VWVortex.com - how easy is it to DIY AC recharge?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 37
    Thread: how easy is it to DIY AC recharge?
    1. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      2015 VW Golf Sportwagen SE TDI - 6spd
      04-05-2011 06:32 PM #1
      was quoted $140 to have my AC system recharged with up to 2lbs of freon. just wondering its is an easy DIY job to just buy freon from an auto parts stores and do it myself. anyone have a write up?
    2. Member ABAcabby's Avatar
      Jul 28th, 2003
      Issaquah, WA
      '81 Rabbit 1.6l diesel
      04-05-2011 06:43 PM #2
      Doesn't the shop have to be certified to do an A/C recharge? They need to do a pressure leak test... I believe that is only when using Freon though.
    3. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      04-05-2011 06:44 PM #3
      Quote Originally Posted by ABAcabby View Post
      Doesn't the shop have to be certified to do an A/C recharge? They need to do a pressure leak test... or is that just with the old freon type A/C units.
      i think you're right. thats why it would take a couple hours, to include a pressure test
    4. Member
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      04-05-2011 06:44 PM #4
      Quote Originally Posted by WhiteTDI View Post
      You can do it but you should use some gauges to watch how high the high side gets and low the low side gets. On a hot day a VW a/c system in Mk5/B6 chassis should suck down between 30-40. I can't remember how high it should go to.
      If you over fill your a/c system it won't work either. You can not really regulate the amount of oil injected into the system either.
      Most Mk5/b6 chassis compressors only use 550 +/- 25 grams.
    5. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      04-05-2011 06:45 PM #5
      if you think you can, then by all means, go ahead!
    6. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      04-05-2011 06:53 PM #6
      Quote Originally Posted by thygreyt View Post
      yeah thanks. if i can do urmom, i'm sure i can do my AC.
      Jun 18th, 2008
      Maryland
      04-05-2011 07:11 PM #7
      You can easily do it but you shouldn't need to recharge your AC unless you have a slow leak somewhere. Get a the system tested for leaks prior to recharging the system. It would be a waste of money to keep recharging a leaky system.
      Contrary to what people believe...freon, or most refrigerants, never go bad. They can go for years without replacement.
    8. Awaiting Email Confirmation 845ryders's Avatar
      Oct 31st, 2010
      845 City Of King's
      2007 VW 2.5 Jetta Wolfsburg
      04-05-2011 07:17 PM #8
      its should be 134a i believe. i do hvac for a living. if your charge is weak and you only need a little. a bottle from autozone could do it. its like 35 bucks. has a guage built in. if its a major leak. we use to use nitrogen to shoot the system to find the leak. but after you will need to vac the system and remove the contaminated oils. its not hard. where you located?btw 140 isn't bad if they will find the issues.
    9. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      '66 Impala '07 Silverado Crew Cab '09.5 G8 GT
      04-05-2011 07:26 PM #9
      Quote Originally Posted by 845ryders View Post
      140 is a good price and it does get leak tested
      NEK '07 Chevy Crew Cab. Formerly CorradoG60
      '66 Impala 3 on the tree (sold)
      '09.5 G8 GT
      '74 F250 High Boy
    10. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      04-05-2011 07:30 PM #10
      i'm in the Los Angeles area. let me clarify, i don't think my system is leaking. i'm sure its just low on freon after having been used a lot over the last 60K of driving i've done. so basically i was thinking about just buying can(s) of freon and adding it myself.
    11. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      04-05-2011 07:40 PM #11
      How do you know, did you ask your AC?
      Go buy the cans, **** up your system cause you don't know what you're doing. Then pay a **** ton of money when you could of done it right the first time and paid the $140
      '09.5 G8 GT
      '74 F250 High Boy
    12. Awaiting Email Confirmation 845ryders's Avatar
      Oct 31st, 2010
      845 City Of King's
      04-05-2011 07:43 PM #12
      Quote Originally Posted by CorradoG602 View Post
      lmao corradog602 your a good dude. your informative and make me laugh when i read some of the **** you write.
    13. Member ABAcabby's Avatar
      Jul 28th, 2003
      Issaquah, WA
      04-05-2011 07:43 PM #13
      I believe Freon is no longer used in cars as it's pretty toxic (hence the leakdown test). 134A is the only thing that normal uncertified consumers can buy. It doesn't blow as cold as freon, but if you're just looking for something to refill it .. 134A is the stuff you need, and you'll be doing everything legally (not that they would ever find out, but whatever).
      Still can't really help with the actual process of refilling it though (removing oils and stuff.. wouldn't even know where to begin) lol.
    14. Member ACEdubs's Avatar
      Apr 18th, 2002
      South Florida
      04-05-2011 07:47 PM #14
      Are you fuking 12!!??! Shut the fuk up!
      Quote Originally Posted by Binary Star View Post
      Should've been more explicit - she likes to share me. Not the other way around....
      PSN: ACEdubs
    15. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      04-05-2011 07:49 PM #15
      my bad, i didn't realize this forum is full of cocksucking rednecks. sorry if i mis-used the word "freon" instead of 134A.
    16. Member WhiteTDI's Avatar
      Jan 16th, 2010
      Salt Lake City, UT
      04-05-2011 07:50 PM #16
      Quote Originally Posted by ACEdubs View Post
      NO thanks. and practice what you preach... tool
    17. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      04-05-2011 07:59 PM #17
      I still call it freon....but what ever. I'm trying to give you insight but I see you're acting like a child and disrespecting me and calling me a redneck. Listen pal you probably think a redneck is white trash. They are way different you fool. I've been working on VW's for 8 years and have forgotten more than you'll ever know. And since you people are such cheap bastards and won't take FREE advise I hope you **** your car up and have to pay a lot of money to replace your mistake. Then you'll put your tail between your legs and go to the dealer. Then argue with the dealer on the cost of fixing you're own mistake and call them liars and thieves. There is an easy road and hard road, you are taking the hard road. BYE
      '09.5 G8 GT
      '74 F250 High Boy
    18. Member
      Jun 18th, 2008
      Maryland
      04-05-2011 08:01 PM #18
      It doesn't matter how much you use your AC...you should NOT have to add refrigerant unless you have a leak...period.
      My 1985 190e has over 180k and has never had an AC recharge.
      My 2001 Honda Prelude had over 170k and never needed an AC recharge...I owned it for 8 years.
      Have it checked...you obviously have a leak.
    19. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      04-05-2011 08:04 PM #19
      Quote Originally Posted by omegared24 View Post
      **** him, he's being a bitch, won't take advise. Next he'll say you have a bunch of POS hondas because he has no clue what he's talking about.
      '09.5 G8 GT
      '74 F250 High Boy
    20. Awaiting Email Confirmation 845ryders's Avatar
      Oct 31st, 2010
      845 City Of King's
      04-05-2011 08:05 PM #20
      134a is still freon. its chemically different. its just "environmentally friendly. there are a crap load of freon types. r12 was hauled on production . but still obtainable at a astronomical price. 20lb bottle is over a grand. i do commercial and residential.but this thread took a bad turn so im done here. lolcorrado is a good dude was trying to help ya bro. thats all
    21. Member
      Jun 18th, 2008
      Maryland
      04-05-2011 08:08 PM #21
      You are probably right...we still want others to learn though
    22. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      04-05-2011 08:18 PM #22
      Yeah I remember when I was in college and used to deliver auto parts for some extra money on weekends we had to lock that **** up in a cage and have the customer sign for it when delivered. People were getting robbed for freon. The R134a is still bad when come in contact with a human. I saw a tech I used to work with get sent to the hospital when a schrader valve cracked when he was servicing the AC system. Since the R134a is heavier than air he had to be held upside down so it would get out of his lungs
      '09.5 G8 GT
      '74 F250 High Boy
    23. Awaiting Email Confirmation 845ryders's Avatar
      Oct 31st, 2010
      845 City Of King's
      04-05-2011 08:20 PM #23
      yup. just think i got the best of both worlds. deal with freon and propane and fuel oil daily. freeze burn sucks bad.
    24. Member goin2fast's Avatar
      Mar 23rd, 2006
      Doylestown Pa
      Trying to remove everything OEM on 06 GTI
      04-05-2011 08:39 PM #24
      What year is your car. the 06 and early 07 had bad compressors. Might not be your charge
    25. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      04-05-2011 08:58 PM #25
      Quote Originally Posted by goin2fast View Post
      Only on 2.0T's where the compressor would lock up sending "black death" through the AC system where the compressor, receiver drier, and expansion valve need to be replaced along with an AC system flush
      '09.5 G8 GT
      '74 F250 High Boy
