VWVortex.com - TT on FK Streetline Coilovers
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 62
    Thread: TT on FK Streetline Coilovers
      May 27th, 2010
      00 TTq
      02-26-2012 07:14 PM #26
      Does anyone have a picture of the rear with FK rear spring, no perch?
      I can't decide if I want to go; FK rear spring with no perch or AFCO spring, with perch.
      AFCO spring, no perch was too low last summer. Want a little better ride this time around.
      Reason why I ask is because I don't want to have to replace the stretch bolts if I don't like it the first time around.
      Feb 7th, 2009
      Homer NY / Syracuse NY
      2011 Touareg TDI / 1990/91 Audi CQ / 1991 Audi 200
      02-27-2012 03:27 AM #27
      stretch bolts? where are these stretch bolts? they all looked like regular bolts to me when i was doing the rear of my 225.
      now i'm scared i re-used a stretch bolt...
      i've been running these for about a few weeks now, i like the feeling of them, but i'm rubbing and it's annoying. i have spacers in the front and back to make the rim flush with the fender, so i believe i need to take a fender roller to it.
      Right now there's 0 gap, no tuck, so it looks perfect to me.
      I installed them with 20 threads left in the front.
      I threaded the perch and locker all the way up in the rear, but removed the white plastic spacer that the spring sits on. (b^tch to get off).
      Regardless, i'm going to install my summer wheels/tires and see if i'm still rubbing. these winter tires are a taller profile and are very rolly in the corners (and have studs in them). so traction is limited. could be a night and day difference. i really had no plan on driving the TT this winter but my cq is in project mode.
      after settling in a week
      there's a little rubbing around corners currently
      final product with my beefier winter tires (could be why i'm rubbing)
      2011 Touareg TDI Lux
      1990 Audi Coupe Quattro - Racecor 2.7T
      1990 Audi Coupe Quattro - S2 Rep 034 Turbo
      1991 Audi Coupe Quattro - Rallyx S2 2.3L
      1991 Audi 200 20vt - Parts or Sell
      May 27th, 2010
      00 TTq
      02-27-2012 06:35 PM #28
      I guess I will try the FK spring only then. That looks little lower than my setup right now, with perches in.
      I believe the stretch bolts are the ones that go through the rear shock.
    4. Member
      Nov 10th, 2009
      Houston, TX
      2000 Audi 180Q Aviator Gray
      02-27-2012 08:31 PM #29
      hey frostyflax, where did you get those headlights??
      May 4th, 2011
      Houston, TX
      2012 Passat, 2014 Fusion
      02-27-2012 09:22 PM #30
      @ frostyflax Love the wheels! I have the exact same ones. Very nice set up you got there!
    6. Member
      Feb 7th, 2009
      03-01-2012 11:15 AM #31
      Quote Originally Posted by Chuckmeister87 View Post
      i made them... not happy with the color or brightness of the led's. they're definitely visible during the daylight, but with them behind the osir clear lenses it gives them a blueish tint. they were pure white when i tested them (and brighter). so i'm going to see if i can redo them this summer with some bigger brighter 4300k led bulbs. The inserts are painted gloss black, and i sanded the crap out of the lenses and polished them. I moved the turn signals to the fog lights.
      Quote Originally Posted by vonnie77 View Post
      thank you, she's one of my babies. she has 4 rings, my g/f has 0.
    7. 03-02-2012 10:11 PM #32
      Quote Originally Posted by frostyflax17 View Post
      yeah, i know about if you have too soft of a spring and the shock is stiffer, you can wear your shocks out and vise versa.
      it's kinda like low, med, and high, you just want to make sure you don't mix a high and low. but a med with high or a med with low is ok for awhile.
      how do you think a bilstein is better then a fk? a proper ratio of spring rate to shock rate. bilstein just had the resources to figure out what was best.
      with me... it'll be more trial and error...
      i wonder if i could find an adjustable shock to fit in
      You must be joking right?
      Might as well stay stock instead of carrying out those demonic plans you laid out in past few posts.
      FYI there are stretch bolts ( torque to yield ) in various spots in the suspension. They are suppose to be "single use" items and only reused if you have a death wish.
      Feb 7th, 2009
      03-09-2012 11:48 AM #33
      to each there own. don't get your panties in a bunch about other peoples likes and dislikes.
      you apparently need to do some more reading into how suspension works. you MAKE custom suspensions, you MAKE them to your liking. just because it doesn't have a huge price tag and a name brand doesn't mean that it can't be good quality. don't be such a stickler calling my plans demonic.
      and i replaced the proper stretch bolts. it did not say in the Bentley i don't think that they should be replaced. so i asked around.
      once again, to each there own. i personally love the look of my car minus the silly blue led's right now. soon they will look more like the new TT's.
    9. 03-09-2012 05:26 PM #34
      you apparently need to do some more reading into how suspension works. you MAKE custom suspensions, you MAKE them to your liking. just because it doesn't have a huge price tag and a name brand doesn't mean that it can't be good quality. don't be such a stickler calling my plans demonic. .
      Yeah Marcus, maybe you should read this thread. Some guy named MadMax wrote it and it really helped me learn about the TT suspension. Maybe you could learn a bit about it too.
      I keep it bookmarked so I can read more as I understand more. I sure wish he was around still so I could thank him for taking the time to do all that writing!
      http://forums.vwvortex.com/showthrea...-TT-suspension
    10. Member
      May 7th, 2009
      A car plant somewhere in Aladamnbama
      01 TT225(daily) 01 TT225(project) 03 GTI 20AE (daily) Occasionally a new model Acura/Honda lol
      03-09-2012 05:44 PM #35
      Lol.
    11. Member Tempes_TT's Avatar
      Oct 23rd, 2010
      Monticello, MN
      2000 180q TT
      03-09-2012 06:07 PM #36
      Quote Originally Posted by 20v master View Post
      Lol.
      Im with this guy.
      Both you other dudes have lots and lots to learn...
      Marcus is a friend of mine and a very knowledgeable individual whether youd like to admit it or not. Learn a thing or two from this mysterious man.
      But youre right, your stuff, you do whatever floats your boat homie.
      /// GTX Build and Progression ///
      Quote Originally Posted by DCMS371 View Post
      You do realize women are biologically programmed to ruin men's lives by making them get rid of anything that they might enjoy more than spending time with the woman right?
      Quote Originally Posted by SchmidTT View Post
      Has anyone really been far even as decided to use even go want to do look more like?
    12. 03-09-2012 06:37 PM #37
      Quote Originally Posted by Tempes_TT View Post
      Im with this guy.
      If I am one of those "other dudes", I hope you noticed the
      Sarcasm is tough online of course.
    13. Member Tempes_TT's Avatar
      Oct 23rd, 2010
      Monticello, MN
      2000 180q TT
      03-09-2012 06:48 PM #38
      Quote Originally Posted by AlaskaTT View Post
      Yes, sarcasm is tough to grasp via simple text.
      I retract my former statement sir.
    14. 03-10-2012 12:04 AM #39
      what do you suggest? Maybe you can educate me
      On a serious note, (before you turn yourself into the subject of many jokes ) I didn't say what I said previously because I wanted to attack your knowledge or preference when it comes to suspension. I was simply trying to discourage you or anyone reading your "plans" from attempting something I know isn't as simple as you were putting it.
      If there is one person that has done custom suspension work on this platform it's me, and I can tell you it's more involved than simply swapping unknown springs on a shock with narrow valving that's not even suited to handle more than 1k of spring change in both direction. I have altered and customized pretty much everything in this suspension and gathered enough data along the way to tell you that your idea will handle worse than stock (wheel rate, natural frequency, valving bias in low and high speed velocities are all customized in my car. Swaybars, ball joint location, caster angle, static weight balance and even Ackerman angles are also modified by Me). I think I have successfully fabricated/designed enough parts, (that are not even available "off the shelf" for this chassis) to know what I'm talking about without needing to discuss credentials.
      Now, if you were suggesting re-valving a decent shock to accommodate more springs, this discussion would be totally different but your plan was nothing short of a butchered job. What would your wheel rate, critical damping and overall balance be? I just couldn't find a kinder word than "demonic" to explain how that setup would have handled, my apologies for my limited vocabulary.
      When or if you decide to change your original formula I'll gladly steer you in the right direction but for now I can only tell you that the following ain't going to work
      " if they're too soft... i'll swap in stiffer springs,
      not low enough? shorter springs.
      kidneys crying? stronger shocks "
    15. Member
      May 7th, 2009
      03-10-2012 02:54 AM #40
      Max has no patience. There are rules here, obey them. Lol
    16. Member Tempes_TT's Avatar
      Oct 23rd, 2010
      Monticello, MN
      2000 180q TT
      03-10-2012 10:11 AM #41
      Mind = Blown
    17. Junior Member shayan_tingy's Avatar
      Sep 6th, 2010
      California, LA
      2001/ TT 225Q
      03-10-2012 04:08 PM #42
      nice most likely their going to b my next setup
      TiNgYyY
    18. Member StateSideS3's Avatar
      Apr 13th, 2007
      NY
      01' S3, 01' TT 225 roadster w/Hardtop (sold), 03' Jetta (sold)
      03-10-2012 05:57 PM #43
      Quote Originally Posted by PLAYED TT View Post
      TT's dont go low in the rear on off the shelf coils
      i highly disagree
      I'm on Bilstein PSS9's coilovers that apparently dont go low at all, and I was tucking tire all around last season
      DubCult _ Florio Special _ S3
    19. Member StateSideS3's Avatar
      Apr 13th, 2007
      NY
      03-10-2012 06:04 PM #44
      pics for reference
    20. Member
      Feb 7th, 2009
      03-13-2012 03:08 PM #45
      sorry for my arrogance, i just got my panties in a bunch when someone called my crazy ideas demonic.
      I do a ton of research before i do any actual fabrication, so i wouldn't be following any of my previously stated plans to a T. I consult people like you who have done there research and base my plans off of that information. So once again, i apologize for the ignorance. I do know what i'm talking about most of the time. I just don't articulate it all into a forum where "most" readers are... lacking.
      I'll hit you up when i plan on dropping a heavier engine in the front of the TT and need to do some more research on the best custom suspension set up.
    21. 03-13-2012 03:12 PM #46
      No harm done bud !
      The madman is always there to help and steer you back in the right path
    22. Member
      May 7th, 2009
      03-13-2012 03:14 PM #47
      Quote Originally Posted by Marcus_Aurelius View Post
      No harm done bud !
      What you did there, I see it.
    23. Member
      Jan 25th, 2005
      Ottawa, Canada
      03-13-2012 03:21 PM #48
      Quote Originally Posted by 1.8tipgls View Post
      i highly disagree
      Quattro? and perches out?
      | BENPURKISSDESIGN |
      STANCE - Related words:
      hellaflush-hellafail-stanced-stancing-mental retardation-******s etc.
    24. Member PLAYED TT's Avatar
      Oct 17th, 2010
      LI
      The land of the rising sun
      03-13-2012 03:21 PM #49
      Gone but never forgotten: 2000GLX-2001TT-2000S10
      Soon to be gone and forgotten 2014Impreza
      flickr---I had a coolish car once
    25. Member
      May 7th, 2009
      03-13-2012 03:32 PM #50
      Quote Originally Posted by Neb View Post
      Quattro?
      His avatar says 225, so yes. Perches, he'll have to answer. lol
