VWVortex.com - Park assist retrofit
    Page 2 of 6 FirstFirst 123456 LastLast
    Results 26 to 50 of 131
    Thread: Park assist retrofit
      May 7th, 2011
      NoVA
      Various Variants
      05-10-2011 06:43 AM #26
      Not every obstacle is high enough/wide enough to see with mirrors. I have this on another car and it has paid for itself many times over.
      Any estimate on cost for this?
    2. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      2011 Jetta TDI, 2010 Jetta TDI, 2007 Jetta GLI, 2006 Jetta TDI, 2001 Jetta TDI, 1997 Jetta TDI
      05-10-2011 09:05 AM #27
      My estimate is $430 bucks IF you already have the 8 Optical Parking Sensors.
      The costly parts are the Control Unit of course ($157.38) and both Assist Sensors ($80.52 each)
      OEM+ FTW
    3. Member tony magnolia's Avatar
      Sep 21st, 2010
      Trash Smell, Jersey
      2009 Jetta GLI
      05-10-2011 11:08 AM #28
      I really don't understand the point of putting yourself through the hassle of this mod. But hey, I'm all for 'its your car, do what makes you happy.' That being said, post pics and good luck
      R135 _MKV & VI PM for Micro-CAN VAGCOM stuff
      ╚╬╬╣ Full APR Carbonio Intake|Loaded APR Stage 1 93|Eibach Pro-Kit|15% Tint|Black Badges|
      _246_Amber Side Markers|Black Mirror Signals|LED City Lights|Matching Race Baby Seat For My Seed|
    4. 05-10-2011 01:11 PM #29
      please do post some photos during installation and a guide to install it> please please
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      06-08-2011 12:58 PM #30
      thanks for the updates! Nice progress!
      Where is the steering module located? What version did you have before? Will check mine to see what version it is.
      Apart from that, someone seemed to find the part number for the bumper sensor holders.
    6. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      06-13-2011 11:39 AM #31
      Quote Originally Posted by Belox View Post
      It is located below the Steering Wheel, you have to remove the SW/Airbag and the lower SW cover.
      I had before this part number 1K0 953 549 AS.
      I'm wating from a friend in Germany to grab the parts and then I will try.
      Remember I will do this for a MK5, not sure about MK6 but should be similar I guess.
      Biggest question mark is the compatibility of the ABS Module in the cars that want to make this retrofit.
      OEM+ FTW
    7. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      07-04-2011 10:39 AM #32
      Just Arrived
      1T0 919 475 H Park Assist Unit
      1K0 927 123 B REH Parking Switch
      1T0 919 297 A GRU Park Assist Sensor X2
      3C0 919 488 GRU Sensor Holder Right (This is just a guess for a Jetta)
      3C0 919 487 GRU Sensor Holder Left (This is just a guess for a Jetta)
      OEM+ FTW
    8. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A Few Alphas
      07-04-2011 10:42 AM #33
      Quote Originally Posted by tony magnolia View Post
      Why would you put yourself through this?
      x10000000
      Cool, but excessive.
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      07-04-2011 01:25 PM #34
      looking good!
      Hoping local guys can get those sensor holders!
    10. 07-12-2011 05:21 AM #35
      Where are the wires??
    11. Member
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      07-26-2011 05:03 AM #36
      Which wires?
    12. 08-01-2011 12:57 AM #37
      Any update about this existing error ? 03075
      HOT HOT HOT !!!! MK7 MFSW with CCS https://www.youtube.com/watch?v=JQ8c...ature=youtu.be HOT HOT HOT
    13. 08-01-2011 08:16 AM #38
      Which wires?
      The wiring harness or the extra wires that needs to be attached with the park assist unit.
      one more question is that do I need to replace Parking sensor controller to install this? And also do provide me with a step by step guide to install it. please..
      thanks
    14. Member
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      08-08-2011 07:00 AM #39
      Northernsky posted the wiring diagram a few posts above. If you already have OPS, you'll need to add the two side sensors, extra console switch, and yes, change the control module.
    15. n00b
      Nov 2nd, 2010
      France
      Skoda Octavia 2 FL 2010 Elégance Xénon 1.6 TDI CRFAP
      08-08-2011 11:03 AM #40
      Hello, I'm new into this forum and sorry I'm French so, I speak english for expose my problem.
      I have on my Octavia 2 Facelift year 2010 retrofitted OPS parking system and it work perfectly and I want to retrofit Park Assist but when I use VAG.COM for coding the module 44, I have this error message :
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Control Module Part Number: 1K0 909 144 J
      Component and/or Version: EPS_ZFLS Kl. 69 3001
      Software Coding:
      Work Shop Code: WSC 73430 790 00999
      VCID: 3147C7F0D40C
      1 Fault Found:
      03075 - Parallel Parking Assistance Control Module (J791)
      004 - No Signal/Communication
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 3
      Fault Frequency: 1
      Reset counter: 26
      Mileage: 25877 km
      Time Indication: 0
      Date: 2014.14.07
      Time: 02:10:23
      Freeze Frame:
      Voltage: 11.63 V
      DD
      Temperature: 29.0°C
      RPM: 0 /min
      Speed: 0.0 km/h
      Speed: 0.0 km/h
      Count: 0
      I have an MK60EC1 ABS module and a module 10 1T0919475C
      Why this message appear please ?
      Very thank
      Regard
    16. 08-09-2011 04:31 PM #41
      Hi, newby here! picking up my golf R(with rns510) in thr morning 6 months old and with the wifes driving need to fit the ops asap, but found this thread and will hold off a while and do the full park assist with ops in one hit i think. Looking forward to a full step by step if possible!! it may just about save the bumpers being painted every month
    17. Member
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      08-09-2011 05:28 PM #42
      Trying to find some reference to my ABS module in ETKA, but so far not found anything with the same part number - looking at illustration 614-10. It shows the part number as 1K0 907 375 maybe it's somewhere else in ETKA??
      For my MK6, my ABS module is 1K0 907 379 AJ. I scanned another GTi with park assist and his ABS module part number is 1K0 907 379 BE, but his car was a later model, so not sure if this is just a running change, or specifcially needed for park assist.
    18. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      08-24-2011 04:06 PM #43
      I just got the remainig parts and updated the part list since the Sensor Plugs were wrong.
      Here is another Park Assist thread from a German forum for a Passat retrofit.
      http://www.passat3c.info/cms_neu/index.php?page=176
      I will try to install soon, but time is not enough these days.
      OEM+ FTW
    19. n00b
      Nov 2nd, 2010
      France
      08-26-2011 06:00 PM #44
      I have retroffited Park Assist on my Octavia 2 Face Lift and it work very well
      http://forumskoda.forumactif.com/t16...el-park-assist
    20. Member CaTcH21's Avatar
      Mar 21st, 2007
      South Africa *sigh*
      08-26-2011 06:16 PM #45
      Very useful info here , thank you kind sir !
    21. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      08-30-2011 11:15 AM #46
      Just only to be prepared if my ABS Control Module does not work MK60 (1K0 907 379 AC) I bought this used Control Module which is MK60EC1 (1K0 907 379 AJ). I hope there are no compatibility issues.
      Waiting the part from German eBay:
      http://www.ebay.de/itm/ATE-VW-ESP-St...-/120673873117
      I will install the Park Assist with the current ABS Module and report back, if it fails, I will install the MK60EC1 version and expect results.
      OEM+ FTW
    22. 09-09-2011 05:20 PM #47
      Quote Originally Posted by NothernSky View Post
      Did you try it? Did it work?
    23. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      09-09-2011 05:46 PM #48
      Im still waiting for the MK60EC1 ABS unit from Germany, nontheless I will install with the current ABS, but I want to have it ready the replacement in case it does not work.
      OEM+ FTW
    24. Member
      Jun 6th, 2010
      South Africa
      2010 GTI 6
      11-01-2011 05:56 PM #49
      Any updates señor Sky?
    25. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      11-05-2011 01:39 PM #50
      Not yet since I got troubles sourcing the ABS Module, good news is that I will get it next Monday.
      It will take me some time to install since I recently got married, so I need to put my head back on the track
      OEM+ FTW
