Results 1 to 15 of 15
Thread: Various engine/trans noise assistance...
  1. Member theguy831's Avatar
    Feb 28th, 2011
    New Hampshire
    GLI 24v
    05-07-2011 01:21 PM #1
    k, so here it goes, 2003 24v, almost 100k. I've noticed when the car is at idle, there is a sound that almost seems like there's a rock stuck within the motor that's bouncing around. Carr runs good, no lights, no codes, just noise. Another noise which sounds like ticking which may be the evap based on other threads.
    I can not figure out what the noise is, can't hear it when revving, but the ticking noise seems to speed up.
    Not super specific, sorry.
  2. Member theguy831's Avatar
    Feb 28th, 2011
    New Hampshire
    GLI 24v
    05-07-2011 01:23 PM #2
    in addition, wrong forum, but the transmission seems to make a sort of grinding noise. not the typical noise you hear when someone misses a gear or something, it's very quiet and only audible when the car is in first or reverse between 1-2k after moving from a stand still.
  3. Member jaso028's Avatar
    Aug 12th, 2007
    02.5 24v GLI, 05.5 Jetta 2.5l
    05-07-2011 09:32 PM #3
    Ticking is Evap completely normal.. it will quite down once its warm and almost sound like a bad lifter... its not..
    The trans noise, It could be a few things.. Original clutch? could be time for a Slave Cylinder... another thing to consider is some fresh gear oil... this will be the easiest thing to do, cause if you need a slave the trans has to come out and @ that point put a new clutch in..
    this other noise you speak of, any chance to get a sound clip of some sort???
    you could as well check your pulleys and accessories over on the passenger side to see if some of them are making noise.. I had a weird ticking/knocking sound.. thought it was my tensioner turns out my PS pump is making an odd noise... So time to replace that..
    you can take a long handled screw driver and put it up to each component and put your ear on the handle, that will magnify the sound...
    hope this helps...
    N.E.R.D.
    White Lightning
  4. Member apstguy's Avatar
    Apr 3rd, 2006
    Chico, CA
    2008 VW R32
    05-09-2011 11:53 AM #4
    If he noise is rattling like marbles, it is you intake shifter rod "bearings". They wear out and get loose.
    2008 VW R32 #587
    Gone: 2002.5 VW GTI 24v VR6 - 180k+ miles
    *My other car is a 1985 Chevy C10* 305 Bowtie Overdrives 700r4 3.08 - Ssslllooowww but sexy!
  5. Member theguy831's Avatar
    Feb 28th, 2011
    New Hampshire
    GLI 24v
    05-09-2011 12:11 PM #5
    Quote Originally Posted by apstguy View Post
    could be a marble like sound..it'd be like putting a rock or marble in a soda can, covering the top with your hand, and shaking the can a little, i can only hear it at idle. any good way to check this?
  6. Member theguy831's Avatar
    Feb 28th, 2011
    New Hampshire
    GLI 24v
    05-09-2011 01:07 PM #6
    Quote Originally Posted by jaso028 View Post
    hope this helps...
    I tried the screwdriver trick, nifty, but i couldn't actually manage to magnify the sound. but it seems that is coming from the passenger side, but i can hear it in the cabin with the hood down.
  7. Member apstguy's Avatar
    Apr 3rd, 2006
    Chico, CA
    2008 VW R32
    05-09-2011 04:21 PM #7
    2008 VW R32 #587
  8. Member jaso028's Avatar
    Aug 12th, 2007
    05-09-2011 04:41 PM #8
    you know suprisingly I am @ 176k and still have the originals in there...
    I dont have any noises though.. weird!!
    I was just saying..
    N.E.R.D.
    White Lightning
  9. Member theguy831's Avatar
    Feb 28th, 2011
    New Hampshire
    GLI 24v
    05-09-2011 06:06 PM #9
    I know there's a diy on gruven for the 12v. Does the 24v differ?
  10. Member jaso028's Avatar
    Aug 12th, 2007
    05-10-2011 07:29 AM #10
    not @ all same procedures...
    N.E.R.D.
    White Lightning
  11. Member apstguy's Avatar
    Apr 3rd, 2006
    Chico, CA
    2008 VW R32
    05-10-2011 01:46 PM #11
    For replacing the intake manifold shifter bushings it is EXACTLY the same 12V or 24V.
    2008 VW R32 #587
  12. Member jaso028's Avatar
    Aug 12th, 2007
    05-10-2011 03:13 PM #12
    I said that Meanie!
    maybe if I put a comma in there it would of looked perfect!!
    N.E.R.D.
    White Lightning
  13. Member apstguy's Avatar
    Apr 3rd, 2006
    Chico, CA
    2008 VW R32
    05-10-2011 04:13 PM #13
    I said that Meanie!
    With a comma it makes perfect sense. Grammer Nazi strikes again!
    2008 VW R32 #587
  14. Member jaso028's Avatar
    Aug 12th, 2007
    05-11-2011 07:54 AM #14
    N.E.R.D.
    White Lightning
  15. Member
    Nov 23rd, 2010
    chicago
    08-09-2012 06:37 AM #15
    Quote Originally Posted by theguy831 View Post
    pretty sure that's your sway bar bushings.
