VWVortex.com - Digifant 2 ECU, what do the part number differences mean? School me!
    Results 1 to 10 of 10
    Thread: Digifant 2 ECU, what do the part number differences mean? School me!
    1. Member ModernDayThorns's Avatar
      Mar 23rd, 2008
      Berlin Virginia
      04 Passat 20v 4motion, 00 Jetta TDI, 97 Golf, 85 GTI,
      04-29-2011 04:26 AM #1
      I have a few questions about the Digifant 2 system.
      I have 90 Golf that has a 037 906 022 M ECU in it. The ECU from my Brother's car had a different letter in it.
      What do the differences in part numbers mean? Can they be interchanged? Does it matter if the ECU is chipped?
      Any addition information on the Digifant system is welcome, I'd like to learn all I can about it!
      Any help is greatly appreciated!
      Saving Volkswagens All The time!
      -Josh Hardy
      757-653-4840
      Instagram: @moderndaythorns
    2. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      04-29-2011 05:02 AM #2
      Depending on the actual letter, it may indicate the brand of ECU, Bosch, Ken, Bosch-Ken, or Siemens.
      Other things to consider fpr the US market, is RV engine vs PF engine (Europe had different engine codes but the ECU may be the same as a US ECU based on the part #.
      The main difference is the RV has a single outlet manifold and down pipe.
      The PF engine has a dual outlet manifold and down pipe, a 5 hp, 5 ft/lbs tq over the RV engine.
      The other difference is with and without diagnostics.
      Only with the exact part # can we decipher what your bro has.
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    3. Member ModernDayThorns's Avatar
      Mar 23rd, 2008
      Berlin Virginia
      05-03-2011 07:51 PM #3
      I have no idea if his is eben in working condition.
      I'm looking at buying one with a 037 906 022 BA part number.
      -Josh Hardy
      757-653-4840
    4. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      05-03-2011 11:41 PM #4
      037 906 022 BA is for a California Digifant 2 with PF engine code.
      The compatible replacement ECU is part # 037 906 022 DX.
      FYI both of these ECUs have been dropped from VW, your best bet is to search the classifieds, or I can look into this for you. I go junking often and will keep my eyes open.
      You can IM me your phone # and email, I will contact you if I locate one.
    5. Member PDXGTI8V 2.0's Avatar
      Oct 11th, 2005
      Portland ORYGUN
      + over 7500 posts pre-ban
      05-04-2011 01:27 AM #5
      and just a FYI...i have two other computers in my garage, all DigiII computers, all with different part numbers on them...I have tried these two, taken from junked/parted out cars, in my car and noticed absolutely no difference in performance or driveability between the other two and my stock computer...so from this I can only gather than the programing differences between DigiII computers isn't that much different...
    6. Member ModernDayThorns's Avatar
      Mar 23rd, 2008
      Berlin Virginia
      05-04-2011 02:14 PM #6
      Thanks for all the help!
      -Josh Hardy
      757-653-4840
    7. 01-14-2014 02:18 PM #7
      Hi,
      I have problem with my ECU VW 037 906 022 CS/BOSCH 0 261 200 294. My car is Jetta 1.8.
      I'm trying to find low price solution because ECU also need to be shipped to Bulgaria.
      Does anyone knows which ECU VW 037 906 022 numbers could work with my car?
      Regards,
      Nikolay Iliev
    8. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      01-16-2014 11:03 AM #8
      Quote Originally Posted by jetta1991BG View Post
      Hi,
      Regards,
      Nikolay Iliev
      This guy ships worldwide.
      http://www.ebay.com/itm/VW-Jetta-Gol...c4770b&vxp=mtr
    9. 01-17-2014 04:53 PM #9
      Thank you Eric!
      I found some offers in eBay and received some others from forum's members. Internet search takes time but you could save a fortune. I'm really looking for a cheap solution. My Jetta's engine is RV. I've just received for test ECU from Passat with PB engine from member from Bulgarian's VW forum. Do you think it could work? If you are interested I'll write the answer next week after the test.
      Regards,
      Nikolay Iliev
    10. 01-20-2014 03:34 PM #10
      Hi All,
      Just for the record. My car's engine code is RV. ECU VW 037 906 022 CS. Test with ECU VW 037 906 022 AN (from VW Passat PB engine code) was successful ... for now.
      Regards,
      Nikolay Iliev
