VWVortex.com - How to remove mortar from concrete?
    Results 1 to 15 of 15
    Thread: How to remove mortar from concrete?
    1. Member auburnjosh's Avatar
      Mar 4th, 2004
      Aurora, IL
      2006 A4 2.0T
      05-09-2011 04:37 PM #1
      I pulled up ceramic tile that was on a slab and it left the mortar behind. What is the best way to get this up? I am putting down laminate and need it as smooth as possible.
      Contact me for special pricing on Rigid LEDs
      Feb 11th, 2009
      Lewiston, Maine
      2017 Hyundai Elantra SE
      05-09-2011 05:48 PM #2
      Quote Originally Posted by auburnjosh View Post
      probably be better off using something like levelastic and smoothing what you already have. Why couldn't you just put the laminate over the tile?
    3. Member auburnjosh's Avatar
      Mar 4th, 2004
      Aurora, IL
      2006 A4 2.0T
      05-09-2011 07:13 PM #3
      Quote Originally Posted by Egilbe View Post
      Because I am using a 12mm laminate and it would make the countertops lower, would have to shave doors, and cut casing. I figured removing the tile was easier. Removing the tile was easy but scraping the mortar is taking forever.
    4. Member robr2's Avatar
      May 5th, 2005
      Boston
      2015 Passat "Limited Edition"
      05-09-2011 07:40 PM #4
      It might be quicker and easier to pull up and replace the subfloor.
    5. Member auburnjosh's Avatar
      Mar 4th, 2004
      Aurora, IL
      2006 A4 2.0T
      05-09-2011 07:46 PM #5
      Quote Originally Posted by robr2 View Post
      subfloor? I'm on a concrete slab
    6. Member eluwak's Avatar
      Mar 18th, 2002
      LF, odnalrO
      '16 Silverado 2500 CCLB, '14 Sienna, '98 C2500 454 Burp
      05-09-2011 08:03 PM #6
      exactly
      Probably the easiest way would be to chisel it off as best you can. You may still have to use some leveler if you can't get it smooth enough.
      <insert comment here>
    7. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys, 2017 Barracuda
      05-10-2011 12:50 AM #7
      If you have a compressor try using a cheap air chisel with a 4" wide blade. You can get this stuff at harbor freight.
      Touareg Audio Accessories - Keyless Start - Paddle Shift
      If you use Tapatalk, you aren't seeing the whole message. Tapatalk shortens GIFs, cuts URLs and deletes signatures.
    8. Banned
      Feb 25th, 2004
      ATL
      E30 Cab & 1.8T Golf
      05-10-2011 04:14 AM #8
    9. Member auburnjosh's Avatar
      Mar 4th, 2004
      Aurora, IL
      2006 A4 2.0T
      05-10-2011 12:03 PM #9
      Quote Originally Posted by spockcat View Post
      I was thinking of picking up one. Looks like I'm having a mortar chiseling party this weekend
    10. Member
      Feb 11th, 2009
      Lewiston, Maine
      05-10-2011 01:01 PM #10
      ok, let us know how long it takes you to scrape all the mortar off the floors, vs shaving doors and trimming casings.
    11. Member VdubTX's Avatar
      Jul 5th, 2003
      Rockwall, TX
      05-10-2011 01:25 PM #11
      I did something similar this past winter. Put new tile entry way. Broke out tile with hammer and chisel, then to get remaining adhesive/mortar out, used a long handled scraper with a thick razor blade on it. Worked great, was kind of skeptical about it, but worked fine. Change blades every couple of hours. Got the surface smooth so I could re lay tile on it.
      Used the same scraper in our kitchen taking out vinyl laminate floors and worked great getting the slab ready for laying tile on it also.
      2012 Audi A4 Quattro Premium Plus, push start/stop, Nav, lots of vagcom tweaks.
      2011 VW CC fog lights retrofit LINK
      CC Windows w/key fob & Rain Closing - LINK
    12. 05-13-2011 10:39 AM #12
      + scrap bit of flooring make short work of door jambs.
    13. Member robr2's Avatar
      May 5th, 2005
      Boston
      05-13-2011 04:31 PM #13
      Sorry, I read that as tile on mudbed. Slabs aren't common around here.
    14. Member chrisyoon's Avatar
      May 23rd, 2003
      AZ
      C63
      05-17-2011 09:14 AM #14
      It's not a fun job removing thinset. You'll need this:
      This:
      And This:
      Its a Demolition hammer with varying bits, using the first to break up the larger chunks, and the large flat one to smooth and remove. The large flat one is designed not to damage the slab, the the wide chisel will if you squat on the slab long enough. Then you'll want to float a leveler. Rent one at a tool rental place like home depot if you dont have one. Don't do it by hand.... you'll gouge the slab and it'll take forever.
    15. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      '14 GMC Sierra, '88 Mitsubishi Jeep CJ3B
      05-20-2011 09:35 PM #15
      Quote Originally Posted by chrisyoon View Post
      This:
      And This:
      This is the correct answer.
      You are in for a heck of a job, I hate to say it.
      Also, when you're done, the slab will still not be smooth enough for laminate.
      You have two options once you get the mortar off:
      1) Spread leveler across the whole slab. It'll take a long time. You'll want a long level to check as you go along to make sure you don't have humps and dips.
      2) Put down a thin plywood subfloor first, to glue the laminate to. You can do a floating subfloor, or anchor the plywood to the slab with tapcon screws.
      I now have an InstaGram: emmettlodge
