Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 365
Thread: Koni Coilovers IN STOCK!!!! Sale by WRDUSA.com.
  1. 07-13-2011 12:21 PM #71
    Quote Originally Posted by dmbbilly41 View Post
    Thank you for the feedback. I really do appreciate it! You may be hearing from me soon...depending on what I find at WF
    Happy to help
    www.WRDUSA.com
    Great Deals on Koni, APR, Neuspeed, H&R, Techtonics Tuning, OEM Maintenance Parts, AND MORE!!!
    PM me for details or give us a call at 775-342-9591
  2. 07-13-2011 12:25 PM #72
    Quote Originally Posted by JZoidberg View Post
    WRD has excellent customer service and from what I found the best price if you want to go with the Konis. I've bought a couple of sets from them with no problems what so ever.
    I appreciate the feedback
    www.WRDUSA.com
  3. 07-15-2011 04:50 AM #73
    bump
    www.WRDUSA.com
  4. Member
    Jun 1st, 2011
    Philadelphia Pa
    DBP MKVI GTI
    07-15-2011 10:31 AM #74
    I currently live in Michigan and moving back home to Philly at the end of the year. Either way, the winters are horrible and salt is everywhere. I am pretty set on purchasing Koni's, but my only concern is rust and corrosion since they aren't SS. Any information on how to prevent corrosion and seizing? Will I have to constantly wash and clean them during the winter months? I read that many ppl grease the threads, but will this have to be done on a regular basis? Any info is appreciated!
  5. 07-15-2011 12:40 PM #75
    We have a lot of customers running these on the east coast and I rarely hear of any issues. And typically when there is a problem, it's with a set that hasn't been touched in years. You are correct that you want to use some sort of spray oil or grease on the threads to protect them. I typically recommend washing them and re-applying a couple times a year. Even if you get stainless coils, i would still recommend this same maintenance as I have seen perches seize up on SS coils as well (keep in mind there are a lot of different grades of stainless)
    www.WRDUSA.com
  6. 07-21-2011 01:11 PM #76
    bump
    www.WRDUSA.com
  7. 07-21-2011 02:41 PM #77
    Quote Originally Posted by CarNut84GTi View Post
    I am a complete noob when it comes to suspensions. What exactly, in terms of physical work and tools, does this require? Do I have to take it to the shop? Am I just able to do it with the jack that comes with the car?
  8. 07-21-2011 06:13 PM #78
    Quote Originally Posted by f00kie View Post
    the cleaning/regreasing doesn't really take any special tools. You will need to be reaching up into the suspension of the car so you DO NOT want it supported by just the factory jack. Basically, just jack the corner of the car up that your going to work on (i prefer an aftermarket floor jack, though the factory will get the job done), place a jackstand under that corner, hose off/wipe off the threaded section of the coilover (you may want to remove the wheel for ease of access, though this is not completely necessary), then re-apply the spray oil or grease that you are using to protect the threads. Be sure to turn the perches up and down a little to make sure you get the grease/oil between the perch and the threaded body.
    www.WRDUSA.com
  9. 07-23-2011 11:51 AM #79
    bump
    www.WRDUSA.com
  10. Member ChefBlake's Avatar
    Jun 5th, 2011
    Charlotte, NC
    2011 Jetta TDI 6-MT , 2000 Passat V6 4Motion
    07-23-2011 03:11 PM #80
    Will these work on the Jetta VI? If so, anyone have pics?
  11. 07-23-2011 05:32 PM #81
    Quote Originally Posted by ChefBlake View Post
    The standard Jetta VI does not have independent rear suspension, and therefore these will not work on it. I believe all sportwagons have IRS, and this kit will work on those.
    Basically, these will work on any MKVI with IRS, and will not work on those with the twist beam (non-IRS) rear suspension.
    www.WRDUSA.com
  12. 07-29-2011 03:21 AM #82
    bump
    www.WRDUSA.com
  13. 07-29-2011 06:30 AM #83
    newb here. will this fit a canadian spec 2011 golf wagon 2.5L?
    Thanks
  14. 07-29-2011 12:40 PM #84
    Quote Originally Posted by bcedhk View Post
    Thanks
    As long as you have independant rear suspension this kit should certainly work for you (to my knowledge, all golfs come with IRS, and all Jetta wagons here in the states also have it, though we don't have any golf wagons)
    www.WRDUSA.com
  15. 07-29-2011 05:12 PM #85
    bump
    www.WRDUSA.com
  16. 07-29-2011 05:49 PM #86
    Brand new MKVI.
    These work I believe right?
    I spoke to Koni the other day and they confirmed that they have never validated them on the MKVI.
    Would I need Strut Mounts/Bearings? $69... as mentioned on your website..
  17. 07-30-2011 08:24 PM #87
    Quote Originally Posted by power-san View Post
    Brand new MKVI.
    As long as you have an independent rear suspension, these will work on your car. This is the Golfs, GTI's, and Jetta Wagons. When the Jetta GLI comes out it should also have IRS. To my knowledge all standard Jetta VI's do not have IRS.
    Koni of North America may not have updated their fitment guide, but Koni worldwide has them listed for the MKVI (www.koni.com then click on worldwide)
    The mounts/bearings depend on the mileage on your car. They are just standard replacements so if your car has a low mileage, then you wouldn't need to, if you have a decent amount of mileage on your car, then you may want to consider swapping them out when doing the suspension.
    www.WRDUSA.com
  18. 08-05-2011 03:08 PM #88
    bump
    www.WRDUSA.com
  19. 08-06-2011 09:44 AM #89
    My coils came in 4 days at the slowest/cheapest rate. I was very pleased with whole transaction. WRD customer service is top notch. The Koni's are normally $1400 and I got them for $980. Really? This must be a dream.
    Thanks WRD!! I will be buying from you again.
    - What happens in Vegas, I brag about for years.
  20. 08-06-2011 09:29 PM #90
    Thank you for the feedback and more than happy to help Enjoy the coils
    www.WRDUSA.com
  21. 08-08-2011 03:24 PM #91
    bump
    www.WRDUSA.com
  22. Member v-dubIV's Avatar
    Jul 5th, 2003
    Mississippi
    2010 VW GTI / 2012 Audi A4 / PAST 1999.5 MKIV Jetta / 2000 MKIV Jetta / 2004 B6 Audi A4
    08-08-2011 08:45 PM #92
    the wife called me and said my Koni's were waiting at the door when she got home, can't wait to get home and check them out,
    Bump for fast shipping and great price!
    2010 CSG GTI DSG | APR Stage I ECU | APR/Carbonio Stage I & II Intake | APR RSC Cat-back | AWE T.O.P | Smoked Corner Markers | Koni Coilovers | VCDS
  23. 08-09-2011 03:01 PM #93
    Quote Originally Posted by v-dubIV View Post
    Enjoy
    www.WRDUSA.com
  24. 08-10-2011 04:29 PM #94
    bump
    www.WRDUSA.com
  25. Member
    Jun 1st, 2011
    Philadelphia Pa
    DBP MKVI GTI
    08-13-2011 07:59 PM #95
    I got my koni's on a few weeks ago. Absolutely love them! FTG 24 F and 24.25 R and they ride awesome. Now I want to go lower. It's very addicting! Once I get her washed I'll post pics. Anyway thanks to WRD for the fast shipment and great customer service.
    Only question I have is...is the lifetime warranty through WRD or Koni? The only reason I ask is because I never received the warranty card with the coils?
  26. 08-15-2011 10:40 AM #96
    Warranty is directly through Koni. I believe the warranty information is on the CD in the box. If you ever have any problems, all you need to do is call Koni's North American warranty center. You'll most likely need your invoice (if you don't have it, we can provide it for you, just send me a PM with your name)
    www.WRDUSA.com
  27. Member
    Jun 1st, 2011
    Philadelphia Pa
    DBP MKVI GTI
    08-15-2011 12:01 PM #97
    Great Thanks. Yeah I have the CD but never opened it yet and I have the purchase invoice from WRD in my email somewhere. Thanks again!
  28. 08-20-2011 06:07 PM #98
    Quote Originally Posted by tomasepley View Post
    Got them today as promised. Great service, thanks guys!
    www.WRDUSA.com
  29. Member prospal's Avatar
    Mar 8th, 2011
    Morris County, NJ
    2011 GTI
    08-20-2011 06:09 PM #99
    Anyone know if corrosion caused breaks are covered under warranty?
  30. 08-20-2011 10:50 PM #100
    Quote Originally Posted by prospal View Post
    What broke due to corrosion?
    Give Koni a call, they have a warranty center in Kentucky
    859-586-4100
    www.WRDUSA.com
  31. 09-01-2011 07:53 PM #101
    bump
    www.WRDUSA.com
  32. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    09-01-2011 09:01 PM #102
  33. 09-02-2011 12:54 PM #103
    Quote Originally Posted by Squirrel Nuts View Post
    www.WRDUSA.com
  34. Member v-dubIV's Avatar
    Jul 5th, 2003
    Mississippi
    09-03-2011 05:33 PM #104
    installed them today finally, awesome ride quality!
    crappy picture but you get the idea
    thanks agian
  35. 09-04-2011 05:00 PM #105
    thanks agian
    Looks good
    www.WRDUSA.com
