VWVortex.com - Park assist retrofit
    Page 5 of 6 FirstFirst 123456 LastLast
    Results 101 to 125 of 133
    Thread: Park assist retrofit
    1. Member bonestockgtx's Avatar
      Apr 20th, 2000
      Vancouver, BC
      2008 Passat Wagon, 3.6 4mo
      03-09-2013 02:14 AM #101
      Just thought I'd follow up. 35mm is too big unless you plan to paint after cutting the hole and want to leave some room. If you drill to 35mm you will have a dark circle around the holder which doesn't look right to me.
      If you want one that fits the holder PERFECTLY call a STARRETT distributor and order an SM34, which is actually 1 11/32" hole saw (they are discontinued in NA but as of today Starrett still has some around). The sensor holders pushed into the hole cut by this saw snugly and I couldn't be happier. I'll post a pic in the next day or two.
    2. 03-27-2013 08:18 PM #102
      Hey all,
      Long time car lover, first time VW owner looking to share my experience with this retrofit. Im new to this forum and typically dont post on threads...but for the benefit of those still wondering if this retrofit can be accomplished with NA vehicles (at least in my case, a MY2013) I thought I should share my experience.
      I own a 2013 US Spec MK6 GTI Autobahn. Im pretty handy when it comes to vehicle maintenance, mods, etc, and this retrofit seemed like a doable weekend job.
      My goal was to install the OPS and PLA Parking Assist (Semi-automatic parallell parking), interface the whole system with my previously installed back up camera and have it all displayed correctly on my RNS 315.
      Rear View back up camera was purchased from ECS Tuning
      http://www.ecstuning.com/Search/ES2562622/ES2562622/
      OPS and Parking Assist 10 sensor kit was purchased from CarSystems
      http://www.carsystems.pl/vw-golf-mk6...ist,id560.html
      I did about two weeks of nightly research for others that had completed the same mod. For the most part, information found in other threads got me through the bulk of the job. Some Issues I wanted to note are as follows...
      -The wire harness from CarSystems was too short on the front bumper. I basically had to cut the harness in half and extend it 12inches...not a big deal, just annoying.
      -Nobody mentioned the possibility of needing to shave/trim the hard foam insert that sits behind the bumper cover. The location of two sensors required that foam insert to be trimmed slightly.
      -Tapping into the Powertrain CAN BUS via the Gateway was not an option for me, that wiring bundle was far too tight and buried deep inside my dash, soldering a splice was going to be difficult. Tapping into the AFS behind the glove box however, was extremely easy. If AFS module is available to you I highly recommend going that route. The glove box removal isnt too bad...took me about an hour to wrestle it out.
      -For me, it seemed difficult to find the correct coding for this system, in the end I figured it out but not before feeling a little pain.
      As far as coding goes, this is what worked for me: (sorry for the text only, I have screen shots but dont have the permissions to post attachments) I gleaned this from others on several forums and basically played with my car until it worked...
      Enable the Park/Steer Assist module (Address 10)
      Open "10-Park/Steer Assist" Module, Select "Coding-07", Open "Long Code helper",
      Byte 0, check Bit 4 and 5
      Byte 2, I selected Golf Plus... (Seemed like closest thing to my car available in the drop down menu)
      Next I opened the "44-Steering assist" module
      Select "Adaptation-10", Select "UP" button until channel "4" (Installation Park Steer Assist) is displayed.
      "stored value" will be "2" (park/steer assist not installed), this needs to be changed to a "1" (park steer assist installed MY 2010 PLA 1.5/2.0)
      Select "Test", then select "Save".
      And really thats about all it took for me to get it working correctly. Ive tested it several times and parking assist works! The vehicle will identify a suitable parking space and make the necessary turn inputs for you to make the maneuver. All 10 sensors operate correctly, and the vehicle with sensor obstacle indication is displayed next to the image of my rear view camera on the RNS 315 (some said I would have to toggle between two screens but this was not true for me)
      My final Auto Scan is listed below... Hope this helps someone!
      I would like to post a video of my vehicle performing its parallell parking maneuver but I dont have the proper permissions yet... Maybe I can post it to you tube and provide a link...
      Wednesday,27,March,2013,21:28:35:35975
      VCDS Version: Beta 12.10.3
      Data version: 20130228
      Chassis Type: 7N0
      Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 2E 37 42 44 46 47 52
      55 56 62 72
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      05-Acc/Start Auth. -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      10-Park/Steer Assist -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      2B-Steer. Col. Lock -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
      Part No SW: 1K0 907 115 AS HW: 1K0 907 115 AA
      Component: 2.0l R4/4V TFSI 0020
      Revision: AAH18--- Serial number:
      Coding: 0403010A1C070160
      Shop #: WSC 01357 011 00200
      VCID: 77D30A410641C3A6BEF
      No fault code found.
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 02E-300-0xx.lbl
      Part No SW: 02E 300 058 P HW: 02E 927 770 AL
      Component: GSG DSG AG6 512 3513
      Revision: 05651213 Serial number: 00001211170907
      Coding: 0000020
      VCID: 27731A0196619326EEF
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
      Component: ESP MK60EC1 H31 0152
      Revision: 00H31001
      Coding: 114B600C492400FB881106EB921F0041B70800
      VCID: 7DDF1869E47DE9F6E43
      Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
      Part No SW: 5K0 959 434 B HW: 5K0 959 434
      Component: VWKESSYPQ35GP 086 1101
      Revision: 00086000 Serial number: 0195253123
      Coding: 030C0C
      ASAM Dataset: EV_KESSYPQ35G A02013
      ROD: EV_KESSYPQ35G_AU21.rod
      VCID: 3449FD4D9FB7E8BE5BD
      Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
      Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
      Component: AC Manuell H20 0505
      Revision: 00001018
      Coding: 0010002002
      ASAM Dataset: EV_ACManueBHBVW36X A01010
      ROD: EV_ACManueBHBVW36X_SK35.rod
      VCID: 7BDB1671F269E7C6DA7
      Address 09: Cent. Elect.
      Cannot be reached
      Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
      Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
      Component: PARKHILFE PLA H08 0116
      Revision: -------- Serial number: 13901206700517
      Coding: 30010B
      Shop #: WSC 12345 123 12345
      VCID: 48B1B9BDFB3F7C5E075
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
      Component: AirbagVW10G 014 0726
      Serial number: 003L4R014FSH
      Coding: 00004737
      ASAM Dataset: EV_AirbaVW10SMEVW360 001026
      ROD: EV_AirbaVW10SMEVW360.rod
      VCID: 3C59D56DB7E720FE93D
      Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
      Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
      Component: LENKS.MODUL 016 0140
      Revision: FF010041 Serial number: 20121212301521
      Coding: 1012140000
      ASAM Dataset: EV_SMLSNGVOLWSXS A01004
      ROD: EV_SMLSNGVOLWS.rod
      VCID: 7DDF1869EC7DE9F6E43
      Multifunction steering wheel control module:
      Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
      Component: E221__MFL-TAS H30 0032
      Coding: 830000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5K6 920 973 C HW: 5K6 920 973 C
      Component: KOMBI H05 0705
      Serial number: 00000000000000
      Coding: 270D01
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
      ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
      VCID: 3753CA418EC103A67EF
      Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
      Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
      Component: J533 Gateway H52 1634
      Revision: H52 Serial number: 131212F1000683
      Coding: 350002
      VCID: 74C93D4DD737A8BE9BD
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H05 0705
      Coding: 000007
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
      ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
      VCID: EAF5A3350DF3EE4EB11
      Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
      Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
      Component: ELV-PQ35 H21 0240
      Revision: 00000000 Serial number: 12000007035001
      Coding: 4900000000000000
      ASAM Dataset: EV_ELVMarquMPVW36X A01001
      ROD: EV_ELVMarquMPVW36X.rod
      VCID: 3041F15D6BAFD49E3F5
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
      Component: SG EXT.PLAYER H19 0550
      Revision: A1001003 Serial number: 7663972093
      Coding: 020100
      VCID: 2A75E3354573AE4EF11
      Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
      Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
      Component: RNS315-NAR H58 0319
      Serial number: VWZAZ2M0028200
      Coding: 04050041010000000000100A
      ASAM Dataset: EV_RNS315NARV2UDS 001705
      ROD: EV_RNS315NARV2UDS.rod
      VCID: 256F1009246D8136DC3
      Data medium:
      Subsystem 1 - Part No: 3AA 919 866 B
      Component: NAR_V3_(0037) 0037
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
      Component: Tuer-SG 009 2119
      Coding: 0001204
      VCID: 3147F459A8A5DD9630B
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K0 909 144 P
      Component: EPS_ZFLS Kl. 74 3305
      Revision: 00H22000
      VCID: 3753CA4146C103A67EF
      Address 46: Central Conv.
      Cannot be reached
      Address 47: Sound System (R12) Labels: 5K0-035-456.clb
      Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
      Component: KonzernAmp 8K H07 0368
      Revision: -------- Serial number: EAA085A0051939
      ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
      ROD: EV_AudioVerst8KanalBNO1.rod
      VCID: 29771C394875A556F8B
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
      Coding: 0001204
      VCID: 3245FB55ADA3E68E491
      Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
      Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
      Component: AFS-Steuergeraet 0148
      Revision: 00H04000 Serial number:
      Coding: 1446940
      VCID: 3449FD4D57B7E8BE5BD
      Subsystem 1 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul l 0004
      Coding: 00000022
      Subsystem 2 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul r 0004
      Coding: 00000022
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
      Component: Tuer-SG 007 2101
      Coding: 0001168
      Shop #: WSC 01357 011 1012552
      VCID: 354FC0495CCDF1B66C3
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
      Coding: 0001168
      VCID: 364DC74541CBFAAE659
      End ---------------------------------------------------------------------
      Apr 27th, 2011
      San Diego
      2012 CW GTI Autobahn w/DSG
      03-27-2013 09:59 PM #103
      ^ awesome. If you lived near me I'd buy the parts and ask for your help How long did it take total for the installation? I already did the RVC so I'd only have to do the OPS/park assist.
      2012 Candy White GTI w/Autobahn and DSG
    4. 03-28-2013 08:22 AM #104
      Im actually from CA originally, the Antelope Valley to be exact... But im military currently stationed overseas, definitely far from the states!
      The install took me about two full days to complete. Im pretty slow with these things and Id have to stop, run upstairs and check to make sure I wasn't about to break a part that was being stubborn....those snags really dragged out the install time.
      I could do it in half the time now that I know how each part is removed. If you decide to do it I can lay out the step by step sequence I used to accomplish it. But if you're by yourself id give yourself the weekend.
    5. 03-29-2013 09:36 PM #105
      Oh man! Me too, if you were closer I'd soooo ask for your help!
      Are you coming back to Cali any time soon?
    6. 03-30-2013 10:47 PM #106
      pennywise330,
      After everything was said and done, does the car park itself?
    7. 03-31-2013 10:15 AM #107
      Quote Originally Posted by unixb0y View Post
      pennywise330,
      Yes sir, It most definitely does. It was actually very startling to see the steering wheel spinning through its maneuver by itself.
      And thats really the only reason ive posted to this thread...ive read and been told several times that the mod cant be done (the automatic Parallel parking maneuver), Or that I would need to change my ABS module or some funky programming.... In my case here... I definitely only needed the OPS+PDC retrofit kit and some programming via VCDS.
      My only complaint so far is the system doesn't always identify a suitable parking spot.
      In the kit from CarSystems all the sensors are identical (10 total), but ive been told the OEM kit has different part#'s for the two addition Park Assist sensors. Also the kit came with the standard sensor brackets/holders for the Park Assist sensors instead of angled brackets that place the sensors more perpendicular to the surveyed area. Maybe changing the sensors and brackets will make my system more accurate?
      Sorry for the long answer to your question... yes it works...usually very well. But at times it doesnt identify a parking spot that I think it should, and sometimes it maneuvers the wheels a little close (for my comfort) to the curb.
      Jul 29th, 2012
      Jetta MK6 1.4TSI 122HP
      04-09-2013 03:56 AM #108
      pennywise330, you need 2 x http://www.carsystems.pl/vw-pla-sens...97a,id361.html
      As a sensor's bracket you can use 3C8919399 / 3C8919400 from CC
      The new PLA upgrade Kitt contain the corect Park Assist sensors and brackets.
      http://www.carsystems.pl/vw-golf-mk6...ade,id649.html
    9. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      04-09-2013 09:57 AM #109
      Quote Originally Posted by ronniejamesdio View Post
      What else do you need to get this to work? That kit only comes with 2 sensors, so I'm guessing you will need a few more sensors...
      EDIT - Nevermind, I found this on that site: http://www.carsystems.pl/vw-golf-mk6...ist,id560.html
      I wonder if the harnesses are long enough to compensate for the extra length of a MK6 Golf Variant (Jetta Sportwagen) over the regular Golf...
      OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
      Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
    10. Member
      Jul 29th, 2012
      04-09-2013 03:54 PM #110
      don't buy this:
      there are 10 PDC sensors instead of 8 PDC + 2 PLA sensors
      The right combination is:
      http://www.carsystems.pl/vw-golf-mk6...ops,id376.html
    11. Member
      Jul 29th, 2012
      04-11-2013 04:02 AM #111
      Quote Originally Posted by pennywise330 View Post
      The answer is YES.
    12. 04-11-2013 09:20 PM #112
      Quote Originally Posted by Code3VW View Post
      More than that I wonder if the system actually knows the different dimensions of the JSW and compensates how much it needs to turn/move accordingly, if it was originally designed for the Golf
    13. Member
      Jul 29th, 2012
      04-14-2013 04:20 AM #113
      Yes, the system will turn the steering wheel acordingly with the length of the car. It communicates on the CAN BUS protocol. First, the system will scan the parking space to see if the car can park there accordingly with the length of the car, different from Golf to JSW but the system know that it is installed and working for a Golf or for a JSW or for a Jetta MK6 because the CAN BUS protocol tells to it the length of the car.
      The system is for Golf6 because the parking unit is designed for Golf6 - 1T0919475P but you can use the system on Passat B6, JSW which is 90% a Golf, Jetta Sedan, GLI, etc
      For Passat B7 the parking unit is 3AA919475L.
      The main reason that they are not interchangeable is the ABS pump which is different from Golf/JSW/Jetta MK6 to Passat.
      cbx750p user already manage to install PARK ASSIST system on a Jetta MK6:
    14. Member
      Jul 29th, 2012
      04-17-2013 09:34 AM #114
      Finally, the entire correct PLA kitt:
      http://www.carsystems.pl/vw-golf-mk6...ist,id665.html
    15. Member
      Mar 28th, 2007
      iowa
      07 uni black rabbit
      06-03-2013 01:45 AM #115
      this thread has had quite the run. reviving it again...
      anybody think the sensors would be able to tolerate some body filler around the edges to smooth them into the bumpers? i figure density-wise it's about on par with a high-build primer, which you'd presumably use when painting them anyway. i really want the parallel park assist to protect my wheels, but i can't stand those dots.
      also, does this actually require an RNS unit? i've read conflicting info.
    16. Semi-n00b
      Oct 10th, 2010
      Poland
      06-03-2013 08:11 PM #116
    17. 07-07-2013 01:27 AM #117
      Please tell me this is possible on the MKV R32 if i change my ABS module to the BE version and install the entire PLA kit????
    18. Member tamorgen's Avatar
      Dec 1st, 2003
      Columbia, MD
      2001 VW Jetta Wolfsburg 1.8t (RIP), 2007 VW GLI 2.0T, 2013 Touareg V6 TDI Exec
      07-09-2013 11:12 AM #118
      Quote Originally Posted by Stylist07 View Post
      It should be possible, if the ABS can be retrofitted and coded correctly. There is another thread that has been trying to do that, but I haven't heard if anyone has put it all together yet. PLA has been done on MKVI Jettas & Golfs, but I don't know for sure if anyone has done it on a MKV yet.
    19. Member
      Jul 29th, 2012
      08-12-2013 07:26 AM #119
      You can ask cbx750p user. He already installed PLA on a MK5 GTI 2009
    20. Member tamorgen's Avatar
      Dec 1st, 2003
      Columbia, MD
      08-12-2013 11:48 AM #120
      I tried emailing a while ago...never heard back. The obsitcle for all of us with a MKV is procedure and confirmation of the ABS controller retrofit.
    21. Member 91Z28's Avatar
      Jan 17th, 2011
      Denver
      2010 GTI, 2001 Jeep Wrangler, 1991 Z28
      08-12-2013 01:48 PM #121
      How does this work on a manual transmission car ?
    22. Member
      Jul 29th, 2012
      08-31-2013 02:48 AM #122
      Doesn't matter if it is manual or automatic transmission. The driver will select the right gear and will control break and acceleration.
      This is a video for manual transimission.
      http://youtu.be/--16sRIyPz8?t=1m4s
    23. Member
      Jul 29th, 2012
      12-16-2013 09:10 AM #123
      Finally, installed:
    24. 03-27-2014 12:32 AM #124
      Quote Originally Posted by NothernSky View Post
      Mixed diagram with 8 OPS
      Which one is the parktronic switch, and which one is the parking assist switch?
      And for last, which is the left PLA sensor and which is the right one?
      Regards
    25. Member superwtc's Avatar
      Feb 19th, 2006
      NJ
      2016 s3
      05-29-2014 11:55 AM #125
      Will this kit also work on my NA 2013 GLI?
