VWVortex.com - Can I use an skc to deactivate immo?
    Results 1 to 11 of 11
    Thread: Can I use an skc to deactivate immo?
    1. 05-05-2011 05:11 AM #1
      I have an 2002 jetta GLS and want to de-activate the immobilizer. I believe I have the
      7 digit skc black tag. Its like the one pictured in this link except it just has the digits on the left NOT the right. Can anyone confirm?
      http://<a href="http://imageshack.us...&#91;/IMG]</a>
    2. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      05-05-2011 10:34 AM #2
      There's no such thing as a 7 digit SKC tag, so no.
    3. 05-05-2011 01:41 PM #3
      I can help you with this with proper documents submitted.
      Best,
    4. 05-06-2011 02:26 AM #4
      ok what do you need? or can I just swap the cluster and go that route?
    5. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      05-06-2011 10:04 AM #5
      If you want to swap clusters then you Will need SKC and do swap procedure, in your case you will need SKC from both clusters:
      http://wiki.ross-tech.com/wiki/index...ent_Cluster%29
      Immo delete can be done ONLY in ECU , It CAN NOT be done in Cluster.
      Cars after 2001 did not have SKC on tag , and the cars who had SKC on tag it was ONLY 4 digit code.
      My Jetta TDI MK5 with MK6 Color cluster
    6. 05-06-2011 11:39 AM #6
      Hey guys,
      Immo defeat can be done in the cluster and the engine ecu.
      I do this for people who don't want a key light for the keys not just the ecu response sent back.
      You can email me direct for legal forms.
      Already answered you in the PM. Stokes.
      To do a transfer even with both skc codes in VCDS or VAS tester will result a second Vin identity displayed in the cluster.
      This you don't want.
      Best,
    7. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      05-06-2011 12:26 PM #7
      Quote Originally Posted by Jack@European Parts View Post
      Hey guys,
      Jack it is not possible to delete IMMO in cluster.
      Best,
      No really if you know how to do it.
    8. 05-06-2011 01:04 PM #8
      Hey Jetta97
      Why would you go as far as to say it cant be done in the cluster?
      Yes you can delete/defeat the immo function in the cluster, just as you can in the engine ecu, its just a matter of knowing what to do.
      You said the same thing about the packet TX/RX on CAN for W not being possible, when I truely know it is for sending back data to shut the key light out in cluster from ECU response.
      You are correct on the VIN data if you are creative which most are not like you are, there is a way to do it.
      So whats up man, is it busy in TX?
      best,
      Jack
    9. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      05-06-2011 04:38 PM #9
      I am always busy,
      OK, tell me how is the possible to delete Immo in cluster, so if you insert different none reprogram key the Immo light will not flash?
    10. 05-06-2011 06:09 PM #10
      You know I can't say how here.
      That would be telling.
      It can be done though lol.
      Check this thing I started up.
      http://forums.vwvortex.com/showthrea...1#post71443323
      Best,
    11. Member zeroboy's Avatar
      Sep 3rd, 2005
      Audi
      02' S6 Atlas grey / 02' S6 Silver
      05-13-2011 03:17 PM #11
      Quote Originally Posted by The Strokes View Post
      That's not an SKC, it's actually called a "key code" which corresponds to the physical key profile for your car. Every once in a while on that black tag there would be another half of that white sticker - to the right. It would have had the SKC, I got one with our 04' Passat.
