VWVortex.com - Rev hang... what actually causes it?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 39
    Thread: Rev hang... what actually causes it?
    1. 04-06-2011 12:34 AM #1
      So I have done a search on this topic and only found the solution of a bad clutch sensor. (For those that don't know what rev hang is, it in the hanging/increase in rpm when the clutch is pushed in to shift gears).
      My cars cruise didn't work when I got it so I installed a new one and cruise worked afterwards (which if the sensor was no good, it wouldn't).
      I'm sure I'm not the only one with this happening to them, so what are other people doing to solve it?
      Thanks in advance!
    2. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-06-2011 02:46 AM #2
      Just an idea...but try a throttle body alignment.
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    3. Member schwartzmagic's Avatar
      Apr 29th, 2007
      MIA
      2011 Jetta TDI; 05 VW Jetta GLI 5857BT
      04-06-2011 10:45 AM #3
      The Uni 830 file I have gives me rev hang. Not too bad, but it is annoying. Its gotten worse lately but that might be because of my exhaust leak
    4. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-06-2011 11:06 AM #4
      Quote Originally Posted by schwartzmagic View Post
      I hear people blame rev hang on exhaust leaks too. And I noticed that as my exhaust leak got worse, the rev hang got worse. I'm fixing my exhaust leak SOON and so I'll report back if the rev hang goes away. Maybe the engine is getting bad data from the O2 sensors, and as such doesn't run all that great.
      My Build
      Jan 20th, 2010
      Cleveland, OH
      01 Jetta Wolfsburg
      04-06-2011 11:19 AM #5
      Depends where the exhaust leak is. If it's after the first o2 sensor, it doesn't really matter as much. I've been told the rear o2 is there for nothing other than the OBD2 scan to tell e-check if your cat is working/there.
      Front o2 does the engine management stuff as far as air/fuel.
    6. Member elRey's Avatar
      May 15th, 2001
      16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
      04-06-2011 11:37 AM #6
      vagcom block #66. check second(or third) value while pressing/depressing clutch pedal. one of the bits should toggle 0/1
    7. Member herb2k's Avatar
      Jul 29th, 2007
      Vancouver, BC
      2001 GTI 1.8T, 2006 Jetta 2.5L
      04-06-2011 02:58 PM #7
      Quote Originally Posted by elRey View Post
      I had that problem. Replaced clutch switch F36 ($50 part from dealer) and all was good!
    8. 04-06-2011 03:02 PM #8
      My car is all stock and there is definately no exhaust leak. I will have to see what the stealership wants for a TB allignment as I don't have Vagcom (or Ross Tech or whatever its called now).
      I guess my next question, is there somewhere to pick up the Vagcom/Ross tech program for a cheaper price? I see its 249 on Ross techs site.
      Or is there a different program I can get that will allow me to diagnose and adjust the computer?
    9. Member 01TornadoWolf's Avatar
      Jun 17th, 2009
      Winooski, VT
      2001 Jetta 1.8T Wolfsburg Edition
      04-06-2011 05:26 PM #9
      look at block 66: http://www.ross-tech.com/vag-com/m_blocks/060-069.html
      if u dont have vagcom, check around. i guarantee someone local has one.
      i had nasty rev hang but my cc still worked. block 66 showed clutch signal at ecu wasnt changing. clutch switch was fine, actually turned out to be my ecu!
      | 802 |
    10. Member Three3Se7en's Avatar
      Jul 1st, 2007
      Mississippi
      02 337. 08 F150
      04-06-2011 06:00 PM #10
      My eurodyne 630 flash has nasty rev hang.
      2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
    11. 04-12-2011 11:01 AM #11
      So I got lookin a little further... I have 3 PCV hoses that are completely $%@#ed. Ordering some new ones from 034Motorsport this morning. Hopefully this is my problem.
    12. 04-17-2011 10:12 PM #12
      Got all my hoses changed but still no luck gettin rid of the rev hang. I'll be getting chipped by APR in 3 days so I will have to try that throttle body alignment after that and post my findings
    13. 04-26-2011 12:00 PM #13
      Tried the throttle body adaption and still no luck. The hang is definately less noticable with the apr program running, but it is still there.
      Any other ideas?
    14. Member schwartzmagic's Avatar
      Apr 29th, 2007
      MIA
      04-26-2011 02:00 PM #14
      Have you tried checking for exhaust leaks or pressure testing your charge pipes? Just a thought......
      I had all kinds of issues because of a boost leak right off the coupler on the compressor housing. My axle was rubbing on the tbolt clamp that tightens the coupler on the compressor exit and eventually got eaten away by the axle, no more clamping = boost leak. The boost leak was throwing off my idle and AFRs.
      Sent from my MB860 using Tapatalk
    15. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-26-2011 02:43 PM #15
      I second this. I hear people saying on here all the time that they 'checked' and have no leaks. But to know you gotta test. Not just eyeball it or feel around.
      Turbo cars do not like air leaks. They live on the air. They get angry when you take or give air at the wrong times.
      My Build
    16. Member
      Jul 24th, 2006
      Alexandria, VA
      05 VW Gti 1.8T, 16 Mustang GT Premium PP
      07-21-2014 11:13 AM #16
      How much would each of those things cost?
      The throttle body alignment and the pressure test on the charge pipes?
    17. Member burkechrs1's Avatar
      Nov 30th, 2008
      Minden, NV
      2001 VW GTI 1.8t Pag billet 3071r
      07-21-2014 11:46 AM #17
      Quote Originally Posted by RafaGti View Post
      If you know of a VW specific shop (not dealership) you may be able to go there and they can do a throttle body alignment with a VAG-COM. Takes about 60 seconds. The pressure test, shouldn't cost you more than $40 to make one, as long as you have access to compressed air.
    18. Member
      Jul 24th, 2006
      Alexandria, VA
      07-21-2014 01:16 PM #18
      Quote Originally Posted by burkechrs1 View Post
      Thanks for the help. Ill start looking for a place to get this done. Ive already replaced the switch and its still holding/reving between gear changes.
    19. Member David_Tedder's Avatar
      Oct 23rd, 2005
      Tdot/Barrie
      MKIV AWP, 08 TL-S 6MT
      07-21-2014 03:09 PM #19
      I also experience this and would love to see what the outcome is
      My Build: 1.8L AWP PPT GT3071r Billet Wheel Tial Vband/8:1 Mahle Pistons/Arp Mains/IE H-Beam Rods/ACL coated Bearings Mains & Rods/ARP Everything/Fluidamper/IE Manual Timing Kit with Gates Belt/AEB head/Supertech Intake/Supertech coated Exhaust/Supertech Spring & Retainer kit/IE CVA1 Cams/IE Cam Gear/SEM Mani/Hemi TB/EV14 1000cc/ CM FX400
      PAG PARTS
    20. Member gitman's Avatar
      May 13th, 2004
      FMY, FL
      IY 20th AE GTI (totaled), 2012 DBP Golf R
      07-21-2014 03:27 PM #20
      Quote Originally Posted by David_Tedder View Post
      have you also replaced your clutch position switch? i think the tell-tale symptom for this is if you disengage cruise control by pressing in the clutch, and witnessing the RPMs not only hang, but climb up before finally going down.
      edit: i used this DIY: http://forums.vwvortex.com/showthrea...l)-replacement
      2012 DBP Golf R
      2003 IY 20th Anniv 1.8T GTI #2545 (totaled 6/16/2015 )
    21. Member
      Jul 24th, 2006
      Alexandria, VA
      07-21-2014 03:47 PM #21
      Quote Originally Posted by gitman View Post
      Yes sir. I tried the pressing the clutch in and the revs did climb before eventually going down.
      Its so annoying, specially in the upper RPM range if youre tryiing to shift even remotely fast or hard.
    22. Member gitman's Avatar
      May 13th, 2004
      FMY, FL
      07-21-2014 03:56 PM #22
      sorry, my question was directed at David_Tedder who did not specify whether he had done the clutch switch.
      2012 DBP Golf R
    23. Member David_Tedder's Avatar
      Oct 23rd, 2005
      Tdot/Barrie
      07-21-2014 06:27 PM #23
      I haven't done the switch because up until today and seeing this thread I hadn't put much thought into what was causing it as there is too many things changed with my build
      PAG PARTS
    24. 07-22-2014 03:03 AM #24
      I had rev hang when I used a 70mm TB with an Eurodyne file for 60mm TB, with a maffless setup.
      Once the correct 70mmTB file was flashed, the rev hang dissapeared, in spite of the bug with the clutch switch (a bug in the software disables the switch, this only affects the CC).
    25. Member
      Feb 21st, 2004
      Stanceville
      94 Jetta scrapin pinch welds
      07-22-2014 04:35 AM #25
      Quote Originally Posted by rogerius View Post
      Wait wait.... Eurodyne software... has a bug?
