VWVortex.com - Brake pad warning lights
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: Brake pad warning lights
    1. Semi-n00b
      Apr 13th, 2011
      pheaton 3.0d V6
      04-15-2011 12:50 AM #1
      My warning lights keep coming on for my brake pads. Took it to my dealer who checked it over confirming that all the pads are fine. Still happening tho. Any solution, any one?
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-15-2011 04:50 AM #2
      Easy diagnosis: disconnect individually each of the connectors to determine which wheel is faulty. This will give you an idea of where the short is taking place.
    3. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-15-2011 10:26 AM #3
      Hi Pierre:
      I don't think your idea will work. The brake service message works by detecting a discontinuity (an interruption in the circuit) of the single wire leading to and then from the brake pad.
      If you disconnect any one of the connectors, you will see a continuous brake service message.
      A much easier way would be to run a diagnostic scan and see if the vehicle reports which of the four wheels is sending the message (I'm not sure if it gets that granular, but it can't hurt to try).
      An alternative method would be to create a jumper plug that MAKES the circuit across the connection where it plugs into the brake pad, and then try using this jumper plug on each of the four wheels - checking individually to see when the warning message disappears.
      Michael
    4. Member
      Oct 27th, 2005
      Pittsburgh & Boston
      2005 Phaeton V8, 2014 CC 3.6 Executive, 2017 Jetta SE manual (among others)
      04-15-2011 10:32 AM #4
      About 10kmiles ago I had the same experience: brake pad light stubbornly on, but visual inspection indicating there was still enough material for maybe another 7-10kmiles. I changed the pads anyway, since at almost 50kmiles I felt I had gotten excellent service from them, and the light wnet off immediately and has been off ever since. I think the moral of the story is that the sensors are designed to give ample warning long before the pads are completely worn out.
      Stefano
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-17-2011 11:54 AM #5
      Quote Originally Posted by PanEuropean View Post
      Hi Pierre:
      THis does not sound correct to me.
      The way brake service messages work is by embedding a small wire in the brake pad, so that when the brake pad is too thin, a contact is made between the wire (that now protrudes from the pad) and ground (the brake disk).
      So the car is expecting a contact to take place, and not an absence of contact (or, as you say, a discontinuity in the circuit).
      Having an interruption in the circuit means the pad is healthy, as it prevents the contact from taking place.
      So, disconnecting the wire would make the car think that the pad is good.
      Disconnecting all wires should remove all warning, unless, there is a short between the wire leading to the brake sensor and some part of the car.
      Either the short takes place between the brake sensor connector and the car computer (in which case it can happen anywhere in the wire mesh) or (more probably) the problem lies in the sensor.
      Reconnecting each wire one by one should tell you which wire is faulty (connecting the faulty wire will light the brake warning).
      P.
    6. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-17-2011 12:21 PM #6
      Hi Pierre:
      Unless I have grossly misunderstood the principle, there is continuity in a new brake pad, and when the brake pad eventually wears down, it wears through the wire and breaks the continuity - rather than establishing continuity.
      I suspect that we are probably both in agreement about the general concept, but are using different terms to describe it.
      Michael
      Brake Pads - New and Worn (indicator wiring at top)
    7. Member Prince Ludwig's Avatar
      Mar 23rd, 2007
      London, UK
      2005 Phaeton V6 TDI, 2003 Mercedes CL55K, 2002 Passat W8
      04-17-2011 12:56 PM #7
      After having a spurious brake pad warning after changing all my pads and discs last year, I can confirm that the system works the way Michael says. Any break in the circuit activates the warning.
      Harry
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-17-2011 03:18 PM #8
      Err.... Then, there must be 2 wires and not only one.
      On my old merc, there was one wire only, that lit up a lamp when the wire was touching the surface of the disk.
    9. Member n968412L's Avatar
      Apr 23rd, 2009
      Holcombe Brook, UK
      2014 3.0TDI Phaeton; 2009 1.4 Tiguan;2013 Take Up!
      04-17-2011 03:47 PM #9
      I think if you look carefully you could believe that there are actually two wires in a common sheath. In the self study guide (posted in a thread regarding long life servicing recently) there is a circuit diagram that shows the two wires.
      self study guide here: http://www.volkspage.net/technik/ssp/ssp/SSP_224.pdf
      Regards
      M
    10. Member Prince Ludwig's Avatar
      Mar 23rd, 2007
      London, UK
      04-17-2011 04:52 PM #10
      Quote Originally Posted by Zaphh
      Err.... Then, there m]ust be 2 wires and not only one.
      Yup, the old Mercs do work like that (or at least the W140 I have some experience with does...) but if you look at a worn sensor pad from the Phaeton, you'll see two little copper points where the wire has worn away. I think the logic is that once the sensor is worn, the warning is displayed constantly rather than just when you press the brake pedal.
      Harry
    11. Member n968412L's Avatar
      Apr 23rd, 2009
      Holcombe Brook, UK
      04-18-2011 12:08 AM #11
      Quote Originally Posted by Prince Ludwig View Post
      Harry
      And also if there is a fault in the circuit it fails safe with the warning light coming on, forcing you to investigate.
      M
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-18-2011 10:31 AM #12
      So you should then be able to check the circuits by unplugging all four sensors, jumping them with a small wire (this should remove the pads light) and then, as you reconnect each sensor, find out which is the faulty one.
      P.
    13. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-18-2011 11:03 AM #13
      Quote Originally Posted by Zaphh View Post
      Exactly! (But this presumes the fault is in the pad unit, not the vehicle side of the wiring...)
    14. Member
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-18-2011 12:05 PM #14
      This will also tell if the fault is in the vehicle, if all sensors are jumped and the light is still on.
    15. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-18-2011 03:01 PM #15
      Correct, it will indicate that the fault is in the vehicle, but it won't indicate WHERE the fault is in the vehicle.
      So - let's hope the fault is in one of the brake pads, or; that a diagnostic scan will reveal which corner of the car is reporting a fault.
    16. Member ruddyone's Avatar
      Feb 9th, 2009
      Barrington, IL
      04-18-2011 03:35 PM #16
      Perhaps check that the wires are in place. I actually had a sensor wire brake which caused the sensor to go off. Unfortunately, some of those wires are built into the pad which caused me to replace the entire pad. Another possibility (although remote) is that the wire came unplugged.
      Best regards,
      Nate
      No. Try not. Do... or do not. There is no try.
    17. Junior Member Phaeton_owner's Avatar
      May 17th, 2014
      Europe, Lithuania, Vilnius
      2007, VW Phaeton V6 3.0 TDI quatro
      01-19-2015 01:02 PM #17
      Hi folks,
      the "check brake pad" light appeared in dash panel. As all we know diagnostics doesn't show which of brake pads,front or rear, it's time to replace. So my questions - is it possible somehow to know which of brake pads (front or rear) should I change? Or should I change all four brake pads at once?
      Thanks for any of your opinion.
      Mindaugas
    18. 01-19-2015 08:19 PM #18
      I don't know if a scan would show it, but you can just look if you pull a wheel off. I definitely wouldn't just change all 4 just in case, but I would check both front and rear, including the life remaining on the rotors.
    19. Member Victor R's Avatar
      Jan 7th, 2010
      Coopersburg, PA
      Member of Le Club 2P: 2005 Coucou Grey W12 5-seater & 2005 Klavierlack Black W12 4-seater Phaetons
      01-19-2015 09:36 PM #19
      It may not be the pads.
      See this thread.
      Victor
    20. Member phaetonjohn's Avatar
      Oct 24th, 2014
      South Western Ontario
      2005 Phaeton 4.2L V8 LWB 4 Seater Klavierlack Black and Sonnen Beige with Chestnut wood
      01-20-2015 07:47 PM #20
      I just tied the wires together. No biggie, now! Just have to replace them when they start to squeal.
    21. 01-20-2015 10:43 PM #21
      Depending on the thickness of your rotors, that might not be the most cost-effective plan. I'm just about to change my front pads, the rotors are a shade over halfway through their life, and the pads are about 70% worn. If I wait until the pads are done, the rotors will need replacing too.
    22. Member phaetonjohn's Avatar
      Oct 24th, 2014
      01-21-2015 04:05 PM #22
      I regularly check the brakes, but I'll be sure not to let them go too far.
      -John
    23. 01-21-2015 04:24 PM #23
      There's a thread somewhere about the brake debate. On mine, if I change the pads a bit early, I get two sets of pads out of one set of rotors. Others seem to think one set of rotors only last for one set of pads.
    24. Member phaetonjohn's Avatar
      Oct 24th, 2014
      01-21-2015 04:28 PM #24
      That's a big money saver, right there.
    25. 01-21-2015 04:40 PM #25
      I think so. A set of pads is $140 after haggling, but rotors are about $250 for the pair, then there's the extra labour or time if you DIY. It'd be even better if they'd switch to the caliper design that my 951 has, there's a spring clip arrangement on top of the pads, so it's just a case of flipping that up with a pair of pliers, pushing back the piston, then swapping the pads. Takes about 10 minutes a side.
