Results 1 to 11 of 11
Thread: MK4 rev limiter
  1. Junior Member MKVjettawlfsburg's Avatar
    Jan 20th, 2011
    Northern WI
    2001 Jetta Wolfsburg
    04-19-2011 03:20 PM #1
    I have a 2001 wolfsburg Jetta 1.8T and im wondering what the rev limiter is set at stock and at what RPM is the engine actually safe to? Anybody got any ideas?
  2. Junior Member nAAArow 6's Avatar
    Jul 20th, 2010
    ORD
    MKIII GLX. MKIII Golf GL 4door. MKII Jetta GL. MKII GLI. MKII Jetta Coupe. MKI GTi ABA. 05 Cayenne.
    04-19-2011 05:00 PM #2
    I would say that your engine stops making power after 5,500-5,600 rpm and if you want to play safe shift @ 6,000rpm.
    Don't try to be cool like the JDM crowd and hit your rev limiter Not good for the life of your engine.
  3. Junior Member MKVjettawlfsburg's Avatar
    Jan 20th, 2011
    Northern WI
    04-20-2011 02:13 PM #3
    Well im wondering because i was gonna try and hit it once just to see if my car has a ecu upgrade or not.
  4. 04-29-2011 08:11 PM #4
    well im sure you know the phrase redlining. Even though my car is right outside i cant remember if the red starts at 6500 or 6700 but thats where the rev limiter should take effect if the car hasnt been chipped. I literally just got apr stage 1 like 2 hours ago and it revs higher. try it out and see bro
  5. Junior Member MKVjettawlfsburg's Avatar
    Jan 20th, 2011
    Northern WI
    05-02-2011 12:28 PM #5
    Quote Originally Posted by Dragon1.8T View Post
    Is the APR ecu upgrade worth the $ ??
  6. Member lorge1989's Avatar
    Sep 3rd, 2008
    Buffalo, NY
    2000 Audi A4, 1988 Audi 90, 1985 VW GTI
    05-03-2011 12:26 PM #6
    Quote Originally Posted by MKVjettawlfsburg View Post
    You can rev safely to 7 or 8 grand. Just don't shift up there if you have an O2J transmission (aka 5 speed). Also I wouldn't do this all the time because **** will break.
    If you are wondering the stock rev limiter for most 1.8ts it is about 6,750 rpm.
    Dubs in the Buff
    in other news, lindsay lohan prefers "philosophical dabbler" to "crack whore."
    Apr 4th, 2011
    Bronx, New York
    05-05-2011 11:56 AM #7
    Does "curiosity killed the cat" ring a bell?? are you really going to rev the engine to see if it bounces off the limiter or not?? now when it doesnt you just proved to yourself, that you are a dumbass, almost killed your motor, and possilby destroyed wats left of your bearings...
    Lets put a knife in the wall outlet to see if it has live current.. -_- let me know how it goes for you... ill be busy checking to see if my engine can run on no oil for 2 months just as a test..
  8. Junior Member MKVjettawlfsburg's Avatar
    Jan 20th, 2011
    Northern WI
    05-10-2011 09:56 AM #8
    Quote Originally Posted by volxwagen View Post
    WTF?? im not doing it for fun you retard
  9. Member jaso028's Avatar
    Aug 12th, 2007
    02.5 24v GLI, 05.5 Jetta 2.5l
    05-12-2011 03:30 PM #9
    N.E.R.D.
    White Lightning
  10. 05-13-2011 02:27 AM #10
    The engine will cut out when you hit the actual redline. Unfortunately, unlike a japanese car, you can't bounce the tach. I believe I was able to get it to 7200 before reaching the cut off. I believe the redline on the dash cluster itself is at 6800. However, as others have stated, if you're on a stock turbo you won't see much power past 6000rpm, let alone redline. However in an autox/track situations the extra room to rev comes in handy. The head is really the limiter on safely revving the motor out past 7500. The 1.8T forum can give further specifics on that.
  11. Member jazzcat2001's Avatar
    Mar 17th, 2004
    Hazelwood, MO
    97 GTi VR6
    05-14-2011 08:45 PM #11
    there are safer ways of telling if your car has an ecu upgrade
    find someone local with vag com and have them plug in to your car
    Jim- Owner of rustisnotacrime.com Like us on FB!
    Admin on Rival House. Like us on FB!
    SE Auto
