VWVortex.com - Dually VS tandem axle pick-up trucks?
    The Car Lounge
    Results 1 to 17 of 17
    Thread: Dually VS tandem axle pick-up trucks?
    1. Member Bakounine's Avatar
      Jul 15th, 2002
      Ottawa
      05-06-2011 09:14 AM #1
      Perhaps someone can school me on this. Why is it that we only see dually pick-up trucks on the civilian market while tandem axles seem more accepted in the military?
      What are the advantages and disadvantages for each?
      It seems to me that a tandem axle would be able to carry more because, well, it's got two axles... I guess the turning radius would be bad, but the the sheer width of a dually doesn't make it much more city-friendly.
      Cost? The new Ram dually has an all metal dually-specific bed instead of the traditional grafted-on fenders, so makink a tandem-axle bed would probably be easily feasible and not to costly, no?
    2. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      Current: Audi S4, B9 Allroad, Porsche Boxster S, Ford F-150 FX4 4x4
      05-06-2011 09:19 AM #2
      Because as much as marketing wants to tell you otherwise, all "civilian" pickups are light duty vehicles. None have the payload or towing capacity to warrant more than one rear axle.
    3. Member mobile363's Avatar
      Oct 13th, 2003
      2012 Kia Rio5 6MT, 2012 Dodge Caravan
      05-06-2011 09:22 AM #3
      A 3 axle vehicle also requires a higher license.
    4. Member clutchrider's Avatar
      Dec 10th, 2010
      Connecticut
      2012 GLI
      05-06-2011 09:24 AM #4
      Dodge T-Rex, saw it at the Big E a few years ago. What an awesome looking truck.
    5. Member shake_n_bake's Avatar
      Jul 7th, 2009
      Atlanta, GA
      05-06-2011 09:36 AM #5
      Quote Originally Posted by mobile363 View Post
      x2
      Besides more axles equals more money. Also 26,001 lbs requires a CDL, so the extra capacity of another axle is not needed.
    6. Member
      May 27th, 2008
      Malvern, PA
      2015 GMC Sierra, 1998 TJ 5.3L/465/Atlas, 1996 F250
      05-06-2011 09:39 AM #6
      The center axle would be very expensive.
      Typical rears have a pinion yoke, or 3rd member to receive power from the driveshaft, then 2 axle shafts. In your average 1/2, 3/4, or 1 ton applications, most axle loads are under 10,000 pounds. A dually dana 70 or 80 could be up around 15,000.
      The axle tube itself is much stronger, and the hubs are different, but other than that, a dually axle and a SRW (single rear wheel) axle share the same axle shafts, gears, carriers, brakes...
      To get that power take off from the center axle, to drive the rear most axle, I know a rockwell has it off the top of my head, which is why a deuce & a half has a PTO
      See that there's an input & output shaft on top of the diff in the top right corner? That's what's cost prohibitive.
      Because most pick-up axles are something like this, with only an input yoke:
      The T-rex has something like this, although I'm not sure if this is the OEM unit:
    7. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      '77 Bronco '85 Toyota 4x4 '87 930 '91 M5 '08 Xterra
      05-06-2011 09:43 AM #7
      A single heavy duty axle is cheaper to build and maintain than two medium duty axles. Costs start to spiral when you add in additional suspension components needed for an extra axle. Think about things like the number of shocks, springs, spring hangers, u-joints, and sway bars needed to hang another axle under a pickup.
    8. Awaiting Email Confirmation
      Aug 4th, 2006
      05-06-2011 10:01 AM #8
      Quote Originally Posted by Bakounine View Post
      Probably bc you aren't/haven't been in the "military". Read up on the Commercial Utility Cargo Vehicle, or CUCV. A 4WD Dually CUCV is one tough SOB.
      Tandem axles are more $ and take up a great deal of space, thus are typically found on much larger (size & capacity) vehicles.
    9. Member PlatinumGLS's Avatar
      Aug 2nd, 2003
      Shelby Township, MI
      7.4, 5.7, 5.3 & 3.0TT
      05-06-2011 10:48 AM #9
      Quote Originally Posted by patrickvr6 View Post
      Not only costs but weight as well. Plus the MPG penalty...
    10. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      '86 Interceptor 700, '82 Quantum Coupe, Hyundai Elantra GT Daily
      05-06-2011 11:02 AM #10
      I imagine that with advances in metallurgy and tires, tandem axles will become more and more relegated to obscure super-high capacity vehicles, and on trailers where you don't have to deal with driving the wheels and space isn't so much a constraint.
      There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
    11. Awaiting Email Confirmation mk3er's Avatar
      Jan 5th, 2007
      North of The Wire
      2012 Shadow Blue GTI 4 door 6MT
      05-06-2011 11:10 AM #11
      I'm gonna throw some Eatons on my lifted F-350 for extra bro-dozeability.
    12. Member mack73's Avatar
      Jan 2nd, 2002
      Seattle
      '08 LR3, '12 A6 3.0T
      05-06-2011 11:24 AM #12
      Quote Originally Posted by mk3er View Post
      Unless I am missing it, who said this had to be a 6x6
      Use the standard axle for the front wheels, then just a non powered axle for the rear wheels. A little bit more weight, but no more complexity or requirement for multiple drive shafts and rear ends over a standard dually.
      '08 LR3 HSE: The Daily/Off-Roader
      '12 A6 3.0T: The Wife's Fast Ride
    13. Member Bakounine's Avatar
      Jul 15th, 2002
      Ottawa
      05-06-2011 11:25 AM #13
      Is it even necessary to have power to the third axle? If it's only for extra support, perhaps a hollow tube with brakes at each end would suffice?
      As for the argument about hd vs light duty, some UTVs use a tandem configuration in the back, so wether it is for a light, medium or heavy duty vehicle, I think the point of adding more capability is still valid.
      Edit: Mack73 beat me to it.
    14. Awaiting Email Confirmation mk3er's Avatar
      Jan 5th, 2007
      North of The Wire
      05-06-2011 11:29 AM #14
      Quote Originally Posted by mack73 View Post
      So what we're really talking about here would be a tag axle setup?
      Though not necessarily a drop axle, more like what you have on buses/motorhomes?
    15. Member TurboWraith's Avatar
      Sep 4th, 2004
      IL
      '13 Focus
      05-06-2011 11:32 AM #15
      Sure it is. I think the two main points of why it isnt done (other than cost) is;
      1. Licensing issues
      2. Tight turning on pavement sucks in these types of vehicles. I dont know if you have ever driven even a 6x6 ATV/UTV before, but the tire scrub from the rear tandems creates a lot of resitance. Its worse on larger vehicles. If you guys ever get behind the controls of something like this:
      You'll see right away how much power it takes to overcome that tire scrub. Traditional duallys are just easier to drive, even with the incrased width.
    16. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      05-06-2011 11:33 AM #16
      It's not valid. A single axle is more than enough to take the payload into the CDL requirement category.
      The only purpose of another axle would be "to look cool".
    17. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      05-06-2011 11:36 AM #17
      A 3rd non driven axle is referred to as a tag axle and it just isn't necessary in trucks with this capacity. Without driving the extra axle you would have less traction available than you would with a true dually becuase you have fewer driven tires.
      There isn't much difference in a 1-ton truck and a 1-ton dually, mainly the hubs and rear brakes. The same isn't true for a 3 axle truck. It all comes down to expense in relation to the extra capacity provided.
      In some areas tolls are also calculated with the number of axles so a 3 axle truck would be more expensive to operate.
