VWVortex.com - 2003 Jetta Wagon TDI oil change info needed
    Results 1 to 8 of 8
    Thread: 2003 Jetta Wagon TDI oil change info needed
    1. 04-18-2011 10:54 AM #1
      ...what oil is recommended, and how do I change it? thank you!
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      04-19-2011 10:16 AM #2
      Quote Originally Posted by elizabella 42 View Post
      If you go by the book... an oil that meets VW505.00
      A lot of people use Shell Rotella T6 and Mobil 1 Turbo Diesel Truck
      How to?
      you can lay on your back or do everything from a hood.
      Tools?
      74-76mm x 14 flute oil filter wrench
      http://www.metalnerd.com/cat05.htm
      3/8" Torque wrench
      you can extract the oil from the oil dipstick using a Pela oil extractor or similar. or
      get a set of Rhino Ramps, then using a T-25 torx driver, remove all the belly pan screws... to access the oil drain plug. I can't remember the socket size (I want to say 17mm, but can't remember, since on my old TDI, I extracted the oil)....remove the drain plug.
      Up top... remove the cap of the oil filter, remove the filter & o-rings. (you can make a huge mess)
      oil filter goes "dam side down....the solid walled portion of the oil filter support cage), replace both o-rings.
      Good idea to remove the residual oil using a turkey baster or oil extractor.
      Tighten oil cap to 25.5 Nm (it says it on the cap) using Torque wrench to verify.
      the rest... is self explanatory
      APR Stage 1/Morimoto 5500K D3S bulbs/Hella XY 9006 bulbs... keeping the mods light on this one...
    3. 04-22-2011 12:14 PM #3
      Forgot to mention...I have a skid plate ...is there a hole to access??? thx!
    4. Member
      May 10th, 2010
      North Jersey
      04-22-2011 02:05 PM #4
      I suggest sucking the oil through the disptick
    5. 05-01-2011 06:32 PM #5
      that is just plain silly...i meanyou arejustplainsilly
    6. 05-02-2011 02:34 PM #6
      please are you sure...is that the only way???? how exactly does one suck through the dipstick??? thanks muchly!
      May 10th, 2010
      North Jersey
      05-02-2011 02:58 PM #7
      I had a metal skidplate on my old TDI.... after a few oil changes, I got an oil extractor from a boating store (west marine).
      Also, popular is:
      http://pelaproducts.com/
    8. Member rocconut's Avatar
      Feb 20th, 2004
      Montpelier VA
      16v Scirocco x 5 MKI GTI, MKII GTI 55 CHEVY
      05-03-2011 03:50 PM #8
      PM sent.
