Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 248
Thread: The Hoedown On Catch-Cans
  1. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    MkVI GTI/2Dr Manual Trans / Future Golf-R Owner
    05-11-2011 12:02 AM #36
    Quote Originally Posted by crew219 View Post
    more evidence as to how catch cans don't work:
    http://forums.vwvortex.com/showthrea...res-Discussion
    This is the truth, "the beef" redux was looking for. It's proof that these cans are pure .
    I'd bet the EGR system is at play here as well! Remember CC's do not address the exhaust gas recirculation system. Those exhaust gases must also be full of oil.
    Gott ist immer auf der Seite des stronest Armee. - Voltaire
    Future Golf-R Owner
    "Those who defend corruption, are often practicing corruption." VWRedux
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    05-11-2011 01:58 PM #37
    Why would the exhaust gases be full of oil ??? (Maybe only if the engine is burning oil because the PCV system isn't filtering the oil mist out before it gets into the intake stream.)
  3. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-12-2011 12:44 AM #38
    Quote Originally Posted by CC'ed View Post
    During the initial start up of any car, especially if cold, the combustion is never complete nor efficient. The exhaust gas is always filled with disproportionate amounts of unburned fuel, condensed water vapor, oil from ring blow by, valve guides etc. until things start to warm up and tighten up. This doesn't last very long, approx. 15-25 min. depending on the ambient temperature. This condition, known as the *initial warm up phase*, is what caused the EPA to mandate that exhaust gases be recycled in the first place, thus the need for an EGR Valve and Regulator was born.
    Today these EGR systems are controlled by the on board fuel management system. It allows these initial gases that are filled with all kinds of unburned fuels, oils, etc. to be recycled and burned again and again, and again in an effort to reduce emissions. These gases are directly injected into the port side of the induction manifold where they normally combine with the PCV gases before flowing past the intake valves. These heavy vapor particles will adhere to these intake valves where they will convert to carbon deposits later on as the engine reaches it's operating temperature. (Let's not forget the exhaust valves. They too will probably need cleaning because of the drawbacks of the DI design.) This accumulative action will mandate a full carbon and valve cleaning be performed since there is no other mechanism to clean the valves such as in the case of cars with port FI instead of DI.
    Therefore, it now appears that catch-cans remove far more water vapor that's generated in the crank case during warm up than they do oil vapor later on in their work day! (See links provided in this thread). It makes sense that if these cans are filled with mostly water and very little oil, and this water is only generated during the warm up phase, then they must really do a piss-ass job of removing the oil vapor during the rest of their day. If these cans were doing a better job, then there would be much more oil than water. The evidence appears to show otherwise. (It's disproportionate)
    That means that the oil vapor is still getting to the intake valves even with a CC installed. Add to that the daily recycling of oil latent EGR gases that have no way of being removed from the equation during the initial warm up phase and what are you left with? UGLY ASS INTAKE VALVES that will need a full C&V job no matter what you do.
    "HEY DUDE, OWN A 2.0FSi or TSi VW? I HAVE JUST WHAT YOU NEED BRO, A CATCH-CAN!"
    . Is this Mike?
    Future Golf-R Owner
  4. 05-12-2011 08:31 AM #39
    You're forgetting that "carbon deposits" can also be left by gasoline.
    Dave
    Dec 1st, 2009
    05-12-2011 08:59 AM #40
    The purpose of EGR is not to burn (or reburn) any residual "unburned" stuff (fuel or oil), it is used to introduce an "inert" gas (the exhaust contains very little oxygen), to dilute the mixture, which reduces combustion temperatures, which reduce NOX (nitrogen oxides) in the exhaust. The EGR typically is only enabled AFTER the warm-up cycle, and operates typically only under part-throttle operating conditions.
    I believe the valve deposits on DI engines is mostly due to the EGR, which does introduce carbon crap onto the intake valve, but I think the oil mist that gets thru the PCV system adds additional crap that deposits on the valves and ports. I think the TSI engine has less deposits than the FSI engine because VW reduced the amount of EGR, or changed how and when its used.
    On the observation about water versus oil ratio of what is found in the a catch can: There is far-more volume of water vapor generated when gasoline is burned, compared to the volume of oil mist that is not completly filtered-out by the stock PCV baffles, oil seperator, and added catch-can. From what I can see, only two of the availible catch-cans have a somewhat effective oil-mist filter, that's the Conceptual Polymer and the ProVent. The typical metal baffles and/or stainless-steel wool, found in most catch-cans, are not an effective filter for oil mist particles. You need a "coalescing filter" which filters particles down to a few microns....
  6. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-12-2011 09:40 AM #41
    The purpose of EGR is not to burn (or reburrn) any residual "unburned" stuff (fuel or oil), it is used to introduce an "inert" gas (the exhaust contains very little oxygen), to dilute the mixture, which reduces combustion temperatures, which reduce NOX (nitrogen oxides) in the exhaust. The EGR typically is only enabled AFTER the warm-up cycle, and operates typically only under part-throttle operating conditions.
    Correct, but it does as a consequence of its design. My efforts above were not to describe how EGR works, but to show that because of what it does, it contributes to the issue at hand. There are some systems that do initiate EGR during warm-up. I believe VW is one of them. In ether case, it appears that the EGR system is a contributor to the carbon build-up on the intake side. Off topic, you are correct that EGR is a nitrogen oxide (NOx) emissions reduction technique. As stated, it works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. In a gasoline engine, this inert exhaust displaces the amount of combustible matter in the cylinder. But in a diesel engine, the exhaust gas replaces some of the excess oxygen in the pre-combustion mixture. Because NOx forms primarily when a mixture of nitrogen and oxygen is subjected to high temperature, the lower combustion chamber temperatures caused by EGR reduces the amount of NOx the combustion generates. As control systems grew more sophisticated, the impact on engine performance improved but other problems were introduced. In a typical automotive spark-ignited (SI) engine, up to 15 percent of the exhaust gas is routed back to the intake as EGR. The maximum quantity is limited by the requirement of the mixture to sustain a contiguous flame front during the combustion event. But in poorly set up applications, an excessive EGR can cause misfires and partial burns. Although EGR does measurably slow combustion, this can largely be compensated for by advancing spark timing. The impact of EGR on engine efficiency largely depends on the specific engine design, and sometimes leads to a compromise between efficiency and NOx emissions. EGR is typically not employed at high loads because it would reduce peak power output. This is because it reduces the intake charge density. EGR is also omitted at idle (low-speed, zero load) because it would cause unstable combustion, resulting in rough idle. Since the EGR system recirculates a portion of exhaust gases, over time the EGR valve can become clogged with carbon deposits that prevent it from operating properly. So it stands to reason that these same gases will do the same to the intake valves as well in a direct injected engine. Today's modern systems utilizing electronic engine control computers, multiple control inputs, and servo-driven EGR valves typically improve performance/efficiency with virtually no impact on drivability, that is, until the intake system on direct injected cars are choked by carbon deposits.
    One fact remains, direct injected cars like ours lack the necessary intake cleaning mechanisms of other designs. In an effort to improve overall mileage, and keep costs down, engineers decided on a design compromise which sacrifices the intake systems of these cars. There is no doubt that EGR systems, by design, only contributes to the problem.
    Future Golf-R Owner
  7. Junior Member Made in America's Avatar
    Apr 10th, 2011
    2010 Passat Wagon 2.0T
    05-12-2011 10:35 AM #42
    So what is the solution? Or is there a solution? Is it inevitable that the intake valves will need to be cleaned by 40k miles? Sounds like a giant pain in the arse.
  8. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-12-2011 11:09 AM #43
    valves this
    valves that
    CCs do more than just help with valve cleaning, everybody just suspected CCs to be some kin dof miracle drug that would fix all the problems with our motors.
    As I have stated MANY MANY MANY times now, CCs have other benefits like removing the PCV gases from your intake, trbo, T.O.P., IC, TB pipe, TB, Intake Manifold, and combustion chambers.
    I am 100% sure that there are still added benefits from having a CC than from NOT having one.
    If you dont believe me, then dont FREAKING BUY ONE.
    /thread
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
    Dec 1st, 2009
    05-12-2011 01:31 PM #44
    The best solution to the intake valve deposits would be to disable EGR, but that would cause pre-ignition issue. Also, it can't be easily done, as the EGR is accomplished by increasing the overlap of the intake camshaft, opening the intake valves earlier, overlapping when the exhaust valve is open. Changing that would require changing the ECU maps for the variable intake cam timing.
  10. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-12-2011 01:55 PM #45
    I suspected this was the type of EGR used on our TSi's especially since I cannot locate any EGR device or valve. But doesn't the TSi share the same Bosch Motronic MED engine management system as the FSi? Check out this Bosch video, and take notice of the EGR system used.
    Future Golf-R Owner
  11. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-12-2011 02:05 PM #46
    Quote Originally Posted by Made in America View Post
    there is none, no there isn't, yes, and you bet it is!
    Future Golf-R Owner
    Dec 1st, 2009
    05-12-2011 05:06 PM #47
    Quote Originally Posted by ManTech View Post
    The Bosch video shows an EGR implemented with a separate EGR valve and passage into the intake manifold. The FSI may be like that, I don't know that engine. The MED engine management can be used in various configurations, MED only indicates the family, or generation of engine controller, not its specific detailed features (such as separate of variable valve-timing implemented EGR). For example, the Audi A4 TSFI has an different configuration of the MED controller, as it also controls the exhaust camshaft timing, which the TSI does not.
  13. Junior Member Made in America's Avatar
    Apr 10th, 2011
    05-12-2011 06:01 PM #48
    What about this service from BG?
    http://www.bgfindashop.com/bgservices/fuelair.htm
  14. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-12-2011 11:14 PM #49
    I dislike their products. Had this service performed on a Mazda I once had that failed inspection. It ruined two O2 sensors, along with a few temperature sensors. BG refused to fix them. Never trusted treatments as a fix for everything.
    In any case this stuff is outdated. it may have helped during the 80's and 90's but not with these new engines.
    Future Golf-R Owner
  15. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    05-18-2011 03:09 PM #50
    EGR valves..... there is no EGR valve on the engine.
    There is EGR function though via the overlap of the exhaust valve timing and intake valve timing.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  16. Member
    May 10th, 2010
    North Jersey
    05-18-2011 03:12 PM #51
    BG has a different service for gas direct injection
    http://www.bgprod.com/news/GDI.html --- no experience with it though
    Other Rides:
  17. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-19-2011 12:08 PM #52
    Quote Originally Posted by BsickPassat View Post
    Todays EGR is either done through timing overlap or through a servo controlled valve. The Bosch MED control FI system utilizes a servo valve. Do you have written proof that our 2.0TSI's have timing overlap? If so, please post or shut up. Thanks.
    Future Golf-R Owner
  18. Member
    May 10th, 2010
    North Jersey
    05-19-2011 01:08 PM #53
    Do you?
    Go read the self study manual for the engine, Self-Study Program 824803 --- there is no EGR servo valve shown as an actuator in the MED 17.5 system for the engine
    and the bentley manual doesn't show a EGR valve either.
    Other Rides:
  19. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-19-2011 04:58 PM #54
    Do you?
    Well the Bosch video is all I have. But I did look at my copy of VAG SSP and you're right, it doesn't show a valve, (mechanical nor electronic) but it also doesn't say if it utilizes a valve timing overlap either.
    Future Golf-R Owner
  20. Member
    Dec 1st, 2009
    05-20-2011 09:17 AM #55
    The BOSCH video is a generic technical sales pitch on the MED system, it is not meant to be a specific design description of the VW FSI or TSI applications.
    What's the argument ? The TSI, and probably the FSI use valve overlap to acheive EGR.
    Another note : Don't take the VW Self-Study Course as the "Bible" either, the TSI one has some mistakes/ommisions, as it was probably written before the final design was settled. The TSI course document shows a breather pipe and check-valve for fresh air into the PCV system, from the pre-turbo intake duct to the valve-cover, which does not actually exist on the TSI.
  21. Member
    Mar 26th, 2008
    Fredericksburg, VA
    '12 R; Built GTI TSI 3+
    05-23-2011 10:53 PM #56
    VWrEdux - thank you thank you! It's about time somebody called this ****ing scam out. And I'm not surprised the most brainwashed people are responding and being defensive against you. You all are a bunch of suckers. Go scope your valves and realize how you got played.
    11.53@121.18
  22. Member
    May 10th, 2010
    North Jersey
    05-24-2011 11:35 AM #57
    It implies it in the cam phasing system.
    INA Camshaft Adjustment System
    The 2.0L TSI engine uses a hydraulic vane cell adjuster on the intake camshaft to affect valve
    timing. Only the intake camshaft has variably adjusted timing on this engine. Oil pressure for this
    task is provided by the engine oil pump. The variable camshaft adjuster provides an adjustment range of 60° crank angle. The camshaft is locked in the retard position at engine shut-off. This unction is performed by a spring-loaded locking pin. The camshaft is released when the engine oil pressure exceeds 7.25 psi (0.5 bar). The rotor of the vane cell adjuster is welded to the intake camshaft. The 4/3-way central valve required for adjuster control is integrated in the camshaft.
    Intake camshaft timing is map-controlled by the engine control module. The goals are to improve engine power, enhance running smoothness, and reduce emissions (through internal exhaust gas recirculation).
    Other Rides:
  23. Member dsm1983's Avatar
    Aug 8th, 2009
    Birmingham, AL
    '10 GTI, '09 JSW TDI
    05-24-2011 01:14 PM #58
    Quote Originally Posted by steelcurtain View Post
    you're like
    and i'm like
  24. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    Started NHTSA DSG Campaign/'09WolfieDSG died@623mi. VW took it back.Bought MkVI/GTI Blk 6spMT/SR/Xen
    05-24-2011 09:14 PM #59
    Thanks! You're welcome! I was just stating the obvious. I had a can in one of my tuned cars a few years back. Ended up throwing it away in the garbage after I discovered it did nothing. When I was a kid, (17) I rebuilt a 1964 Chevy Corvair Turbo Spyder, (200 hp, water/meth injection, the works). I installed a catch-can from JC Whitney even back then. What a hunk of crap the whole concept is. Sure it helps a little, but the rest is just pure fantasy island .
    "There's nothing like a well tuned car on an open road". Paul Newman
    *The New 2011 VW Jetta... At Least You Pay Less To Get Less!*
  25. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    05-24-2011 09:24 PM #60
    Yes it is mantech... it's the "beef" I was looking for alright. (His post below couldn't be clearer!) I'm not sure about the EGR playing a roll, but maybe All I know is that the guys who push this trash based on false advertising should offer refunds to all those who ask for it.
    ______________________________
    THE "BEEF" THAT PROVES THAT CATCH-CANS ARE
    Quote Originally Posted by staulkor View Post
    You know of the intake valve issue that plagues our engines. I have some pretty good comparison pictures of what an atmospheric catch can actually does. To my knowledge, there havent been pictures taken of one's car with, and then without, a catch can with a good amount of mileage in between while keeping the same engine mods.
    Below is a set of comparison pictures. On the left are my valves from 0 to 50,000 miles without a catch can (I got a catch can at maybe 45k, but the damage had already been done, so I am ignoring this). On the right are my valves from 50,000 to 87780 miles with a BSH atmospheric catch can.
    Note: For 50-80k, there was less carbon on the valves than from 0-50k.
    Note: Both scenarios had considerable build up on the walls.
    You must remember, the pictures with the catch can only span 38,000 miles instead of 50,000 miles. This means there will be less build up regardless of what modifications are in place to alleviate blow by build-up, so take this into consideration.
    Also, please note that since this is an atmospheric catch can, I am assuming it is a perfect catch can; meaning that ALL blow by goes out of the engine and is not consumed. This is in comparison to a recirculating catch can where most, but not all blow by gets filtered. Recirculating systems are not a perfect system and there will be a small amount that goes back in the engine and is consumed. With that being said, I consider this comparison a best case scenario in terms of the least amount of blow by possible.
    With that said, this is what I conclude from the comparison pictures:
    Catch cans work, but I don't think they work as well as we have been lead to believe. They are effective, but only so much. The pictures show there is still a major carbon issue, and this will NOT magically fix your issues. It may delay when the issues start occurring by a few thousand or even tens of thousands of miles, but who knows.
    The catch can did more than I was expecting. I thought the catch can would have done next to nothing, but that clearly isn't the case. It did prevent some carbon build up, however much that may be, but the buildup that did collect and the amount of carbon is considerable.
    I believe catch cans have a place for the FSI. They work as advertised, albeit less than you are lead to believe, but they work nonetheless. Please take the pictures into consideration when buying a catch can. Remember that they are no magic cure for carbon buildup. That carbon is a tenacious bastard and take up camp on your valves no matter what you do to prevent it.
    ANYWAY, enough with the serious **** and here are some pictures from the job
    Also, that is what you have to deal with having an atmospheric catch can. It is DIIIIRRRTTTYYYY! I degreased everything and the catch can has been removed. I dont consider it worth the mess for the minimal benefits.
    UPDATE: The pics in the post above have been mysteriously lost but they did show the before and after PROOF that catch-cans do very little, if anything, to help the intake port/valves. As Mike later agrees, catch-cans were not designed for this... even though he lists it as a reason to buy his product.... scam.
  26. Member
    May 10th, 2010
    North Jersey
    05-25-2011 07:33 AM #61
    EGR plays a big role in it.
    I know this from back when I had my MKIV TDI, where we have that issue, which VW won't acknowledge. Dialing back on the duty cycle or eliminating it completely basically makes the intake clogging a non-issue.
    Other Rides:
  27. 05-25-2011 09:36 AM #62
    Quote Originally Posted by VWRedux View Post
    Yes it is mantech... it's the "beef" I was looking for alright. I'm not sure about the EGR playing a roll, but maybe All I know is that the guys who push this trash based on false advertising should offer refunds to all those who ask for it.
    I noticed that BSH pulled the pics of dirty valves off their website. Lol!
  28. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    05-25-2011 11:58 AM #63
    I wonder if that means what I think it does?
    Future Golf-R Owner
  29. Member
    Mar 26th, 2008
    Fredericksburg, VA
    05-29-2011 08:31 AM #64
    Quote Originally Posted by dsm1983 View Post
    you're like
    and i'm like
    Not mad at all. I was laughing thru the whole read! Good info on EGR too and still not a single response from the top 3 sellers of catch cans.
    11.53@121.18
  30. Member
    Jul 27th, 2007
    Ottawa, Canada
    07 Rabbit, 10 Tiguan, 1928 Chev, 02 Dakota
    05-29-2011 08:49 AM #65
    None of them are going to respond to this thread and I don't blame them one bit. No matter what they say, it will end in argument.
  31. Member xnox202's Avatar
    May 18th, 2009
    Brunei Darussalam
    10' A3 SB 2.0 TFSI S-tronic
    05-29-2011 01:40 PM #66
    So anyone with the exhaust cut-out on the TSI? If it's possible, I'm going to do it.
    2010, Matte "WRC" / 02C Blue - Audi A3 Sportback 2.0 TFSI DSG
    APR Stage 2+ RON 104 | Eurojet 3" DP | BSH (Pendulum Mount/Throttle Pipe) | Forge DV/Boost Tap | AWE TOP | Neuspeed TSI Torque Arm Insert | JOM Blueline CO | Snow Performance Stage 3 WMI | LED @ Full Interior/License Plate | Blacked OEM Headlamps, Audi Rings| CF @ Roof Spoiler/Side Mirror/B-Pillar | Work VS-XX 18x8.5" ET45 F/18x9.5"R ET40
  32. Member VWRedux's Avatar
    Jun 3rd, 2009
    Potomac Maryland
    05-31-2011 01:06 AM #67
    Quote Originally Posted by shawng View Post
    Why would it end-up in an argument? If they have conflicting facts, facts that prove that catch cans actually do postpone or eliminate carbon and valve jobs on 2.0 FSi and TSi engines, I think we would all like to see it! And if this evidence is credible, and contradictory to that which has already been field tested/confirmed and plainly presented (the so-called "beef") by our friends above who posted links to their side by side photo comparison, we would not argue the point with the catch-can manufacturers, we would be joyous and seek further confirmation by duplication.
    However I fear they are declining to get involved either because they have nothing to prove their case, or they wish not to do some real work for a change. They rather just sit on their fat butts while milking our wallets. So it's better they not respond because we will press them for evidence to prove that their product is indeed beneficial by SUBSTANTIALLY reducing the carbon build-up inside the intake ports of DI VW's, which will require that they get up off the couch for once.
  33. 05-31-2011 02:03 AM #68
    BSH responded to the thread where those pictures originated from on golfmkv. Said the CC was more for keeping oil out of intake/charge/fmic pipes than reducing buildup. The amount of oil I had in my pipes is enough for me to finally pickup a CC. If that is all it does I guess that is good enough for me.
  34. Banner Advertiser Forge US's Avatar
    Jul 31st, 2002
    Orlando FL
    '09 TTS / '12 Golf R
    06-02-2011 01:32 PM #69
    I'll chime in.
    Absolutely nowhere have we ever stated that a catch tank kit, ours specifically, is guaranteed to prevented carbon buildup on your intake valves. If you purchased one of our kits under the assumption that the potential for carbon buildup was going to be completely eliminated immediately upon installation, either someone else led you to believe that, or you came to that conclusion on your own, because no one here would ever had stated as much to anyone.
    While we do advertise them as eliminating the return of oil, fuel, and water vapors to the intake tract, as well as LIMITING the potential for intake valve deposits, we do NOT claim that our product eliminates the deposits completely.
    It is a known fact that leaking valve guides are another contributing factor that can lead to valve deposits as well, and that potential issue has not yet been addressed by the OEM or aftermarket to our knowledge, so it cannot be overlooked.
    We have never guaranteed specific results that anyone can expect from the installation of a catch tank, so to demand that we substantiate claims that have never been made is simply not going to fly. We developed a product that we would use on our own vehicles, and do for that matter, and that we saw a need and a demand for within the market, so we have fulfilled that niche, as others have as well, and the products appear to be performing as intended.
  35. Member ManTech's Avatar
    Oct 13th, 2010
    NYC
    06-02-2011 03:44 PM #70
    Quote Originally Posted by Mike@ForgeMotorsport View Post
    I'll chime in.
    Well thanks for setting the record straight but that's not exactly how I remember it. Every catch-can thread on vortex to mkv and vi etc was filled with references to the carbon issue as the number one concern by potential customers. And every vendor responded that catch cans do "eliminate all" pcv vented oil. A misleading response in my opinion.*
    And so here again you make the same claim that your catch-can "eliminates the return oil", do you not?
    So do you have any evidence to back up that claim? How do you know this? Can you accurately measure the amount of oil, fuel and water etc venting from the system at all times and the proportions captured by the catch-can vs that which gets by? If you do, please provide it because all factual evidence says they do not. In fact the above evidence proves that much more is bypassing the can than you realize. *Simply implying that your product eliminates the return oil, and let there be no mistake, the word *eliminates* means all oil, may lead your potential customers into believing that your product will significantly help reduce carbon build-up, when in fact it does not. Plus your theory that carbon build up within the intake port is caused by leaking valve guides is also unsubstantiated because valve guide leakage is at worst almost negligible in a brand new engine.
    All fingers point to vendors like you who have taken advantage of those who may not understand your job here.
    Future Golf-R Owner
