View Poll Results: wwUd
Voters
28. You may not vote on this poll
  • Suck it up, buy a new truck and enjoy the benefits
    6 21.43%
  • Who wouldn't want to do an engine swap
    5 17.86%
  • If you want to save money, just buy used
    17 60.71%
Results 1 to 26 of 26
Thread: Put together or Buy? Truck question
  1. Member ladykiller's Avatar
    Oct 8th, 2003
    Denial
    3d
    05-03-2011 01:45 PM #1
    I'm wanting to obtain a diesel truck, but don't really want to drop $38k on a new truck. That's just for a 2500HD WT extended cab 4x2 and the only options selected are a Duramax motor and an Allison transmission. I'd want to get a LT 4x4, and that bumps the price up to $44k+
    Lets say you and your friends have the tools, know-how and space to buy a used truck and replace the motor and transmission. But you can only work on it over the weekend. Would you buy a non-diesel used truck, new motor and transmission to save some money?
    Lots of used trucks <$10k
    Duramax motor $ 6900
    Allison Trans $ 4200
    Total ~ $20k
    I guess a 3rd option would be to buy a high mileage (100k+) diesel that I like around $20k. The selection for this option is just more limited.
    i have nerd tendencies
  2. 05-03-2011 02:30 PM #2
    I searched around on autotrader and cars.com and these seem pretty plentiful (the 6.6 diesel, extended cab, 2WD) for under $20k w/under 100k miles. I would go that route because you have a lot of things to think about such as suspension (isn't the diesel much heavier?), plus electronics, wiring harness, doesn't a diesel usually take two batteries(?), fuel system (fuel lines, fuel tank, etc.) plus many things I'm probably missing.
    It just seems like a huge headache, a lot of added expenses and tons of unnecessary frustration plus you would never get that money back out of it and if someone plowed into you and totaled it, again, you're never getting that money and time investment back out of it.
  3. Member Smigelski's Avatar
    Dec 9th, 2008
    Annapolis, MD
    Weekday sports car, weekend sports car, and a suburban homeowner special
    05-03-2011 02:45 PM #3
    Quote Originally Posted by sullie View Post
    I fully agree with this. The swap from gas to diesel is a lot more of a hassle than just engine and transmission.
  4. Member the flying grape!'s Avatar
    Dec 4th, 1999
    08 528i, 02 VW 337, 93 F-150
    05-03-2011 02:46 PM #4
    Why the need for a diesel 4x4? Or is it a want instead?
  5. Member cryption's Avatar
    Mar 27th, 2006
    Houston
    99 Miata, 2011 Fusion, Texas Edition Silverado
    05-03-2011 02:49 PM #5
    Just buy a truck used.
    When you go gas -> diesel you should replace the fuel tank and lines among other things as well
    Team 30k Jetta - Frat Boys
  6. Member 89VWdieselGolf's Avatar
    Feb 22nd, 2004
    Durham, Ont.
    2001 Golf TDI 2004 Passat 1.8T
    05-03-2011 03:04 PM #6
    Quote Originally Posted by ladykiller View Post
    100K is high mileage?? HAHAHA It's diesel! 500K is high milage
    89VWdieselGolf's Autobiography
    2001 Golf TDI
    2004 Passat 1.8T
    1990 Golf ABA Turbo -SOLD
  7. Banned
    Feb 19th, 2005
    Huntsville, TX
    05-03-2011 03:24 PM #7
    Quote Originally Posted by cryption View Post
    If you look around you can find *new* trucks on the lot with ~10k+ in rebates and incentives.
    At least down here in Texas.
    Nov 24th, 2009
    Reno, NV
    02 WRX, 89 Cherokee 4.0l, 91 Olds Cutlass Calais
    05-03-2011 05:17 PM #8
    Why would you hesitate to buy a 100k mile truck? At that point the engine and transmission are not going to be the trouble points; if anything, the suspension will need maintenance, which would apply to your transplant truck as well. And I'd be surprised if you could do it for less than the cost of just buying a diesel truck outright. If you only need an extended cab and 2wd, you will save some money, as the Crew Cab 4x4 shortbed trucks fetch a premium.
    Maybe if you find a wrecked one with all the conversion parts you need. And if you're a very skilled mechanic with knowledge of diesels. And if 100s of hours of your time is worth saving a few grand.
    I could understand doing this for an off-the-wall custom or project. Duramax/Allison swap in to a 67-72 Chevy? Sign me up. Duramax/Allison powered Grand National clone? Absolutely. But for something you could buy off the shelf? I don't see much point.
    Something else to consider, if you have emissions testing and inspections, it's likely that you'll run in to issues. I don't know the specifics, but I've heard things from the offroad community about having trouble swapping Cummins engines in to their trail rigs. However, I don't know if this applies to newer vehicles/engines.
  9. Senior Member SSLByron's Avatar
    Jul 29th, 2004
    Annapolis, MD
    05-03-2011 05:21 PM #9
    Quote Originally Posted by Rex_WRX View Post
    Most of them are probably running into issues because they don't put OEM-equivalent exhaust systems back on the engines after the swap, and because full-size trucks aren't subjected to the same limitations as light-duty trucks and passenger cars. The emissions rules follow the chassis, not the engine.
    Swapping from one HD chassis to another wouldn't be as problematic from that standpoint.
  10. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    05-03-2011 05:24 PM #10
    Quote Originally Posted by 89VWdieselGolf View Post
    I was a little confused at this too lol. I thought they only broke in at 100k miles.
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  11. 08-08-2012 11:22 AM #11
    +1
    ...if you don’t want to spend too much, try to buy a used truck then buy at least tools you would need for repair/maintenance try to check this site: http://www.stylintrucks.com/category...d-_garage.aspx hope this could help you
  12. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    08-08-2012 11:55 AM #12
    100K is high mileage? It's diesel! 800K is high milage
    Fixed.
    If you want to build your own truck, you need to find a mechanically injected diesel motor, 6.5td, 6.9/7.3idi, 4bt, 6bt, dt466, 3208, 4bd1t/2t, Deutz, Perkins, etc.
    Then choose your transmission, the,th400 auto is really popular, so is the NV4500. Once you have your swap, rebuild it, then find a body, 86 GMC 3500 3+3 crewcab would be nice, or any 70s, 80s, or 90s 3/4 ton, crewcab 4x4.
    Re: http://forums.vwvortex.com/showthrea...=Nissan+diesel
    I built a 1978 F350 Supercab, 4x2, Isuzu NPR 4bd1t swap, T19/Doug Nash 2 speed. 4:10 rear axle, with a Detroit eLocker. Email me, I have plenty of pics. Pulled like a train.
    Have fun.
  13. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    08-08-2012 12:05 PM #13
    i guess it depends as well on how you value your time...
    i dont think swapping a gas truck to a diesel would be all that fun though.
    honestly id either do the swap to something really old, or just buy a new(er) truck set up how you want it
  14. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    08-08-2012 12:22 PM #14
    Hmmmmm, AIRCOOLED DIESEL: http://www.magirusdeutz.co.uk/MD8deutz.htm
    Read the whole article, really interesting.
  15. 08-08-2012 01:17 PM #15
    I've always dreamed of swapping a Duramax/Allison combo into an older Dodge Ramcharger or an even older Chevy 3500 Dually P/U. Other than the gas lines/gas tank which doesn't seem like that much work, why is it so hard to do?
  16. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    96 Jetta - 300K Club, Truck, Boat, Quad
    08-08-2012 01:18 PM #16
    100K on a diesel is like 10 miles on a gas engine
    There aint no OZ in rape.
  17. Member MCTB's Avatar
    Dec 29th, 2005
    NoVa
    '12 Focus SE, '72 MGB GT, '58 MGA
    08-08-2012 01:20 PM #17
    Theres more involved than that. You will have WAY more than 20k in that truck before its legally re registered and back on the road.
    You think you hate it now. Wait til you drive it.
  18. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    08-08-2012 01:22 PM #18
    Quote Originally Posted by MCTB View Post
    swaps always sound so easy...
    its just an engine/trans, what could go wrong
  19. Member zane!'s Avatar
    Jul 27th, 2005
    WA
    Drivers, beaters, pedal bikes
    08-08-2012 01:25 PM #19
    Quote Originally Posted by ValveCoverGasket View Post
    This x10000
    It's not just an engine and trans... ECU and wiring, TCM and wiring, drivelines, engine and trans mounts, fuel lines, EVAP, tank... the list goes on.
  20. Member personman's Avatar
    Sep 24th, 2008
    TX
    03 Golf, 94 GS500, 13 WRX
    08-08-2012 01:26 PM #20
    How old is this thread?
  21. Member zane!'s Avatar
    Jul 27th, 2005
    WA
    08-08-2012 01:26 PM #21
    Quote Originally Posted by personman View Post
    Haha we fail.
  22. Member MCTB's Avatar
    Dec 29th, 2005
    NoVa
    08-08-2012 01:31 PM #22
    Gas V8 for gas V8...not too tough. A full diesel swap is the thing dreams are made of. I thought about it but then realized it would be smarter and cheaper to buy one (a diesel Cruiser, that is).
    Whats odd is there was less of the usual TCL "put an LSx in it." I know it has one but where was the 8.0 suggestion?
  23. Member Cousin Eddie's Avatar
    Dec 17th, 2005
    Ontario, Canada
    That there's an RV, Clark
    08-08-2012 01:45 PM #23
    Brodozin' ain't cheap pal.
  24. Member Broduski's Avatar
    Nov 18th, 2008
    Barbeque Capital of the World, NC
    Old Stuff.
    08-09-2012 05:38 PM #24
    Quote Originally Posted by pho View Post
    Pics and Videos please. I want to see this.
    A Ford, two Dodges, and a Volvo.
  25. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    08-17-2012 12:13 AM #25
    Talkin about a ninja bump. Wow, just checked out the initial thread date,
    Sheesh.
  26. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    08-22-2012 12:44 PM #26
    its just an engine/trans, what could go wrong.
    Quote Originally Posted by 16v_43v3r View Post
