VWVortex.com - Ground effects and the repair of your car.
    View Poll Results: Did replacing your grounds, resolve issues, or create them?
    Voters
    14. You may not vote on this poll
    • I replaced the Battery to Frame only.
      0 0%
    • I replaced the Battery to Frame/Engine only.
      0 0%
    • I replaced all of them that I could find.
      3 21.43%
    • I cleaned them.
      2 14.29%
    • Why bother, they look good.
      0 0%
    • Briano is right replace all them things.
      9 64.29%
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 82
    Thread: Ground effects and the repair of your car.
    1. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      05-02-2011 01:45 PM #1
      I recommend that folks Replace their GROUND's. Others have picked up my Mantra, but I see folks struggling with this issue. Some folks just need black/white proof as to the effects. Hence this poll.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    2. Member DaveLinger's Avatar
      Jul 6th, 2005
      Morgantown, WV
      2007 Jetta GLI Fahrenheit #760
      05-02-2011 04:02 PM #2
      Just for clarification, is this poll asking about mk1 Cabriolets only, or also mk3/3.5s, or all cars in general?
    3. Member hessiandave's Avatar
      Jul 5th, 2009
      the arsenal city, NY
      my other volkswagen is a volkswagen
      05-02-2011 04:25 PM #3
      Thy cabriolet god has spoketh and ye shall listeneth.
    4. Member 90Kabby's Avatar
      Feb 2nd, 2005
      Hollywood
      90 Kabby
      05-02-2011 04:32 PM #4
      Clean contact points and replace all them things, its just good common sense....on any vehicle.
    5. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      05-02-2011 10:16 PM #5
      I replaced the battery to frame and frame to trans ground only. All other ground points have been and are cleaned as I come across them/as need be. Effects? Slightly better starting but that's about it, that I've really noticed anyway. But my car hasn't really had any ground-related issues in its 20+ years.
      My Vanagon is a different story: It has several minor electrical issues now and all of its ground points are pretty dirty. I need to go through the entire thing replacing, adding and cleaning grounds, fixing connections, etc.
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    6. Member Darter's Avatar
      Aug 24th, 2002
      West Milwaukee, WI
      02 Passat Wagon GLX 4mo, (sold: 83 Rabbit Convertible Wolfsburg Edition, sold: 99 Passat 1.8T)
      06-21-2011 12:59 PM #6
      I gotta say, the one thing that's been difficult for this new cabby owner in regards to addressing grounds is specifically what points they connect to. I've discovered a number of these grounds to be missing on my car, so I'm left scratching my head as to what "valve cover to coil" or "one on the steering column" mean (I know what these parts are, but my coil has at least one extra spade on it... does it connect there? Which valve cover stud is correct, or is there a separate ground anchor?).
      Eventually the answers turn up after lengthy search sessions, but the info is not readily available (though briano's mantra is ). What's more, I haven't found a complete list anywhere, but many threads with different locations mentioned.
      Could we compile a more detailed list and photos for cabby-info.com? So far, I've found:
      1. Battery to the left frame rail
      2. Frame rail to the transmission
      3. Valve cover to the ignition coil (coil, or coil mount?)
      4. Fuse/relay panel (to...?)
      5. Steering column (to...?)
      6. Valve cover to raintray/firewall (same as above?)
      7. Main harness to ground donut near fuse box (same as above?)
      8. Rear harness DS panel near tailaights. (DS? driver's side?)
      9. Rear Defrost PS opposite other ground. (PS? passenger's side?)
      10. alternator to the engine block or valve cover (is one better than the other?)
      11. cold start valve (to...? CIS only?)
      12. hood to fender
      13. instrument cluster (to...?)
      14. ... what else?
      Being relatively new to cabby's I hear from the long-timers that grounds are essential, and I probably look at them every other time I'm wrenching on the car, but more details about the grounds would make addressing the issue much easier. If we can demystify the locations and attachment points, that would help a lot!
      May 11th, 2009
      IA
      88 Cabriolet, 95 MKIII Golf GL, 06.5 MKV GTI
      06-21-2011 02:34 PM #7
      I agree with this. A good list of what grounds and maybe pics would be cool.
    8. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      06-21-2011 04:01 PM #8
      Your wish is Granted, I am missing a few pics, but O'Well self discovery is the best, and these are on my 92,and 93 Cabbies, most CIS have the same ground points.
      The battery grounds are located:
      Back corner of the valve cover Going over to the Coil Bracket nut:
      Behind the air box on the frame horn. From the frame horn to the Transmission mounting to engine Bolt.... The only studded bolt on the tranny mounts
      From the Battery negative to that same frame mount.
      There are more than adequate and there are additional grounds that
      are from the
      A/C compressor to the Alternator Case nut.
      The ECU bracket to the rain tray.
      There are additional "bonding" wires which are also Ground from the hood hinge mounting bolt to a Fender nut. Either Side.
      In the Trunk:
      From the Tail Light Base Plate Drivers side to the Frame, I usually use a bumper bolt. I do both sides.
      Bumper Bolt:
      Tail light Bracket 3 Middle Male Spads;
      Power Steering Firewall to a screw on the power steering cover:
      Clean the Frame stud and the back side of the nut, use a little Never-seize on it and with new standard battery cables they will be able to more than do the job for you.
      Remove your Instrument cluster:
      http://cabby-info.com/Files/DashRemoval.pdf
      On the back of your cluster, remove the Shroud off the main connector
      by pressing in the finger tabs, and carefully pry off.
      Carefully lift the Mylar connector off the tongue.
      Place one strip of electrical tape on the pad side of the plastic tongue.
      Replace the shroud.
      You should also remove the nuts off the back of the cluster and sand them to clean them.
      Sand the lock washers too.
      Brush the mylar with steel wool I usually twirl it around the stud sticking out, and that cleans the mylar too.
      Replace the nuts and tighten them.
      Now you are going to add an additional ground wire to the main cluster connection.
      From the Large Connector, go back about 4 inches and use a wire splice to join
      a 12 inch piece of wire to the number 2 pin, brown wire.
      Between the "X" drill a small pilot hole, and sand around it to get it to bare metal.
      Add a terminal connector to the bitter end of the new spliced wire.
      Use a sheet metal screw to screw the connector to the frame. You now have a good cluster ground. You can run
      This ground to the console gauges and get a more accurate reading, although I have used the ground from the
      Cassette Tape Holder Lamp.
      Inside the Cabin on the firewall there are Star connectors that are riveted to the Frame.
      The have the majority of grounds. Don 't have a pic.
    9. Member Darter's Avatar
      Aug 24th, 2002
      West Milwaukee, WI
      06-21-2011 04:32 PM #9
      Nice pics! Looks like I have more missing than I thought... Will have to go over my car some more to see how these other locations are fairing (didn't know about the a/c to alt, for instance).
      What is that metal piece that is under the ground strap ring on the valve cover gasket? I'm pretty sure I don't have it...
    10. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      91 Burgundy Etienne(2), 06 Jetta 2.5, 08 GTI 2.0T FSI
      06-21-2011 04:43 PM #10
      Its a copper plate. It's held in place by a nut on the valve cover. As far as I know its intended to allow a extra good ground to the block, for the wire that runs to the firewall. It also holds the wires/plug assembly for the 02 sensor, in the visible slot to the side of it.
      May 11th, 2009
      IA
      06-21-2011 04:54 PM #11
      Now that's what i am talking about! I know what I am going to do when I get off work tonight lol.
    12. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      06-21-2011 04:59 PM #12
      Quote Originally Posted by Darter View Post
      6. Valve cover to raintray/firewall (same as above? It's valve cover to ignition coil bracket only)
      12. hood to fender
      14. ... what else?
      I'm working on an illustration that shows all of the main ground cables in the engine bay. As for all the other "minor" ground points, they differ between the years and are listed in the electrical section of the Bentley Service Manual, as are the connection types for each year. I may go through all of those lists and add them to the illustration, text-wise.
      A/C compressor ground varies based on car year: some ground at the battery, some ground on the engine block.
      PS = passenger side
      DS = driver side
      Brian's photos are of his Digifant, so don't go looking for the same grounds. Cases in point: 1) The A/C compressor. Your factory ground is at the battery. 2) The ECU. CIS does not have an ECU in the rain tray, it has an ICU (ignition control unit) and does not have a ground strap. 3) The valve cover. CIS valve covers use the same type of hold-down strip in the back as is used in the front; use any nut for the ground strap on that rear strip you like (make sure it's clean).
    13. Member Darter's Avatar
      Aug 24th, 2002
      West Milwaukee, WI
      06-21-2011 06:21 PM #13
      Quote Originally Posted by kamzcab86 View Post
      PS = passenger side
      DS = driver side
      Ah, thanks for all of the clarifications... I was getting a bit worried there. I'll have to stop at a parts store on the way home and start with the valve cover strap. Good to know I'm not supposed to have that copper plate. I do have those hold-down strips though.
    14. Junior Member verger's Avatar
      Sep 8th, 2010
      Gettysburg, PA, USA
      91 EA Bordeaux Red/ 91 EA Mangrove Green
      06-21-2011 06:27 PM #14
      Thank you very much for showing us!
      John
      91 Etienne Aigner Bordeaux Red
      91 Etienne Aigner Mangrove Green
    15. Member
      May 11th, 2009
      IA
      06-21-2011 07:08 PM #15
      Anyone have any luck to adding grounds above what comes from the factory?
    16. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      06-21-2011 07:21 PM #16
      Adding Grounds is only productive to your desired results. There is no Luck in proper grounding.
      For VW's adding grounds or redistributing the grounds is only gonna help you in the long run.
    17. Member vwtdiwagon's Avatar
      Oct 27th, 2002
      Northern Cali
      '86 GTI, '76 Scirocco, '00 BMW 528I
      06-22-2011 03:49 AM #17
      This should be in the DIY section...Sticky please admin.
      '03 Passat Wagon 1.8t Parting Out http://forums.vwvortex.com/showthrea...-Wagon-partout
      Gone but not forgotten
      '02.5 Jetta Wagon TDI (sold)
      '84.5 Cabby (parted)
    18. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      06-22-2011 04:41 AM #18
      Quote Originally Posted by vwtdiwagon View Post
      There is no DIY section in this forum, only an FAQ section which is, sorry to say, pure and utter useless hodge-podge. Hence: http://www.cabby-info.com/electrical.htm#Ground , which I just updated.
      Edit: URL changed since this post; link updated.
    19. Member Moljinar's Avatar
      Sep 20th, 2001
      Indianapolis, IN
      87 Cabriolet, 85 Cabriolet, 90 JettaGL
      06-22-2011 09:15 AM #19
      The only way to know for sure is to check voltages. The worse looking cable may be fine. The good looking cable may be futzed. Get out the voltmeter and know for sure.
    20. Member Darter's Avatar
      Aug 24th, 2002
      West Milwaukee, WI
      06-22-2011 11:19 AM #20
      There is no DIY section in this forum, only an FAQ section which is, sorry to say, pure and utter useless hodge-podge. Hence: http://cabby-info.com/electrical_system.htm#Ground , which I just updated.
      NICE!! Thanks Kammy! Between that chart and briano's pics, this consolidated info helps a lot!
    21. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      06-22-2011 11:31 AM #21
      The Hood Bonding wire "usually" on the Driver side hinge To the Fender is for RF shielding to the antenna, so that spurious noise "spark plug, and wire" are shielded from the antenna for those that listen to "AM" radio, or for those that have the really older cheap radios that didn't have the proper circuitry to shield the final amplifier in the " Amplitude Modulating Super Hetrodyne" radios. "FM" listeners didn't have that issue, and it isn't truely needed for proper grounding.
      With the Advent of Resistor wires and plugs most manufacturers eliminated the additional bonding wire, or others didn't care at all that you heard a "motor boat" through your radio.
    22. Member vwtdiwagon's Avatar
      Oct 27th, 2002
      Northern Cali
      06-22-2011 08:09 PM #22
      Ya...The thread at the top. Thats kind of what I meant....I guess thats what I should've typed.
      Thanks for updating it on your site. Its a great resource to all cabby owners.
      Do we even have an admin? I guess its because we all play nice and dont need as much supervison as other forums.
    23. n00b tomran's Avatar
      Jun 16th, 2011
      Los Angeles, CA
      1989 VW Cabriolet "Karmann"
      10-20-2011 06:08 AM #23
      I am real new to my Cabby "Princess" and I just gotta' say that with out you guys and er, ah gal, I would be up fudge creek without a Pop-Cicle stick. Oh, she's a fickle one! My Cab, not, oh Gawd! Not you Kam! Puleeze!
      That bit of basting done, I came across this piece on "grounding" and thought I'd pass it on. http://www.gabma.us/elec/proper_grounding.pdf It applies to British motorcycles and may raise the specter of Lucas Electric, "The Lord of Darkness" as they were known by any one who had MG's, Jaguar's, etc. This is a fine explanation of the principal and history of grounding practice. It's pretty short and going on the theory that even though you needn't have knowledge of the workings of the internal combustion engine to drive a car, having it sure makes the ride more interesting and ya' meet so many nice people!
      It occurs to me that grounding in the sense we are using it is very like the "common" in house wiring. The common and ground are for all intents and purposes the same. If your house were of steel stud construction FTSOA, you could in theory run a single "hot wire" and the return could be the framing. The problem lies in that the frame, uninsulated could actually become overloaded and begin to heat up, the whole thing about imbalanced loads yada, yada-- from the get go it's just inefficient. BTW there was one more commandment... #11...and God said,"do what briano1234 says, do it gladly, completely, with a cheerful heart! Oh, and Flapjack in the second at Hollywood Park, that's all, God out!"
      Buying my Cabbie has been a true eye-opener. As a hold-over sanity keeper when I owned an older Mercedes (vacuum goblins, Oy!), I keep a SNL sketch running in the back of my mind with the engineers at VW having little "off the cuff" contests, vying for the most confusing "cross-purpose-let's-blame-it-on-the-Italians" improvements (subtext: "Who rrreally von Vorld Var two? Hmmmm?} Clarity even late got is soooo welcome
      Call me greedy or an idiot... Okay, BOTH! Briano, I love your pics, but for the life of me I am not quite sure just what I am looking for... You get the jist. Is there a way to add some sort of photo editing function to the site? Circles, arrows, etc., in the same way we are able to underline, italicize, embolden or otherwise affect text in posts. Kam has spoken of doing a definitive ground wiring plan but it's a lot of work. I've seen her work as well as that of others on the vacuum distributor switch -- the HVAC control "thingy", it's sensational yet still a work in progress. As am I come to think of it. Am I asking for "unobtanium" here, I don't think I've ever seen this on a site; is it even possible?
      Just askin'. What with the economy tanking -- Lions and tigers and bears, Oh, my! 'N this schmeckle dances in askin' for circles and arrows, OY! Nich bein hock mein chinuk!
      Have a nice day y'all!
      PS Oh I have to mention this B1234, your patience. Some one, I forget exact context, posed the problem you responded, simple cure, he came back with a "NO, I'm simply certain it can't be that yada, yada". I think madrabbit got in at one point "b1234 has good history with this kind of thing you should try before disregarding..." as did several others. This went back 'n forth for a good bit. I kept waiting for a moderator to jump in an tell him to go fly up his own... You were so even handed, impressive. I would love to say this had a fab ending but I don't know, it was just the way you all rally, not so much to the aid but to the solution. I think the guy just took his Radio Flyer and went home, left the field to youse guys!
      I want to be young and wild, and then I want to be middle-aged and rich, and then I want to be old and annoy people by pretending that I'm deaf.
      --Blackadder III "Nob and Nobility"
    24. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      10-20-2011 07:19 AM #24
      My first car was a 58 bugeyed sprite, followed by a 67 MG midget, and a 1972 Rover 3500S, so I am well aware of Lord Lucas....and grounds.
      "Call me greedy or an idiot... Okay, BOTH! Briano,
      to the site? Circles, arrows, etc., ....
      Am I asking for "unobtanium" "
      Yes, you are greedy, and I have circled a few items
      in posts before. So I have take the time to edit a few
      of the pics.
      You have to edit them prior to posting to your "bucket" account,
      or after you have them loaded there.
      "Oh I have to mention this B1234, your patience....
      You were so even handed, impressive. "
      Not always... I too have my bitchy days...be thankful
      you have your car type in the profile
      I Read http://www.gabma.us/elec/proper_grounding.pdf , and he is about 3 miles up the road from me.... He must of read some of my posts...
    25. Member
      Jun 28th, 2006
      Elizabethtown, PA
      '97 Golf (sold), '82 Rabbit 'vert, '92 Jetta VRT, '01 BMW 325i wagon
      10-20-2011 08:42 AM #25
      I haven't answered the poll because more than one of them apply. When daily driving my '82 I went through and cleaned all the main grounding points, as well as adding a few extras. I used 8ga stereo power wire and added 2 or 3 extras and never had electrical issues.
      I will add one of the worst and weakest ground points on (at least early) CIS cars is the ECM ground. On my '82 the ECM is mounted under the kneebar on the passenger side and the ground wire actually runs out through the firewall and connects to one of the cold start injector mounting bolts on the end of the intake manifold. This ground has been known to fatigue over time and break, or get down to only a few strands and will cause serious running issues. If it breaks completely, the car will not run. So be sure to check this ground carefully!
