Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 35 of 201
Thread: FS: MISC Mk1 CABRIOLET PARTS (cleaning out garage, leftovers from partout)
  1. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    A few somewhat functioning VW's, and a garage full of VW guts
    04-17-2011 07:27 PM #1
    *** 4/18/2013 I Lowered the prices on some of the remaining parts ***
    I'm trying to lessen the clutter in my garage-full-o-parts. I have a lot of misc pieces leftover from Mk1 Cabby that I parted out last year. I'll try to update this thread if I come across more Cabby parts.
    If you see something pictured that doesn't have a price, just make me an offer
    If you're interested in anything, PM me with exactly what you'd like (please be specific) & your zip code if a shipping quote is needed, and I'll give you a price A.S.A.P. All "shipped" prices mean shipped within the U.S., ask about shipping to elsewhere.
    Cabby Digi intake manifold - SOLD
    Cabby Digi intake tube/boot - SOLD
    Distributor cap w/ plug wires - GONE
    Cabby Digi O2 sensor - $12 shipped (no idea how many miles are on it)
    Oil gauge senders - SOLD
    Oil filter/cooler stand - $13 shipped
    PCV breather valve - SOLD
    Trans/Engine mount brackets - All SOLD
    Booster firewall brace - $13 shipped
    Raintray drain inserts - SOLD
    Clutch cable bushing/bracket - GONE
    Radiator mount brackets - SOLD
    Steering rack mounts - SOLD
    Front Susp. camber bolts - $13 shipped (both)
    Master cylinder reservoir - SOLD
    Cabby brake prop valves - $22 shipped (both)
    Shifter rod - $7 shipped
    Raintray/Hood seal - $13 shipped (each)
    Raintray blower motor cover - SOLD
    Raintray thin plastic cover - SOLD
    Wiper motor - $15 + shipping (linkage gone)
    Lower ram air intake tube - $18 shipped
    Battery to alternator wires - SOLD
    Negative clamp to ground wire - $12 shipped
    Black/White sunvisors - SOLD
    Wiper & turn stalk w/ cruise - SOLD
    Wiper stalks - $17 shipped (each)
    Turn stalk - $10 shipped (1 tab on back is broken, holds fine when everything's together)
    Complete clam shell - SOLD
    Top clam shell half - SOLD
    Airbag clock spring - SOLD
    Drivers side seat belt - SOLD
    Lower seat belt reel covers - $15 shipped (both)
    E-brake handle - SOLD
    E-brake handle cover - SOLD
    Upper seat belt bolt covers - $7 shipped (both)
    Sunvisor clips - $7 shipped (both)
    Door/domelight sensors - $10 shipped (both)
    Top J-hook - SOLD
    Cabby front power window regulators - N/A
    Dash duct pieces - best offer
    Cabby rear manual window regulators - N/A
    Brake pedal - $12 + shipping
    Gas pedal - $12 + shipping
    Airbag steering column - SOLD
    Ignition housing - $15 shipped (no switch or tumbler)
    Door chime relays - $10 shipped (each)
    Map pocket speaker grille - SOLD
    Drivers side map pocket complete - SOLD
    Lower seat slide pins - $7 shipped (pair)
    Heater control panel face - $10 shipped
    As I stated at the top of the thread, I'll try to update this post as I come across more parts that I don't need. Thanks for looking
    Mk1/Mk2/Mk3 stuff for sale. Cleaning out the garage, search my posts and/or message me
    CE2 Fusebox Connectors & Misc Connectors w/ Wiring (I have LOTS of used OEM connectors & wiring, let me know what you need)
  2. 04-19-2011 04:58 PM #2
    do the center caps all have the bolts, do you know what year they are, should be on the back, thanks
  3. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    04-22-2011 09:04 PM #3
    Quote Originally Posted by clarges37 View Post
    No bolts sorry. Those center caps will fit any "teardrop" wheels, no matter the year, but will only fit that style wheel.
  4. Member curbdawg's Avatar
    Aug 4th, 2002
    westernMAss
    '83 GTI, '05 Passat Wagon 1.8t 4motion, '99 Toyota Coralla Motorola Holder
    04-24-2011 02:31 PM #4
    do you have both the speaker pocket panels?
  5. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    04-24-2011 04:33 PM #5
    Quote Originally Posted by curbdawg View Post
    No, only the 1 pictured.
  6. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    04-29-2011 04:50 PM #6
    Bump
  7. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-03-2011 08:14 PM #7
    TTT
  8. 05-05-2011 01:27 PM #8
    Desperately need the front mount as well as the cup mount that bolts to the core support, your pictures show two of the front mounts; would you happen to still have the core support mount that the front mounts mates up to? Shipping to Ohio 45052?
    Thanks!
    86 Cabby ......down; but not out.......
  9. 05-05-2011 09:08 PM #9
    Does the steering wheel have the leather wrap? Is so please quote with shipping to 06460
  10. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-06-2011 05:21 PM #10
    Quote Originally Posted by 86 Cabby View Post
    Thanks!
    I sent you a PM with details
    Quote Originally Posted by vwcab93 View Post
    No, it's a non-leather wheel. I responded to your PM
  11. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-12-2011 07:22 PM #11
    Bump
  12. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-14-2011 07:40 PM #12
  13. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-15-2011 07:01 PM #13
    Quote Originally Posted by luisin3460 View Post
    Hi
    Would you take $10.00 plus shipping for the front center support, for sipcode 00624.
    thank you in advance.
    Luis
    Sent PM
  14. Junior Member
    Apr 7th, 2008
    Litchfield County, CT
    VW Cabriolet
    05-16-2011 02:58 PM #14
    looking for all or the pass side door and fender trim in all black. How much and need shipped to 06705 in CT....email @ hot1lola@optonline.net. Thanx, Ana
  15. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-16-2011 09:58 PM #15
    Quote Originally Posted by toplesvw View Post
    All of the trim is gone, sorry.
  16. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-18-2011 10:06 PM #16
    Bump
  17. Junior Member onemean6's Avatar
    May 30th, 2010
    1991 vw ea cabby
    05-23-2011 09:20 PM #17
    i'll take it 516 729 6357
  18. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-23-2011 11:03 PM #18
    Quote Originally Posted by onemean6 View Post
  19. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    05-26-2011 11:13 PM #19
  20. Member ih8erickempf's Avatar
    Apr 23rd, 2004
    New Jersey
    06 A4 avant , 91 EA Cabriolet, 80 Rabbit p/u
    06-04-2011 08:48 AM #20
    the airbag spiral spring, does that have the rubber boot surround w/ it? if it does i might be interested. hit me up in a pm
  21. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-09-2011 07:09 PM #21
    Quote Originally Posted by ih8erickempf View Post
    PM sent
  22. Member
    May 17th, 2011
    Long Island
    1990 Cabriolet Auto / 1996 Audi A4 Quattro 2.8L V6 5 speed
    06-09-2011 07:30 PM #22
    Interested in Cabby Digi intake tube/boot. How much shipped to 11755. I'm ready with paypal.
  23. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-09-2011 07:49 PM #23
    Quote Originally Posted by kidrocking79 View Post
    Sorry, I had already sold that but forgot to update the list, my apologies. I updated it.
  24. Member ih8erickempf's Avatar
    Apr 23rd, 2004
    New Jersey
    06-09-2011 08:56 PM #24
    pm responded to
  25. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-10-2011 11:23 AM #25
    pm responded to
    Responded back
  26. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-11-2011 08:00 PM #26
    Sold a few things, updated the list
  27. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-17-2011 11:08 AM #27
    Bump
  28. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-19-2011 01:04 PM #28
    Hi
    Do you have a fuel distributor for a 1987 cabriolet.
    Luis
    Luis, I don't have any of those, sorry
  29. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-21-2011 10:53 AM #29
    Bump
  30. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-24-2011 08:34 PM #30
    TTT
  31. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-25-2011 09:37 PM #31
  32. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    06-29-2011 11:00 PM #32
  33. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    07-05-2011 01:17 PM #33
    Bump
  34. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    07-15-2011 11:18 AM #34
    TTT
  35. Member Delete!'s Avatar
    Apr 26th, 2002
    Shavin bays in PA
    07-28-2011 07:30 PM #35
