VWVortex.com - ignition lock cylinder how to?
    Results 1 to 22 of 22
    Thread: ignition lock cylinder how to?
    1. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-08-2011 07:56 PM #1
      does anyone know how to change the lock cylinder on a mk3 jetta? mines bad and im new to the vw game so all help is appreciated. thanks in advance everyone.
    2. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-08-2011 09:14 PM #2
      Bentley manual has some pretty good instructions for it.
      We need a series like this state-side. I'm in if there is one, or will be one. VW Cup 2017/8, anyone?
      DIY: Adding a "cruise engaged" indicator to the cluster
      Odometer: 164319mi | 269 full tanks | 84,631.9mi | 2,969.143gal | 28.50381mpg | US$0.10163/mi
    3. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-08-2011 09:34 PM #3
      unplug negative batt terminal, take steering wheel off, take wiper/turn stalks off. attempt to use a puller of some sort to pull the metal housing that the ignition lock cyl is in off of the steering column. give up like i did, go ahead and grab your drill with a small bit, drill a hole, push locking pin back into ignition lock cyl, pull it out.
      shove new one back in, put turn/signal stalks back on, put steering wheel back on, plug everything back up.
      vague instructions which will get you through. just try to find the measurements of where to drill the hole, i think bentley has measurements for location; if not - i know somewhere online has it. lol
      '96 Golf Harlequin VR6, Chagal Blue base
    4. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-08-2011 10:09 PM #4
      ahahhh! nice thank you im waiting on the part to come in and once it does im putting it on cause im tired of mine shorting out and having to cycle the switch on an off over an over to start it haha
      once its done i'll post again to let you know how it went!
    5. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-08-2011 10:42 PM #5
      The lock and housing usually doesn't have to be replaced. Your problem is most likely the switch (since you mention having to cycle it a few times), which is much easier to replace than the lock & housing.
    6. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-08-2011 11:24 PM #6
      Quote Originally Posted by mk3FTW. View Post
      yeah... don't replace the entire lock cylinder if you are having electrical-ish issues. only need to replace the lock cylinder if you are having issues with the key turning the lock.
      just replace the ignition switch.
      http://www.germanautoparts.com/Volks...ectrical/206/4
    7. Member Old Windy's Avatar
      Mar 31st, 2009
      Someplace where there is no snow
      2.15678L 16V ABA, SN 95 Mustang V8, 2013 Frontier V6
      05-09-2011 12:00 AM #7
      Quote Originally Posted by dceola View Post
      Besides parts this might be able to make it easier. Don't forget to search the DIY's or the forum.
      http://forums.vwvortex.com/showthread.php?2532481
      Quote Originally Posted by Time for a GTI View Post
      Banging a hooker will make the wasps go away? I'm off to find a bee's nest. BRB.
      Quote Originally Posted by 88c900t View Post
      You mean CalDeRoo?
    8. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-09-2011 08:05 AM #8
      yep, use that DIY. I've done this twice. hardest part is getting the steering column shaft back into the u-joint and keeping that stupid effing spring in there where it's supposed to be. I've done this twice on 2 diff cars now; first time it took me about an hour.. 15mins to change the switch, 40mins to get the shaft back in the u-joint properly.. second time took me about a half hour.
    9. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-10-2011 10:43 PM #9
      Wow you guys are hero's thanks for the tips an links!
    10. Member
      Sep 25th, 2006
      MKIII Museum
      05-11-2011 06:22 PM #10
      If you prefer working while sitting, rather than climbing under the dash.... buy a bearing separator and a 2 jaw puller. You clamp the separator to the serrated sleeve and pull it off. It takes 5 minutes.
    11. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-13-2011 12:43 AM #11
      I gave this project my first shot today and noticed that same thing I just didn't have pullers :/
      Also I could not get the lock cylinder out for the life of me and ended up drilling 6 holes an it's still not out :fail:
      Any more tips guys?
      Sep 25th, 2006
      MKIII Museum
      05-13-2011 12:55 AM #12
      Are you changing the actual "key" part of the lock or the switch?
    13. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-13-2011 10:19 AM #13
      Both cause they're both bad I jus want to knock them out at the same time
    14. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-13-2011 10:25 AM #14
      if you are doing both then just go pick up a good puller and the other thing the above guy said; take the steering wheel and turn/wiper stalks off, and pull off the metal collar thing that holds the ignition lock and switch in.
      when i tried to change my ignition lock, I just had a standard 3jaw pulley puller.. and it didn't work @ all. the lip on the metal collar was so small i couldnt get it done. Def need the bearing separator to clamp around it to help pull from.
    15. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-13-2011 11:37 AM #15
      alright cool thanks for the tip. im still having a lot of trouble getting the clip on the lock cylinder to push down in order to pull the cyclinder out in the first place, like i said i have like 5 holes drilled and still cant get that b*tch out
    16. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-13-2011 11:44 AM #16
      yikes.. you sure you are in the right area with the holes?
      when i did mine, i drilled two times to get it right... i measured and marked the spot to drill; first hole i could see the thing to push down but couldnt get to it, second hole put me right on the nose
    17. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-13-2011 12:00 PM #17
      im pretty sure, i used a diagram but i could have had it upside down. did you drill from the top of the housing or the bottom of the housing?
    18. Member
      Sep 25th, 2006
      MKIII Museum
      05-13-2011 02:09 PM #18
      Look at your new lock. You'll see where the metal spring that needs to be depressed is located.
      It's 12mm in from the edge of the housing
    19. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-13-2011 02:28 PM #19
      Yeah, my first housing drilling experience was a fiasco. I ended up making like four holes so close to each other that it turned into one giant hole, and even after hammering that spring on the cylinder down and bending it permanently into the "release" position, it still didn't come out. After getting the housing off, I took the switch out, put a punch on the back end of the cylinder, and gave it a good smack and it flew across the garage floor.
      then after replacing the housing and the cylinder (and rearranging the pins in the new cylinder to match the old key), I installed it, but did it upside down somehow, so I had to drill a hole in the new housing to pop it out and try again and it was a bulls eye. Used a punch just to press the release spring down and pulled the cylinder right out.
      Regarding that collar that is in the way, I used a 2-jaw puller. Got the grinder out to make really sharp edges on the jaws, then used my hand to hold the jaws tight and slowly pulled the collar off.
    20. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      05-15-2011 03:52 PM #20
      from the Top. (top as in, if the housing were still in the car, it's on the top, facing up)
    21. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-17-2011 04:48 AM #21
      Quote Originally Posted by Sky-Fi View Post
      that is my nightmare for this project actually haha but your experience will help me complete mine so thank you lol
    22. Member mk3FTW.'s Avatar
      May 3rd, 2011
      MD
      '98 Jetta GL 2.slow
      05-17-2011 04:49 AM #22
      shoo what a relief, at least i know im in the right direction and not COMPLETELY screwing this thing up haha
