Just make it stop. It's like Chinese water torture, these Jeep pickups. Just ****ing put it in the dealerships already.
#1
http://www.trucktrend.com/features/n...ent/index.html
The JK8 Independence kit will be available this summer from Jeep/Mopar! No pricing yet.
#2
Now go get your shinebox
#4
I like it, but Jeep should just quit pissing around and build their Nukizer 715 concept instead.
93 Passat wagon VR6T FOR SALE http://forums.vwvortex.com/showthrea...6T-Edmonton-AB
I have my fears, but they do not have me.
#5
That thing is way too wide! Look at the picture with the parking spaces that would never fly. Hummer got away with it, because there arent very many of them. It's still a cool truck concept though.
Also wranglers have always been narrow for a reason. Something that big would be pointless unless you're in the desert or mud.
#8
The Cooking Animal is my side project: a blog for horngry food geeks. Check it out!
#9
#10
The AEV Brute conversion for the TJ is around $9K. I would expect the JK8 to cost similar.
http://www.quadratec.com/showcases/aev/brute/
#11
Don't find that attractive at all. It needs some styling to the bed.
Step in the right direction, at least.
#12
Aren't very many Hummers? What part of the world do you live in? They're as common as a Frod Focus around here.
It has a standard Wrangler windshield. And some wider flares. It's no wider than most full sized pickups. And for those that do venture offroad, not all Jeep offroading requires a narrow Jeep.
I'd take it over the JK8 any day, even if it meant I couldn't squeeze between trees.
#13
im thinking it will be less since the brute also comes with a bed while the jk8 is just a cab close out it will prob be closer in price to a rubitrux conversion at $3k-$5k
http://rubitrux.com/conversions.htm
*also technically the rubitrux is just the cab closeout on the brute without removing the back half of the jeep and putting a bed on and the price includes labor
#14
#15
I don't have anything constructive to add, but...
Love me some Brute. They make me feel funny.
2007 Passat Wagon 6MT Package2 Sport | 2006 Cummins Ram 6MT | 1993 B13 SE-R | 1987 E30 325is | Rhygin Juke HS
#16
#17
#18
#19
#20
Dempsey Bowling
Sales Consultant at Doug Smith Dodge/Chrysler/Jeep/Ram/Subaru/Kia/used (800) 553-3099
My fleet: 91 Miata, 98 Wrangler Sport, 12 Soul +, 89 Voyager turbo, 06 Mustang GT, 01 Suburban 2500 8.1L
#21
Dempsey Bowling
#22
That is if you also want the 5.7 Hemi, highline fenders, hood, etc. right? If you just want only the pickup conversion, but keep the 4.0 and the stock body panels and only put 31's on there, did all the fab work yourself, I assume it would cost considerably less, no?
#23
#24
My co-worker retained the stock engine, transmission and axles. You can clearly see that he upgraded to the high fender kit, but remember: he got his hardware--all of it--at his company's wholesale cost... which means he didn't spend any more money at AEV than you would if you just bought the basic kit. So you aren't saving any money there compared to him.
But what about the lift? He did all that installation himself (since he had years of experience doing this for his company), so there was no labor for that. The lift kit, again, he got for wholesale cost... so he spent less than you're thinking he did.
The elephant in the room is the body shop labor. As I mentioned, you have to cut the frame in the center of the vehicle, graft in extensions, then you have to cut the frame at the rear and extend that, also. But what's worse is modifying the tub itself. This isn't some redneck sawzall maneuver you rush right through. You have to drill through lots of body welds, carefully separating the external body shell from the inner body, then make like a surgeon and cut both pieces so they match the Brute kit. Then you get to weld it all together and grind it smooth so it looks OEM. After that, prime, paint and clearcoat for a nice finish. (You did remember to completely gut the entire interior before you started, didn't you?)
AEV claims the kit takes 60 hours to install. Matt says that would only be true if you already have experience building dozens of Brutes. For your first time out, Matt says it takes 200 hours of labor to do it right. Sure, you could half-ass it in a few places to try and save some time, but the end result would clearly demonstrate your impatience (or inexperience) and it would look... well, half-assed.
Matt sums it up best when he says he cannot imagine someone building a Brute for less than $35,000 (including the donor Jeep, which he only paid $8500 for) since he is in his more than that. In my opinion, the only way you'd undercut that price is if you (a) are a professional body man with decades of experience so you don't have to farm out the body work, (b) an experienced mechanic who can properly modify suspensions and such so you don't have to farm that out, either and (c) you can also get all your parts from every vendor at wholesale cost.
Dempsey Bowling
#25
#26
Just for fun, let's look into that. How much labor could really be involved? And how expensive could it really get? Well, here's a real world example.
Warn (as in the company) decided they wanted a bad ass Brute. So they delivered a stock Wrangler to AEV along with a Warn front bumper/winch combo. "Build us a Brute that kicks ass," they said. So AEV did. Here's what Warn got in return:
In addition to the "mere" Brute kit, they also installed the high clearance fender upgrade, plus a 6" long arm lift, plus the wheels and tires, plus Portal-Tek axles with ARB air lockers front and rear, and--since we're spending money--they tossed in the 5.7L Hemi conversion as well. Tah-dah! Here ya go, Warn.
How much did AEV bill Warn for their handiwork? $125,000.
Now obviously that hardware came at a hefty cost. Nevertheless, the labor is a significant cost in building a Brute... one which should not be dismissed lightly.
Dempsey Bowling
#27
Oh man, how I want portal axles. Badly want portals. Theres $12K+ in axles alone in that Brute. Personally, If I were going to look for a single cab, midsize pickup for off road use, a Brute wouldnt be it. I would pick up a Defender 110 HCPU or an FJ45 (much more comfortable than the 110). That would eliminate all of the frame/ body/ sheetmetal modification needs (plus, I think theyre a little cooler).
You think you hate it now. Wait til you drive it.
#28
#29
I think your first example of your friend Matt was a better "real world" example than that beast built for Warn. It comes at no surprise that it cost that much to build a TJ with custom axles, suspension, drivetrain, etc. And have someone else do ALL the work for you.
Edit: Not trying to knock you thought, thanks for sharing both examples![]()
#30
I'm thinking this kit will land some where between 10-15k, easily.. It's "MOPAR" I mean look at the third party campers they used for for the "Jeep wrangler" the pop up ones.. the actual retailer who makes them sells them for nearly 5k less I believe.. an no difference except for some Jeep logos and colours..
But saying that.. I gotta trade the 2 for a 4 door now![]()
#31
#32
If you want to buy a vehicle like the JK8 and not do the work yourself, then check out the JGMS J8. JGMS builds military and industrial Jeeps for foreign govts., logging companies, and private security firms. The JK8 body is basically a J8 in kit form.
http://www.jgms.com/
#34
The real question....is it macho? And if so....is it mucho macho?
#35
Those would be awesome if we could actually get them in the US. I threw up examples of ones that you can find in the US and are street legal. You can import them as mine trucks, etc... but then they arent on road legal. There are a couple people, most notably Proffitts Cruisers, who are taking 70 bodies and putting them on 60 or 80 series frames (still cheaper than building a Brute).
The Honcho is too big. Thats a full size Jeep built on a proper truck chassis not starting life off as a regular Jeep.
I have never seen the CJ pickup (besides a Scrambler half cab) like that before and I thank my lucky stars. MAN, that thing is UGLY. I just put two, sub $20k mid size pickups for an example of what you can do for less money. Both are readily available and both have a killer aftermarket to support them and both can be made to be pretty comfortable, even though they are a tad bit older.
