Page 1 of 2 1 2 LastLast
Results 1 to 35 of 53
Thread: wtt b3 passat lots of mods
  1. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    1993 B3 Passat VR (sold), '13 Jetta Sportswagen TDI, 08 Acura MDX
    04-20-2011 11:45 PM #1
    throwing this out there..see what might catch my interest. Trade for: MK2's MK3's MK4's B5 Passat ,Audi
    1993 B3 Passat VR6
    229k on body/ 15k on built motor w/ new head
    tornado red
    i'll start with the not so good:
    Clearcoat is peeling on roof and trunk, sunroof works but needs help closing (broken track tab) and the headliner needs re-wrapping
    (new parts unless otherwise noted)
    GIAC Cam Chip
    K&N Filter
    MKIV Head Gasket
    PowerGasket between intake mani and head
    New Injectors
    Brand New Head (complete)
    Autotech 262’s
    New Alternator
    VF Engineering front motor mount
    BFI Poly rear mount
    G60 solid tranny mount
    Diesel Geek Short Shift kit (also new bushings and rods last month)
    A2B4guy grounding kit
    MSD Coils & MSD Wires
    (still have the stock coil pack and mkIV plug wires)
    Alum ‘crack pipe’
    Corrado tranny (rebuilt)
    ACT Sport clutch
    Lightened flywheel
    Cat back stainless exhaust 3"
    Brakes: 11.3” DE front calipers, Brembo rotors, Hawk HPS pads
    mk4 rear calipers, Brembo rotors, OEM pads
    Goodridge SS front and rear over axle lines (new flex lines at calipers)
    ATE super blue fluid
    new tires: Nangkang 205 40 17 Z's in back. Fierce HP's up front
    Suspension: Neuspeed Sport springs
    Bilstein Sport dampers
    HD front upper strut mounts
    VWMS front control arm bushings
    Audi TT rear control arm bushings
    wheels: ASA AR-1 17” FRONT are new, Rears are a couple years old
    spacers: H&R 10mm (front), 15mm (rear)
    B4 (1997) Leather Seats (heated but not hooked up)
    B4 (1997) Center console with rear cup holder
    B4 (1997) HVAC controls
    B4 (1997) Turn stalks & clamshell
    Euro 3-point Seat Belts (used)
    Euro Corrado Steering wheel (used)
    stereo: Alpine Head unit with Ipod interface
    Polk DB 6.5” rear speakers
    Polk DB 6.5” front component speakers
    Thule Roof rack system w/bicycle trays + locks
    Maintenance (new parts unless otherwise noted)
    Timing chains (and all associated parts)
    Aux. Water pump
    Water pump
    Serp. Belt tensioner & belt
    T-stat housing
    T-stat (low temp)
    All sensors in T-stat housing
    All switches in oil filter flange
    Radiator (new this month)
    Fan switch
    Coolant overflow bottle & cap
    AC Condensor (used)
    Battery
    B4 Battery cables (used)
    Oil filter cap and drain plug
    Front wheel bearings
    Tie-rod ends
    Sway bar end links
    Sway bar bushings
    Subframe bushings
    Rear wheel bearings
    Rear trailing arm bushings
    Plugs
    Fuel filter
    http://s981.photobucket.com/albums/a...enwa01/Passat/
  2. Junior Member Audi96fans6's Avatar
    Aug 18th, 2010
    Mass
    Looking for my new Vdub... 02 kidhauler(wifes ride) haha
    04-21-2011 09:23 AM #2
    What are you looking to get for a cash price???
  3. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    04-21-2011 05:21 PM #3
    more looking for a trade. this is my spring/summer daily driver
  4. Junior Member
    Mar 10th, 2011
    south windsor ct
    1997 golf 2.0 1997 jetta 2.0
    04-24-2011 01:29 PM #4
    i have a 97 jetta primer grey whole car is primer at this point bodys clean. 2.0 187k i was told the motor was rebuilt its chipped and cammed. trannys got like 120k on it. short throw lowered on rokkors and has powdercoated tear drops. any interest.
  5. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    04-24-2011 07:55 PM #5
    got pics?
  6. Junior Member
    Mar 10th, 2011
    south windsor ct
    04-24-2011 08:11 PM #6
    email? http://www.facebook.com/photo.php?fb...0253191&type=1 idk if youll be able to see that
  7. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    04-25-2011 08:01 AM #7
  8. Junior Member
    Mar 10th, 2011
    south windsor ct
    04-26-2011 07:06 AM #8
    sent
  9. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    04-26-2011 02:55 PM #9
    bummmmp
  10. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    04-30-2011 09:40 PM #10
    bump
  11. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    05-03-2011 12:15 PM #11
    bump... all cleaned up and put back on the road for spring
  12. 05-03-2011 07:58 PM #12
    Hey were did you get that grille? Can I buy it if you don't sell the car soon????
  13. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    05-07-2011 03:30 PM #13
    sorry not parting out...
  14. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    05-12-2011 07:29 AM #14
    bump
  15. 05-15-2011 11:50 PM #15
    How about an 86 scirocco with 2.0 from 98 gti?
  16. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    05-16-2011 05:53 PM #16
    pics? location?
  17. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    06-04-2011 03:56 PM #17
    upppppppppppp
  18. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-10-2011 12:26 AM #18
    up
  19. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-12-2011 07:53 PM #19
  20. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-18-2011 05:03 PM #20
    New Pics Up!
  21. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-23-2011 12:24 PM #21
    ttt
  22. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-23-2011 12:25 PM #22
  23. Member
    Apr 15th, 2009
    North Jersey
    07-25-2011 03:05 PM #23
    Pics? Got a 98 Jetta might be interested in
  24. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    07-25-2011 04:53 PM #24
    Quote Originally Posted by provost13 View Post
  25. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-04-2011 04:21 PM #25
    up
  26. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-05-2011 05:52 PM #26
    ttt
  27. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-06-2011 04:02 PM #27
    up
  28. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-10-2011 02:20 AM #28
    bump.. may entertain cash offers
  29. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-15-2011 09:00 AM #29
    ttt may consider cash offers too
  30. Member jake legend's Avatar
    Aug 10th, 2010
    Orlando,FL
    93 cabby, 68 bug.72 ironhead,96 1200sporty
    08-16-2011 04:45 PM #30
  31. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-16-2011 06:12 PM #31
    looks good man, but honestly not really interested in traveling
  32. Member jake legend's Avatar
    Aug 10th, 2010
    Orlando,FL
    08-16-2011 11:46 PM #32
    free bump
    love your car
  33. Member Golfwa78's Avatar
    Jul 3rd, 2008
    Norwood, MA
    08-21-2011 09:18 AM #34
    Quote Originally Posted by subydude View Post
    actually on trade hiatus right now, got into a fender bender and fixing the passat right now. heres the link: http://forums.vwvortex.com/showthread.php?5403591-(
    may be a while before its trade-worthy!
  34. 08-22-2011 01:51 AM #35
    That sucks, doesn't look too bad you get an estimate?
