Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 116
Thread: Park assist retrofit
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    04-04-2011 09:44 AM #1
    from the mk5 subforum, but thought it better to start a new one given that it relates specifically to a mk6...although probably 90% the same.
    Plan is to retrofit park assist to a mk6 without PDC.
    Needed:
    New park module (1T0919475H)
    addional wiring harness for Park assist switch in console
    addtional wiring for two addtional sensors in front bumper
    addtional sensors, and mountings
    coding
    Since the only documented retrofit is on a russian site, I'm still relying on maloosheck to give it a bash with him mk5 jetta, but thus far the fellow has not had a chance.
    Getting to you pDC module should you have one already, as below (pics compliments of Kufatec)
    Module is under the rain tray near the edge of the windscreen
    Remove rain tray
    Remove wipers. looks like there is an addtional bolt after the wiper removal under the rubber covers.
    Loosen indicated retainig nuts
    Remove wiper assembly
    Locate this cover underneith
    and there's the PDC module, or where the PDC / Park assits module will go.
    Sep 20th, 2010
    Austin, TX
    MKVI 2.5
    04-04-2011 10:47 AM #2
    Would be easier to just learn how to park your damn car...
    "Park assist"
    Apr 9th, 2007
    DC
    Too many to list here
    04-04-2011 10:55 AM #3
    man, at least I know how to remove mine now thanks to this thread
    Follow my MK1 build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
  4. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    04-04-2011 11:12 AM #4
  5. Member tony magnolia's Avatar
    Sep 21st, 2010
    Trash Smell, Jersey
    2009 Jetta GLI
    04-04-2011 12:36 PM #5
    Why would you put yourself through this?
    R135 _MKV & VI PM for Micro-CAN VAGCOM stuff
    ╚╬╬╣ Full APR Carbonio Intake|Loaded APR Stage 1 93|Eibach Pro-Kit|15% Tint|Black Badges|
    _246_Amber Side Markers|Black Mirror Signals|LED City Lights|Matching Race Baby Seat For My Seed|
  6. Member darin45's Avatar
    Feb 23rd, 2000
    Gilbert, AZ
    2012 Jetta SE and 2011 BMW 328i AWD
    04-04-2011 02:15 PM #6
    As a new parent, I can now see the usefulness of this if you are backing up and a child pops up behind your car since my conscience would KILL me knowing I backed over a kid. That being said, I dont have this feature in my car but its good to know you looked into it.
    **UPDATED! NOW 14 VW's since 1996...Yeah, I have a problem! **
    ____________
    2012 Jetta SE w/ Conv. Pkg- Stock for now....
    2011 BMW E90- 328i w/ X-drive
    Detroit Lions #1 Fan in Arizona
  7. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    04-04-2011 02:44 PM #7
    http://forums.vwvortex.com/showthrea...&highlight=BUC
    I'd rather have vision, than auditory warning only.
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
  8. Member darin45's Avatar
    Feb 23rd, 2000
    Gilbert, AZ
    04-04-2011 03:32 PM #8
    I would run this! Too bad I have the sh**y stock stereo...I hope to change this out soon, Zach!
    ____________
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    04-04-2011 04:04 PM #9
    Parking has little to do with it, just being able to do is the reason! That and having less blank spaces on the console above the gear lever...
  10. 04-04-2011 06:47 PM #10
    Thanks a lot Belox,
    Now i will by the parts and try to retrofit the park assist.
    Thank you
  11. Member Smrtypants44's Avatar
    Jul 30th, 2010
    Norman, OK
    2010 UG 2Dr GTI "Gus"
    04-04-2011 07:03 PM #11
    Quote Originally Posted by Code3VW View Post
    Park assist is on the front too.
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    04-07-2011 04:27 AM #12
    Let me know how you get on. Still trying to find the pin out for the PDC module, know I saved it somewhere.
    Side sensor for park assist has a different 'bracket' to the other four PDC sensors. If you find this park number, let me know! Can't see anything on ETKA, seems to marked as 'non-replacement part'
  13. 04-07-2011 05:10 AM #13
    Great thread. It will help to have wiring diagrams of your car and a car that has to go to configuration. If your car is a DSG, the coding in the Mechatronic could be different.
  14. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    Started NHTSA DSG Campaign/'09WolfieDSG died@623mi. VW took it back.Bought MkVI/GTI Blk 6spMT/SR/Xen
    04-07-2011 08:24 AM #14
    "There's nothing like a well tuned car on an open road". Paul Newman
    *The New 2011 VW Jetta... At Least You Pay Less To Get Less!*
  15. Junior Member
    Oct 17th, 2007
    South Africa
    '10 MKVI GTI - Tornado Red, Sunroof, Xenons
    04-09-2011 07:51 AM #15
    youve got too much time on hands mr belix
  16. Member
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    04-11-2011 04:12 PM #16
    Quote Originally Posted by rodga View Post
    If only - RVC camera install still awaiting final wiring...for 4 months now...and it only needs power and connection to reverse signal.
  17. Member
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    04-11-2011 04:24 PM #17
    Finally located PDC module pin outs. Would assume park assit module would be much the same, with some additonal pics used for addtional front sensors, and some for the parks assist switch most likley in the same area as the PDC switch.
  18. 04-12-2011 04:04 PM #18
    HI,
    I think that it can help us,
    I found a document, in deutsch, with the explanation of the Park assist components if you want i can send it to you, just tell me your email adress.
    regards
  19. 04-25-2011 09:10 PM #19
    Nice! Hopefully this isn't too hard, then I'll try to do it myself
    I'm about to retrofit PDC, so I wonder if I should wait to see if I can retrofit both at the same time?
  20. Member RichardNixonsHead's Avatar
    Aug 31st, 2009
    North Carolina
    '08 PG MkV Jetta SE 5m, '11 WGM JSW 2.5L SE
    04-25-2011 09:49 PM #20
    I gotta tell ya, our Passat SW is going back off lease in 2 months and I'm going to miss the packing sensors like mad! Don't get me wrong, I can reverse/parallel park my jetta sedan no problem but the sensors make it even easier to park the Passat and let you park in an even tighter spot!
    Thinking of getting a JSW TDi and would miss the sensors, so maybe this would be an option.
    2008 JETTA Plat Grey SE (OEM projector 3000K HID fogs, HID Headlights, dark side markers, LED interiors, GLI rear, trunk lip spoiler, Tinted LED tails, Amber Club )
    2011 JETTA SW 2.5L White Gold SE (W/17"WHLS & PAN ROOF)
  21. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    VW 2007 Jetta GLI, VW 2006 Jetta TDI, VW 2001 Jetta TDI, VW 1997 Jetta TDI
    05-09-2011 08:12 PM #21
    I think this diagram could help if you already have 8 OPS sensors:
    I'm planned to make this swap, I already installed the 8 OPS Sensors......but I will first retrofit the Tiguan RVC, then the Park Assist.
    I did swap my Steering Wheel for a new one and module with the CH one. I always got a soft error on the Steering Wheel Assist module that the Parking Assist is missing...so it is time to retrofit
    Hopefully my ABS works with Park Assist, I have ESP (1K0 907 379 AC ESP FRONT MK60 0101)and Jetta GLI model is 2007.
    Here is a list I compile so far:
    1T0 919 475 H Park Assist Unit
    000 979 009 E Wire to the Control Unit X2
    1K0 927 123 B REH Parking Switch
    4D0 971 636 Plug Parking Switch
    000 979 009 E Parking Switch Wire X3
    1T0 919 297 A GRU Park Assist Sensor X2
    1T0 919 133 C 9B9 Sensor Seal X2
    3C0 919 494 GRU Sensor Holder Right (This is just a guess for a Jetta)
    3C0 919 493 GRU Sensor Holder Left (This is just a guess for a Jetta)
    1T0 973 203 Sensor Plug X2
    000 979 034 Sensor Wire X3
    06A 972 741 Wire Seal X10
    1J0 973 714 8 Pin Bumper Plug from Car (switch form 6 pin to 8 pin)
    1J0 973 814 8 Pin Bumper from Bumper (switch form 6 pin to 8 pin)
    000 979 131 E From Car Wire (Related to 1J0 973 714)
    000 979 132 From Bumper Wire (Related to 1J0 973 814)
    IF you need; as my case, more space for the console buttons, 5 instead of 4 you need the EOS/Golf VI Console:
    5K0 857 961 9B9 Console for 5 Switches
    5K0 863 487 1QB Console Trim
    Last edited by NothernSky; 08-24-2011 at 04:01 PM. Reason: Bold part Numbers, added part numbers
    OEM+ FTW
  22. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    05-09-2011 08:25 PM #22
    Error when switch Module 44 Steering Assist to Parking Assist Installed:
    New Steering Module 1K0 953 549 CH
    Error:
    So it is time to retrofit Parking Assist
    OEM+ FTW
  23. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    05-09-2011 09:57 PM #23
    Mixed diagram with 8 OPS
    OEM+ FTW
  24. Junior Member JFranko's Avatar
    Apr 25th, 2011
    Columbus Oh
    2011 2-door GTI manual, 1992 Jeep Wrangler
    05-09-2011 11:36 PM #24
    Seems like too much of a hassle, I can tell how close I am to hitting something within a foot, and in any car I've driven with that feature (all chevys), the car starts beeping like crazy when you get that close.
  25. 05-10-2011 03:12 AM #25
    Can't wait for you to do it, please take pics!
    I hope this can be retrofitted to the JSW, I don't know if the difference in dimensions will be a problem, hopefully nto since the module is for Golf, EOS, Tiguan, etc...
  26. Member
    May 7th, 2011
    NoVA
    Various Variants
    05-10-2011 06:43 AM #26
    Not every obstacle is high enough/wide enough to see with mirrors. I have this on another car and it has paid for itself many times over.
    Any estimate on cost for this?
  27. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    05-10-2011 09:05 AM #27
    My estimate is $430 bucks IF you already have the 8 Optical Parking Sensors.
    The costly parts are the Control Unit of course ($157.38) and both Assist Sensors ($80.52 each)
    OEM+ FTW
  28. Member tony magnolia's Avatar
    Sep 21st, 2010
    Trash Smell, Jersey
    2009 Jetta GLI
    05-10-2011 11:08 AM #28
    I really don't understand the point of putting yourself through the hassle of this mod. But hey, I'm all for 'its your car, do what makes you happy.' That being said, post pics and good luck
  29. 05-10-2011 01:11 PM #29
    please do post some photos during installation and a guide to install it> please please
  30. Member
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    06-08-2011 12:58 PM #30
    thanks for the updates! Nice progress!
    Where is the steering module located? What version did you have before? Will check mine to see what version it is.
    Apart from that, someone seemed to find the part number for the bumper sensor holders.
  31. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    06-13-2011 11:39 AM #31
    Quote Originally Posted by Belox View Post
    It is located below the Steering Wheel, you have to remove the SW/Airbag and the lower SW cover.
    I had before this part number 1K0 953 549 AS.
    I'm wating from a friend in Germany to grab the parts and then I will try.
    Remember I will do this for a MK5, not sure about MK6 but should be similar I guess.
    Biggest question mark is the compatibility of the ABS Module in the cars that want to make this retrofit.
    OEM+ FTW
  32. Member NothernSky's Avatar
    Nov 24th, 2004
    Monterrey
    07-04-2011 10:39 AM #32
    Just Arrived
    3C0 919 488 GRU Sensor Holder Right (This is just a guess for a Jetta)
    3C0 919 487 GRU Sensor Holder Left (This is just a guess for a Jetta)
    OEM+ FTW
  33. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    07-04-2011 10:42 AM #33
    Quote Originally Posted by tony magnolia View Post
    x10000000
    Cool, but excessive.
  34. Member
    Jun 6th, 2010
    South Africa
    2010 GTI 6
    07-04-2011 01:25 PM #34
    looking good!
    Hoping local guys can get those sensor holders!
  35. 07-12-2011 05:21 AM #35
    Where are the wires??
