#351
#352
#353
Give Tom a break. He is very skilled and could have easily accomplished this build in a couple weeks if it weren't for the multitude of unexpected problems that arose along the way. I am fully confident that Mitchs car will be sorted out soon enough and running strong on the road! So go ez and be ez on others!
#354
trans stays in for head gasket replacement.![]()
I "ruined" a limited edition .:Race car
R32 Turbo Build Round 2! Faster, Lower, Smoother.
Integrated Engineering
#355
I dont know why im picturing the tranny having to come off in order to remove the chainoh well .. so you're saying the best idea would be to swap from 2 gaskets to 1 and machine down the guide for best fitment?
thats cool .. you can stay outta my thread now .. you have been a member for a year and a half and average 6 posts per day of absolute useless information .. so please stop cluttering it in here
#356
#357
Im not going to direct this at the OP since his bay is pretty custom and he has had a hard enough time as it is, however that Quote should sure as hell go in a Sig or maybe even be Stickied somewhere for future generations of modders!
I took exactly that advice and my car came out of the shop, I put gas in it, drove it 800km home, and have been driving and enjoying it ever since
OP, I was going to mention why not just take the head back of and redo the whole thing, if only to have peace of mind down the road, but I thought that might be the last thing you wanted to hear after your long wait...
HGP-T 450PS, Unibrace, 225/40/18 AD08s, OZ Ultraleggera, Light BBK F&R, Recaro Interior, .:R extras, MFD Navi, Phatbox, JCaps, Neuspeed, PSS9s, H2Sport Stage 3, DLI-Teknik, GC links, bHPP, etc...
#358
My kit has a 8.5:1 and I had to use a custom chain guide made by HPA, and my timing was tricky as well. When I blew my head gasket and I replaced it I had problems with the timing, I sweared that we did it on point, but we didn't, had to take it to KMD tuning (HPA dealer) and had them do it. They said HPA has a "special" way on doing they timing on that kit....![]()
JDS Motoring | CCW | Linden VW/HPA MotorSports | LosGoonies.com
It's not just a passion, it's a life style!
#359
this wasnt a "kit" by any means .. so nothing fit .. at all really .. and thats my fault for trying to make it work .. between trying to make a 24v downpipe fit on a r32 exhaust manifold with a S cover turbine housing to custom charge piping .. to trying something new out on the transmission casing that didnt quite work out .. not to mention using 2.5" charge piping off the turbo .. 80% of "kits" use 2 inch piping to insure fitment .. but my turbo housing was 2.5 so we went with 2.5 .. everything fits .. its just all super tight and its a pretty amazing setup
compare my bay next to a bolt on c2 or kinetics kit .. there is a world of difference .. not to mention tom did a stellar job on the wiring .. everything is SUPER clean and everything unnecessary is deleted in the proper fashion.
#360
#361
#362
#363
#364
Yeah tell me about it, I had to ditch out $1,200 for them to do the timing, car was running fine but kept getting these codes....
Sunday,03,April,2011,23:06:22:12060
VCDS Version: Release 10.6.3
Data version: 20101206
Address 01: Engine Labels: None
Control Module Part Number: HGP Turbonac HW: 14. 4.0 3
Component and/or Version: hruestung GMBH G b121
Software Coding: 0000132
Work Shop Code: WSC 13621 156 402982
VCID: 1D3A4830BD37
2 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 001 - Upper Limit Exceeded - MIL ON
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
P1347 - 001 - Upper Limit Exceeded - MIL ON
after they did the timing everything was fine....ahhh gotta love turbos...![]()
#365
#366
OP, here is my head spacer install and no tran's removal.
http://forums.vwvortex.com/showthread.php?3166457
#367
yeah i cant bring myself to dropping that coin on the schricks at the moment .. whats the difference between them and the techtonics .. schricks putting out more power at top end vs techtonics more midrange? I sent you a request on facebook .. I upload more photos on there than I do on here ..
#368
The info I have shared here is specific to the 9.0 : 1 spacer setup C2 sold in the past.
As far as the HPAs kits, in the past they used two mechanisms to relieve tension.
One is the machined guide and two is the oil feed line / banjo fitting that they use on the main tension bolt.
The simple presence of that fitting takes up a few threads and lowers tension on the chain.
Don't get distracted though. You are using 9.0: 1 head spacer and your oil feed comes off the top of the oil filter housing right?
#369
Agreed on both counts, and noted in my previous posts.
Well, its not exactly a huge secret (in general), however, thats one of the benefits you get (or should get!) when going with a proven kit. I dont think a company should have to share all those little things - thats one big advantage why to buy a kit because (hopefully) someone has figured it all out beforehand
Like you said, yours wasnt a kit at all, so, in some areas you were running blind...
Thats how it is when you want something different.
#370
#371
#372
yes .. we have the old chain on .. we couldnt get the new chain on due to it being that tight
in my perfect world .. i would like my new chain on .. 1 head gasket split in half .. and a modified guide if necessary .. removing the chain without breaking it would mean trans has to come out .. correct?
let me explain that a little further .. I bought a new chain .. new chain wouldnt fit .. so we put the old chain on which was worn out and fit .. but just barely
#373
#374
I dont want to .. like i said in my perfect world .. with the single gasket and a modded guide .. which is documented to work .. a factory chain SHOULD fit .. but with 2 gaskets
i dont know how he plans on doing this .. i assume .. break the chain while its still connected but taken off the gears .. break the new chain .. add a link .. run the chain through the gears til it loops back up .. then press them together? but how the heck is he going to press together a chain while its connected to the motor .. if hes going to make the chain longer by adding the link outside of the car and then completing the chain so its all connected .. then isnt he going to have to remove the trans anyways? I imagine pressing a chain together would need a machine press .. or is there some sort of handheld tool that can securely press it secure?
all i know is he says he can do it .. and has done it before .. not on a boosted R but on VR chains several times .. so lets sit back and see how this pans out
and just a tidbit here .. I dont do the work on my motor .. all work is done by tom .. am i capable of doing most of this stuff? probably .. but i dont own 1/500th of the tools that tom has .. i just do all the polishing and tedious things .. I work 50 hours a week behind a computer so I dont have time to do this kinda stuff
#375
#376
Mitch hope you get it sorted out any questions just ask. Let me know what route you go. Something has to work for you
-JAMES-
Daily Drive /Beaten/Built /UM Turbo R - VR NATION
#377
thanks James .. I hope I don't come off sounded like a "noob" when i post all these questions .. id prefer to just have people who have first hand experienced it and have gone through it themselves to shoot out answers and plausible ideas so that i dont completely **** up here
ive got A LOT of money into this thing![]()
#379
we are using the further performance 9:1 spacer but the actual compression on this motor is closer to 8.5:1. Using a non split gasket modified for max coolant flow has greater benefits than the traditional split gasket design. Yes, one may argue that a split gasket seals well but understanding how it works you would argue for the non split gasket. Having more layers makes it flexible to form to irregularities in material as well as have a higher tolerance for uneven expansion in bursts of heat.
I might be wrong but then again, VW/Audi might be wasting money on their headgasket design.
Innovative Motorsports - Making wet dreams come true. Shop# (203) 345 4647
United Motorsport - Making software to rule the world.
#380
ladies and gentlemen we have a celebrity in the building![]()
#381
#382
I understand the two gasket theory.. But why reinvent the wheel? For quite a while 12v's have been running split gaskets aswell as alot of r's and 2.8 24v's with good success and no mods to chains or guides. Im gonna run a further spacer and split gasket on my setup, which is extemely similar to yours mitch. Down to the 4" inlet housing and ram horn manifold
WunderWagens June 10,2012 in Gilbert, PA... 2nd year http://www.wunderwagens-show.com
UnitedMotorsport r32 cam flash... get one
My Turbo .:R Build Thread
WunderWagens Vortex Forum
WunderWagens Facebook
#383
i didn't understand this concept of toms idea with the chain until he showed me how a chain comes .. split already .. so who is the say they can't be taken apart, extended, and re-connected ..
additional 1/2 link was sourced overseas .. running the dual gaskets is a slight extra bit of reassurance that there will never be any problems .. and tom is pretty good with measurements and calculators so i trust his idea on this and we will see where this goes
I've been busy all week with this ****
turning this
into this
not for me .. for a buddys 1.8t .. baby throttle body
his caps def needed a touchup ..![]()
#384
how was pulling the guts out of that TB? kinda want to mod mine but i'm afraid to with all the electronics in it still.
"I'm DrB and I approve this message."
instagram doktor_b
projekt oveRhaul - i hate my caR and i hate you too
#385
well thats not for my car its for a 1.8t .. all that was taken out was the black casing and 2 gears inside .. then I threw some painters tape around it tightly so i didnt bother anything .. pretty sure the entire thing can be taken apart fairly easily though
