VWVortex.com - tapping a stripped lug bolt hole?
    Results 1 to 13 of 13
    Thread: tapping a stripped lug bolt hole?
      Nov 12th, 2002
      PDX, Oregon
      '03 1.8T GTI, 81 Hare
      04-27-2011 09:33 PM #1
      so one of the holes on my hub is stripped out. I figured I would try tapping it. I have never performed this task and was curious if someone knew what size tap to use and any tips are appreciated! thanks!
    2. 04-27-2011 09:50 PM #2
      If its stripped, a tap wont do you any good.
    3. Member WackyWabbitRacer's Avatar
      Apr 24th, 2001
      Charlotte, NC USA
      1978 WackyWabbit (sold)
      04-27-2011 09:53 PM #3
      Quote Originally Posted by A2Rags View Post
      As Shannon said, a tap will not restore the threads if the hole is stripped out.
      A new hub is in your future.....
      Cheers, WWR.
      WWR
      signature edition
      Harry Puckett R.I.P. 01-24-2010. You are gone too soon. We had races
      to race, jokes to tell, laughter to share, and cold beers to drink.
    4. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Almost the Arctic, Alberta, Canada
      Because MK1
      04-27-2011 10:15 PM #4
      3 lugs ftw.
      Nov 12th, 2002
      PDX, Oregon
      04-27-2011 10:19 PM #5
      thought I had seen a thread where someone had? thanks!!
    6. Member backinthegame's Avatar
      Dec 13th, 2004
      Virginia Beach, VA
      89 Cabriolet, 90 Corrado, 83 Caddy, 87 GTI, 07 A6 Avant,2012 powerwheels Jeep
      04-27-2011 10:33 PM #6
      You don't tap if it's stripped unless you are making it a larger hole. You can helicoil a stripped hole.
      Neither of these are options for a hub. As said, get a new one.
      Sent from my Droid using an escape pod to Tattoine.
      Quote Originally Posted by mad8vskillz View Post
      they're trying to skip out on their contracts via rapture. not very christian of them
    7. Member TM87's Avatar
      Dec 30th, 2008
      Windsor CT
      VW
      04-27-2011 10:56 PM #7
      They are cheap,just get a new one
    8. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Because MK1
      04-27-2011 11:00 PM #8
    9. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      04-27-2011 11:03 PM #9
      Quote Originally Posted by 8v-of-fury View Post
      Don't forget the wheel bearing that needs to be replaced at the same time.
      http://www.autohausaz.com/search/pro...ber=171498625D
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    10. Member cuppie's Avatar
      May 3rd, 2005
      Redford, MI
      88 Scirocco 16v (Wilda); 02 Passat NevarLose wagon; '12 Fusion SEL (wife's.) Past: '86 QSW, '87 Golf
      04-27-2011 11:05 PM #10
      3 lugs ftw.
      That's retarded. And, so unsafe that you shouldn't even say it jokingly - someone might take it seriously!
      As others said, if the threads are stripped, it's junk now. Time for a new hub and bearing.
      Assuming Rabbit (recheck the application, please!)....
      Wheel bearing kit (bearing, snaprings (replacement required), axle nut (also need new), tie rod & ball joint nuts: $25
      Wheel hub: $32.
      http://www.germanautoparts.com/Volks...ivetrain/242/1
      That's assuming you're talking about the front axle. If rear, you'll need a new brake drum (and, 2 wheel bearings, and a grease seal.)
      FYI: the wheel bolts are M12x1.5. But, 'stripped' = 'no threads' (read: tap won't help, as there are no threads to use - the hole is larger than it once was.)
      - Cup
      '88 Scirocco 16v, 'tastefully' modified.
      Click here for my Cincy pics
      things currently broken (Scirocco): 4
      things currently broken (Passat): 4
    11. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Because MK1
      04-27-2011 11:09 PM #11
      Quote Originally Posted by cuppie View Post
      Natural Selection.
      Aug 2nd, 2010
      Fargo north dakota
      81 caddy n/a tdi, 02a.
      04-27-2011 11:34 PM #12
      smart cars are 3 lug
    13. Member Minty_Fresh's Avatar
      May 27th, 2009
      Dela-Where?
      Juced Cutty on 13's
      04-28-2011 02:17 AM #13
      use it as a excuse to comvert to pres in studs.
