VWVortex.com - battery drain in my jetta
    Results 1 to 21 of 21
    Thread: battery drain in my jetta
    1. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-17-2011 12:23 PM #1
      please delete
      ( )=====\X/=====( )
      For sale....or trade
      http://forums.vwvortex.com/showthrea...8#post81818358
    2. Member mAyZa b 3 a t s's Avatar
      Nov 4th, 2009
      Canadensis, PA Shippensburg, PA
      A Yugo and a mule
      04-17-2011 02:37 PM #2
      Ignition switch? I have a bad one and it gives accessory power to some of the stuff in my car when it's in the off position. It can kill my battery in a about 12 hours. I'm just too lazy to replace it at the moment.
      Quote Originally Posted by Sodomythical Frostgoat View Post
      **** off Timmy, I'm trying to break someone's spirit here, jesus.
      If you use the term "hater," I'm just going to assume you came out with the cord wrapped around your neck.
    3. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-17-2011 03:11 PM #3
      thank you, how do i check/test for that?
      ( )=====\X/=====( )
    4. Member mAyZa b 3 a t s's Avatar
      Nov 4th, 2009
      A Yugo and a mule
      04-17-2011 07:37 PM #4
      Borrow a known good one and plug it in and see if the issue goes away. I would just grab a new one. They're like 11 bucks or something and they're prone to go, so even if that doesn't solve it, you'll have a new one when yours does go bad.
    5. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-17-2011 09:30 PM #5
      awesome!! thank you so much for the advice
      ( )=====\X/=====( )
    6. Member
      Sep 25th, 2006
      MKIII Museum
      04-17-2011 11:15 PM #6
      If you have no drain from the Positive terminal, then you could have an internal battery drain between positive and negative plates.
      Disconnect the battery and see what happens.
    7. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-21-2011 09:01 PM #7
      i disconnected the negative terminal, but left the the multimeter still hooked up between positive post n positive terminal, it went from 12.60v with negative hooked up, to a bunch of numbers goin back n forth after i disconnected the negative. any ideas?
      ( )=====\X/=====( )
      Sep 25th, 2006
      MKIII Museum
      04-21-2011 10:22 PM #8
      Did it still discharge while it was disconnected? If so, you have a bad battery. If not... report back.
    9. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-22-2011 05:34 PM #9
      nope, does not discharge when disconnected.
      ( )=====\X/=====( )
    10. Member mrbatavus's Avatar
      Nov 29th, 2008
      Ewing NJ
      2002 Chevy Trailblazer, 2002 Saturn L300, 2003 Saab 9-3 Linear
      04-22-2011 07:09 PM #10
      after driving your car for a while let it sit, then place one lead from your multimeter, that is set on amps to the positive terminal of the battery, place it in such a way so that when you disconnect the positive terminal that the first lead u placed on the battery doesn't have to loose connection and place the second lead from your multimeter on the cable from the battery you just took off
      let me know what it says, if theres under .5 amps (500 milliamps) theres no problem with your car, just replace the battery
      http://www.youtube.com/watch?v=yFCT-...eature=related
      basically this but do it while the battery is disconnected and then remove the battery cable without breaking the connection wit the multimeter
    11. Member
      Sep 25th, 2006
      MKIII Museum
      04-22-2011 07:23 PM #11
      Quote Originally Posted by dubbed21 View Post
      Well then, the battery is good.
      First try disconnecting your alternator wire and testing it for current. Sometimes the diode trio fails.
      Next... remove fuses one at a time and connect your leads to each slot. You can then read what current is flowing in each circuit.
    12. Member jorge r's Avatar
      Apr 27th, 2006
      Los Angeles, 5&110
      vw
      04-23-2011 12:31 PM #12
      With the engine running, the battery bolts measured from the battery terminal posts should be 1-2 volts more than with the engine no running, then you know the alternator is doing its job.
      With the engine off properly connect the meter (in series), set for 10 amps, between the battery terminal post and the battery cable connector clamp, all doors closed and everything off. If there is a current leak, you will see its value in the meter.
    13. Member mrbatavus's Avatar
      Nov 29th, 2008
      Ewing NJ
      04-23-2011 05:51 PM #13
      quick way to check the alternator diode trio (rectafier bridge) is to hook up your miltimeter to red ac voltage and then just hook it to the battery, there should be nothing if u get anything the alt is bad
    14. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-23-2011 07:12 PM #14
      thank you everybody soooo much, i am going to work on it when weather gets better.
      ( )=====\X/=====( )
    15. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-24-2011 10:25 AM #15
      Quote Originally Posted by mrbatavus View Post
      i dont have red ac voltage on my meter, i have red dcv, blue ac ma, blue dc ma, green acv, yellow dc10a, and battery load test section with 1.5v, 6v, 9v, and 12v. which one do i set it to
      ( )=====\X/=====( )
    16. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      04-24-2011 10:30 AM #16
      ive done this and it is under .5 amps, but the battery doesnt loose charge when disconnected
      ( )=====\X/=====( )
    17. Member jorge r's Avatar
      Apr 27th, 2006
      Los Angeles, 5&110
      vw
      04-24-2011 12:24 PM #17
      How long before it drains the battery and how old is your battery?
      It doesn't make sense that you have a drain and yet, there is no drain measured. The only thing left is that you lock the car and hold down (prope it down to hold it down) the engine compartment alarm button switch before measuring in case the alarm once engaged is causing a drain.
      At .5 amp drain, a 60 AH (ampere hours) battery would last 120 hours, but cranking power may be gone at 60 hours, and you say it's cold so even sooner when cold.
      What dubbed21 says is to measure volts with the a-c scale, not the d-c scale. There shouldn't be more than 0.5 volts on the reading or the diode set is bad and this may cause a misfire trouble code.
    18. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      05-15-2011 12:27 PM #18
      it drains over night. battery is 2 months old, and this problem has been happening before and after i got the new battery. altenator is like 3yrs old and autozone tested it and said its good, which i believe because the battery stays charged until i let it sit overnight. weather sucks again, i will try the alarm thing asap.
      ( )=====\X/=====( )
    19. Member FATANG!!'s Avatar
      Aug 21st, 2007
      South Jersey
      1995 Jetta GL
      05-15-2011 12:34 PM #19
      Did you put an aftermarket head unit in? If you accidentally crossed the Constant and the Alternate lines of voltage (red and yellow wires), you'll drain over night, every night.
      Quote Originally Posted by PKstrategy View Post
      easy+mk3= does not always compute
      Quote Originally Posted by sk8too View Post
      It's the car's way of saying I hate what you've done to me and take them out
      -Not quite a Fink, but still a rat. -MK3 OBD1 Issues? Start Here!
    20. Member MrDubberDad's Avatar
      Jul 8th, 2010
      LV PA
      02 1.8t
      05-15-2011 06:28 PM #20
      it did have an aftermarket head unit in it, but i took it out. i bought that harness so it would be hooked up right, i dont think i crossed wires. would those wires be crossed somewhere in the dash at all??
      ( )=====\X/=====( )
    21. Junior Member
      Sep 14th, 2011
      new holland pa
      slc corrado
      09-15-2011 09:22 PM #21
      i'm having this same problem. i have a full bose sound system in my jetta but that runs through an amp. so i unplugged that amp about a half hour ago. i just hope thts the only problem
