18-2013 08:54 PM #65
    Yup its a dimple dash in from a cabrio already inside there. It was about 4 inches I had to cut out. Still don't really know what to do with where I glued the two pieces though haha. Maybe some kind of trim or fabric.
  31. Member
    Jul 28th, 2009
    Northwoods USA
    02-18-2013 09:16 PM #66
    Also, got the door panels re-upholstered I think they came out pretty good! I was going for a Spyker/GTI kind of vibe and I think I got it haha.
    More to come soon as I hope to finish this damn thing!
    Total Chesterfield look. I'm playing with vinyl right now for a GTI seat... Hope it turns out half as good as those!
  32. Member punkvideo81's Avatar
    Jul 12th, 2005
    New Paltz, NY
    02-18-2013 09:57 PM #67
    Nice job on the wheels and stock style grille. Holy headlights!
  33. Member
    Mar 2nd, 2009
    Philly
    02-19-2013 12:33 PM #68
    Quote Originally Posted by punkvideo81 View Post
    Haha thanks boss. I was lookin for that rally kinda look, looks even cooler with the covers on.
    GTI Lip also on there that I bought from a fellow vortexer.
  34. Member PorpoiseHork's Avatar
    Oct 27th, 2011
    PNW
    '11 Jetta TDI, '82 Caddy 1.8 (TDI Swap Project)
    02-19-2013 09:40 PM #69
    I'm planning to put a mk3 dash in my caddy as well. Could you go into more detail on the fitting and cutting process? How much to cut, where, etc.
    Quote Originally Posted by jearp View Post
    sorry if i misspelled or had bad grammar during this post, i smoked a bowl of weed and am drinking beer. thanks
    FS: 84' GTI engine and FN Trans
  35. 04-04-2013 04:16 AM #70
