VWVortex.com - Horn fuse keeps blowing--WHY?
    Results 1 to 11 of 11
    Thread: Horn fuse keeps blowing--WHY?
    1. Junior Member CGJet's Avatar
      Apr 20th, 2009
      2001 Jetta 1.8 Wolfsburg
      05-07-2011 05:19 PM #1
      Can anyone help me to trace why the horn fuse keeps blowing. No work has been done on the car recently to short it out. I have changed the fuse and followed the wiring as much as I visibly can and I don't see anything fishy.
      Can anyone help???
    2. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      05-07-2011 05:25 PM #2
      Obviously it has a short in the ckt. Pull the fuse and test the power wire at the horn for a ground. Also check in the Bently manual to see if it has a relay, could be a bad relay.
    3. Member saps's Avatar
      Jul 10th, 2009
      Sterling Heights MI
      3071'd 20th GTI
      05-07-2011 07:08 PM #3
      Short to ground, meaning the power wire is directly touching a ground wire or chassis ground.
    4. Junior Member CGJet's Avatar
      Apr 20th, 2009
      05-07-2011 07:55 PM #4
      Sorry but what do you mean "short in the ckt"? What is that?
    5. Junior Member CGJet's Avatar
      Apr 20th, 2009
      05-07-2011 07:57 PM #5
      Quote Originally Posted by saps View Post
      Any idea where to start looking for this power touching a ground wire or chassis ground?
    6. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      05-07-2011 08:44 PM #6
      Quote Originally Posted by CGJet View Post
      "short in the ckt"?
      It means you have a short in the circuit, where power is going to ground w/o going to the load. "Short circuiting the load". I would start at the horns, check them for resistance, one of them could be bad, then ohm the power lead to the horns. If all this still means nothing to you, you may have to have someone familiar with trouble--shooting a DC circuit help you or do it. A Bently manual will be a big help for the wiring diagram. But if the "short" is readily found, it could be buried in the dash steering column or engine compartment. GL
    7. Member 16plus4v's Avatar
      May 3rd, 2006
      Rossland, BC
      '15 M235i Performance Edition, '15 GTI Autobahn DSG stg2
      05-07-2011 08:53 PM #7
      How is this a 1.8t "specific" tech related issue ?
      '15 M235i Performance Edition w/LSD 6MT - His
      '15 GTI Autobahn 5dr - DSG Stage 2 - Hers
      iracing.com - The best simulation racing software, period.
    8. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      05-07-2011 08:55 PM #8
      must be on a car with a 1.8t motor. might get more interest/help in the mkIV Jetta forum.
    9. Member 16plus4v's Avatar
      May 3rd, 2006
      Rossland, BC
      05-07-2011 08:59 PM #9
      Quote Originally Posted by ps2375 View Post
      Thats what I'm hinting.
      Its like this 1.8t forum has turned into a freaking "HELP ME" and "I DONT KNOW ENOUGH TO BE WORKING ON MY OWN CAR" forum..FML..
    10. Junior Member CGJet's Avatar
      Apr 20th, 2009
      05-07-2011 09:06 PM #10
      Thanks so much for the help. Sure someone will help you out when you're in a jam.
    11. Member
      Jul 2nd, 2002
      Orlando-ish
      2011 Hyundai Sonata GLS, 2002.5 Jetta 1.8T (gone)
      05-08-2011 07:30 AM #11
      our cars have horns?? If I want to get someone's attention, I just rev it and let the loud BOV whistle at them
      Sent from my Apple Newton.
      Quote Originally Posted by JoeyVR6 View Post
      you didn't get ripped off, you got out smarted.
      congratulations.
      Quote Originally Posted by Genuine Rolla
      The 1.8T is God's chariot. It runs on the tears of virgins.
