VWVortex.com - Noise when turning steering wheel...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 37
    Thread: Noise when turning steering wheel...
    1. Member M Diddy's Avatar
      Sep 24th, 2002
      PA
      2013 Touareg TDI Exec, 2015 Jetta 1,8T Sport
      03-28-2011 12:00 AM #1
      Ok, so a few days ago, my CC's steering wheel decided it was going to start making a noise when I turn it. It's not super loud, but lound enough to annoy the **** out of me.
      It kind of sounds like one of those wheels you see at fairs, kinda like this:
      Any ideas on how to stop this? I'd rather not have to go to the dealer for something so small but I can't take this damn noise.
      2013 Touareg TDI Exec Galapagos Gray
    2. Member cwwiii's Avatar
      Jun 18th, 2007
      West Hollywood, CA
      .:White Gold:. 2009 CC 3.6 Sport
      03-28-2011 01:52 AM #2
      I started to have some creeking noise come from my right wheel well when I turn right. Going very slow. Is this kind of similar?
      Would ya look at that..
      .:dubnoxious:.
      flickr
      Nov 27th, 2009
      50 Miles South of Tucson AZ
      2015 Tiguan SEL and 2013 Genesis Coupe Track V6
      03-28-2011 01:58 AM #3
      Quote Originally Posted by M Diddy View Post
      Do you actually mean a rapid clicking sound as you spin the steering wheel?
      2015 Tiguan SEL, White Gold.
      2013 Genesis Coupe Track Version, 3.8 V6, Red.
    4. Member
      May 12th, 2010
      2010 CC Luxury
      03-28-2011 05:31 AM #4
      Two possible scenarios:
      1- CV joint
      2- Subframe assembly is lose, moving and hitting the underbody.
      I had a simillar noise and dealer added shim plates to subframe to prevent it from moving and as a result destroyed my car.
    5. Member jspirate's Avatar
      Jan 15th, 2011
      Virginia
      2011 CC 6MT, 2014 Tacoma 5MT, 2000 Miata SE 6MT
      03-28-2011 06:37 AM #5
      The steering wheel itself is making noise? Or some other component is making noise when you turn the steering wheel?
    6. Member
      Oct 25th, 2010
      Nova Scotia
      12 CC stick with roof
      03-28-2011 07:01 AM #6
      Couple of questions:
      1. Where is the noise coming from ... the steering wheel itself or somewhere else?
      2. Does the noise occur when the vehicle is stationary, or when it's moving?
      3. If you only get the noise when you're moving and when the wheel is turned to the right or left, the clacking or knocking noise may be a CV joint.
      4. If you're getting the noise when the vehicle is stationary and while turning the wheel, I would check the pump and or steering rack.
      Mack
      Dec 1st, 2009
      2012 CC DSG, 2001 Corvette 6MT Z51, 2010 Audi S4 6MT
      03-28-2011 01:23 PM #7
      There is no power steering pump. The power rack is electric, no fluid.
    8. Member M Diddy's Avatar
      Sep 24th, 2002
      PA
      03-28-2011 01:41 PM #8
      1. Where is the noise coming from ... the steering wheel itself or somewhere else? It's coming from the steering wheel itself. From the steering column actually. It's a creak, but the faster I turn the wheel, the more it sounds like a very fast tick.
      2. Does the noise occur when the vehicle is stationary, or when it's moving? Both.
      3. If you only get the noise when you're moving and when the wheel is turned to the right or left, the clacking or knocking noise may be a CV joint. Happens when standing still as well, so it rules this out
      4. If you're getting the noise when the vehicle is stationary and while turning the wheel, I would check the pump and or steering rack. Again, happens also while driving so it kinda rules this out too.
    9. Member M Diddy's Avatar
      Sep 24th, 2002
      PA
      03-28-2011 01:42 PM #9
      I'll see if I can record the sound with my phone after work and post it up.
    10. Member cwwiii's Avatar
      Jun 18th, 2007
      West Hollywood, CA
      03-28-2011 02:13 PM #10
      Go to your dealership. I had this recalled on my CC. There are two wires inside the steering wheel that wrap around the column. They have know go to bad. That is most likely what has to be removed.
      I didn't hear it making noise at that time but the dealer found out when turning the wheel in stationary that it was making a slight clicking/rubbing noise in the steering wheel.
      As for me to hijack this thread: I'm hearing a creeking noise in the right wheel well when going about 2-5mph with no gas applied. It's only when turning the steering wheel all the way to the right. It doesnt happen when I'm going faster. Possible CV Joint, or rubber housing cracked are my only thoughts for my car.
      .:dubnoxious:.
      flickr
    11. Member M Diddy's Avatar
      Sep 24th, 2002
      PA
      03-28-2011 03:47 PM #11
      Quote Originally Posted by cwwiii View Post
      That sounds like it might be it.
      Nov 27th, 2009
      03-29-2011 01:41 AM #12
      Mine is making a light rubbing sound as opposed to a clicking sound. Will let my dealership take care of it.
      Sounds like a slight friction sound inside the steering wheel hub. My Eos is totally silent while turning the steering wheel.
    13. Banned Epence's Avatar
      Jan 7th, 2010
      Los Angeles
      2010 CC Sport, White Gold, DSG
      05-31-2011 11:05 PM #13
      any update on this, anyone?
      I started to experience the noise..
    14. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A mullet, a cracked piston, and an Espresso.
      05-31-2011 11:51 PM #14
      Sturt bearings/ mounts? Fender liners... Yup had that happen on the Jetta. CV Axles or boots?
    15. Member
      May 12th, 2010
      2010 CC Luxury
      06-01-2011 12:40 AM #15
      Quote Originally Posted by DavidPaul View Post
      Mine has the same sound. Did your dealer fix it?
    16. Member
      Mar 25th, 2009
      NOVA
      2012 CC R line, 61 Merc. 220b
      06-01-2011 12:41 AM #16
      my CC is making a noise too when i turn the wheel.. but this is coming from the steering wheel, and it sounds more like an electric whizz than anything else...what can it be? ive only had this car for 2 weeks...
    17. Banned Epence's Avatar
      Jan 7th, 2010
      Los Angeles
      06-01-2011 01:15 AM #17
      Quote Originally Posted by Lucian1988 View Post
      exactly what i'm experiencing; going to call to schedule an appointment.
    18. Member
      Apr 20th, 2011
      Southeast Florida
      2012 VW CC R-Line w/DSG
      06-01-2011 01:36 AM #18
      started 3 days ago with my 2012 with 1300 miles.
      Larry
      2012 CC R-Line, DSG (stock)
    19. Member dubious judas's Avatar
      Sep 22nd, 2010
      Sacramento, CA
      2008 Audi TT 3.2
      06-01-2011 04:02 AM #19
      I have this too but usually when the car is cold. Definitely from the steering wheel, sounds like something is wrapped around the column like cwwiii mentioned. I had the dealer check it before but they couldn't recreate the noise.
      2008 Reflex Silver GTI (TIE Bomber)
      2010 Reflex Silver CC R-Line (Star Destroyer)
    20. Member
      Mar 25th, 2009
      NOVA
      06-01-2011 08:34 AM #20
      ill just wait till i do my first oil change. dont want to make too many trips to the dealership right off the bat.
    21. Member M Diddy's Avatar
      Sep 24th, 2002
      PA
      06-01-2011 09:12 AM #21
      I never actually went into the dealer to fix it. I'm going to wait until my 20K service and have them look at it then.
    22. Member
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      06-01-2011 09:27 AM #22
      Most likely the clock spring. A lot of CC's and B6 Passat make this noise from the factory.
    23. Member milan187's Avatar
      Mar 15th, 2009
      On, Canada
      2015 GTI 6MT
      06-01-2011 09:54 AM #23
      I started hearing it too! Not sure if it was there before but I will mention it my next oil change.
    24. Member gospeed-racer's Avatar
      Aug 15th, 2003
      Meridian, ID
      80 rocco 16v/ 87 rocco 16v/ 09 CC 2.0T 6MT
      06-01-2011 10:00 AM #24
      have you done the electronic steering column lock recall, it cover 09-10 CC's.
      Don't know if it will fix your noise, but it might.
      Take a couple of hours for the dealer to complete.
    25. Member snobrdrdan's Avatar
      Sep 9th, 2008
      Southeast Michigan
      2017 VW
      06-02-2011 06:49 AM #25
      x2 on this
      Definitely comes from the steering wheel when making low speed turns
      Not really a big deal, but a little annoying
      2016 Tiguan R-Line
      2017 Passat R-Line
