VWVortex.com - 2000 Jetta VR6 VAG Results
    Results 1 to 9 of 9
    Thread: 2000 Jetta VR6 VAG Results
      Jan 16th, 2010
      Brantford, Ontario
      2001 Jetta TDi
      04-13-2011 10:21 PM #1
      Here's what the scan came up with.
      VAG-COM Version: Release 409.1-S
      Chassis Type: 1J - VW G/J/B Mk4
      Scan: 01,02,03,08,16,15,17,19,22,35,46,56
      Address 01: Engine
      Controller: 021 906 018 M
      Component: MOTRONIC ME7.1 G 6760
      Coding: 00031
      Shop #: WSC 93119
      1 Fault Found:
      16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
      P0140 - 35-10 - - - Intermittent
      Readiness: 0000 0000
      Address 03: ABS Brakes
      Controller: 1J0 907 379 R
      Component: ASR 20 IE CAN 0001
      Coding: 13204
      Shop #: WSC 00066
      5 Faults Found:
      00290 - ABS Wheel Speed Sensor: Rear Left (G46)
      16-10 - Signal Outside Specifications - Intermittent
      04-10 - Mechanical Malfunction - Intermittent
      00287 - ABS Wheel Speed Sensor: Rear Right (G44)
      Skipping Address 15-Airbags
      Address 17: Instruments
      Controller: 1J0 920 800 J
      Component: A4-KOMBIINSTR. VDO V58
      Coding: 07362
      Shop #: WSC 93119
      IMMO-IDENTNR: VWZ7Z0Y2208197
      No fault code found.
      Address 19: CAN Gateway
      Controller: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 00066
      Address 46: Central Conv.
      Controller: 1J0 959 799 AJ
      Component: 61 Zentral-SG Komf. 0001
      Coding: 04096
      Shop #: WSC 00066
      2 Faults Found:
      00943 - Heated Exterior Mirror: Driver Side (Z4)
      35-00 - -
      00944 - Heated Exterior Mirror: Passenger Side (Z5)
      35-00 - -
      End --------------------------------------------------------------------------------------------------
      I changed the rear wheel bearings about 6 months ago but didn't touch the rear ABS sensors. Kind of odd that they are both showing an issue.
      The O2 sensor code was unexpected because I have no CEL, but poor gas mileage and a bit of a rough idle. Which sensor is it?
      What does the heated mirror reading mean? Switch or mirrors themselves?
      Thanks for your help.
      RB
    2. Former Advertiser
      Mar 18th, 2011
      Newnan, GA
      09 TSi Jetta, 04 R32, 95 Jetta VR6
      04-14-2011 09:11 AM #2
      B1 S2 is bank one sensor two meaning the rear oxygen sensor, after the catalyst, passenger side if there are two. Note, the fault is intermittent. So its working some of the time. I'd look into testing that sensor. But it will be difficult due to the fact that it is working correctly at this time.
      Rear ABS wheel speed sensors. When you replaced the bearings, did you swap over the wheel speed rings? Some of the bearing kits only come with the hub/bearing assembly and require you to swap over the wire mesh cage looking sensor rings. Also, if the distance between the sensor pickup and the ring is to big this can cause the outside tolerance fault as the ABS module is having a hard time reading the wheel speed. As well, if you have two different tires on the rear, depending on the overall diameter differance, this can cause one wheel speed to read higher or lower than the other one and confuse the ABS module.
      The mirror faults are just the heaters being burned out. The heated coil in both mirrors are open circuit. Simply replace them and clear the fault.
    3. 04-14-2011 09:49 PM #3
      This content Vacated by Jack
    4. Member
      Jan 16th, 2010
      Brantford, Ontario
      2001 Jetta TDi
      04-15-2011 06:25 AM #4
      Sorry, I'm a bit new to VAG. What is VCDS Lite?
      Feb 25th, 2010
      Wilkes-Barre, PA
      04-15-2011 10:04 AM #5
      First off The O2 after the cat shows a problem. Clear the code and repost scan if it comes back? It's not that major if the Check engine light isn't on. The L.R. R.R. Wheel speed sensor need to be checked. First actually take a good look at them and wiring at the wheels. Then log into the ABS control module and look at the sensors and turn the wheels and see if the ABS see's wheel speed. ABS are known to go bad and set false wheel speed sensor codes, so you want to be sure it's the speed sensor before replacing them. If you can't have a pro check them first and tell them to scope the sensors before replacing them. If they scope good the module or wiring maybe bad. Google the part # of the ABS module and you will find out all you need to know about rebuilding ABS and it's common problems. Heated mirrors most likely your car doesn't have them so you get a code, don't worry about it. Jack means go to ross-tech and download newest VSCD lite and install it on your PC. And rescan your car with the latest version. Good Luck
    6. 04-15-2011 02:43 PM #6
      It is the newest version of VAG-COM for the interface.
      Go here to get it.
      http://www.ross-tech.com/vcds-lite/download/index.html
      Best,
      Jan 16th, 2010
      Brantford, Ontario
      2001 Jetta TDi
      04-16-2011 10:54 AM #7
      Ok, thanks guys. I do have heated mirrors, but they don't work, so the code explains that. My ABS light comes on on the dash but not all the time, and no cel for the o2. I will look at the abs sensors and login to the module and spin the tires as was suggested.
      Again, thanks for the help.
      Jan 16th, 2010
      Brantford, Ontario
      2001 Jetta TDi
      04-16-2011 10:56 AM #8
      Quote Originally Posted by Jack@European Parts View Post
      Go here to get it.
      Best,
      Do I need to register this or will the shareware version do what I need?
    9. 04-16-2011 04:36 PM #9
      Shareware version is limited.
      I would recommend getting a registered licensed version.
      It will help me help you.
      Best,
